Old 06-27-2001, 01:31 PM   #1
oldpreza
Member#: 5259
1995 Impreza
Default What do I need to complete a shortblock?
If I had a EJ25 or EJ22 shortblock and I want to make it into a complete engine to swap with my EJ18, what do I need?
I figured so far that I will need:
oil pump,
water pump,
heads,
header,
pulley,
flywheel,
clutch,
fuel rail,
injectors,
ECU,
wiring harnesses,
intake,
intake manifold,
throttle body,
A/C,
alternator,
starter
can you think of anything else?
oldpreza is offline   Reply With Quote
Old 06-27-2001, 01:39 PM   #2
jeffg
Member#: 2958
2001 6.0?RS
If you are buying a shortblock from a rebuilder, they typically have the oil pump already mounted.
Does the car have AC already? If not, you will need the compressor, heat exhanger (radiator looking thing) and all the hoses and control parts.
That should be about it.
Jeff
jeffg is offline   Reply With Quote
Old 11-18-2009, 01:34 PM   #3
RR
Member#: 48191
2012 WRX
Ducati Monster
I am considering a shortblock with 40k, I have my current engine with 140k with blown timing belt, tensioner, and idler pulley bearings. I should be able to cobble something together between the two correct?
RR is offline   Reply With Quote
Old 11-18-2009, 11:21 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Is any part of your motor damaged? Besides the timing belt/tensioner/pulleys.
~Josh~
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-15-2010 12:49 AM
What do you need to do to have constant voltage to fuel pump? csugden Electrical & Lighting 2 10-31-2009 11:39 AM
what do i need to complete this exhaust alfmoney Newbies & FAQs 5 10-25-2006 01:56 AM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 07:43 AM
uppipe and axleback exhaust aquired.. what do i need to complete setup imprezu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-21-2003 08:06 PM
