Old 06-27-2001, 12:45 PM   #1
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
Unhappy Smoother shifting?
I got the Shifter installed. ( Thanks Josh) But I want a smoother shift. Will the Cusco bushings help? What can I do to improve my shifting. Who can tell me some technics on shifting? i.e. Power shifting, Double shifting, etc...
Rowdy2.5 is offline   Reply With Quote
Old 06-27-2001, 01:17 PM   #2
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
I recently installed the Syms kit + cusco bushings on my car..
First off, this kit is obscenely nice. Installing it turned out to be a pain that I couldn't do without dropping the tranny a bit, so I cheated a bit and popped the shift level itself out and replaced it like shown for the shifters that only replace that one thing.
Also, I dumped the bushings from the Syms kit and switched in the cusco bushings, mainly because the Cusco ones are harder.
The improvement in shifter feel was wonderful, and I have all of 4" of shift travel. Friends with sticks say that their throws are around 6 to 8, sometimes 9" depending on the car, and love how my shifter feels now.
I would highly, highly suggest the cusco bushings, they seem to be the hardest ones out there, and offer the greatest advantages. Also, I would not suggest installing a $300 shift kit when its only the lever and the bushings that are different (didn't notice any difference between the bushings where they meet to the back of the tranny tunnel). But thats for you to decide =)
Scoob_13 is offline   Reply With Quote
Old 06-27-2001, 01:23 PM   #3
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
I think I will try for the bushings then. Afterall they're only $10 a pop. Thanks for the info.
Where are you Josh!!!
Old 06-27-2001, 07:33 PM   #4
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
If you need some help installing the bushings, let me know, they're fairly easy to do if you have an area to jack the car up or have access to a lift. Only hard part I encountered was getting the stock bushing out; its 1 solid piece and an absolute pain to get out without careful use of a lever against the tranny tunnel.
Took all of an hour to switch those out, but I was following directions and trying to take some decent video for my own fun and joy.
If anyone ever finds harder bushings than the cusco ones, I'd love to know where to get them, its an absolute blast when you go to shift now.
Old 06-28-2001, 11:40 AM   #5
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
I have also noticed that when the shifter is in gear, it still can be moved about a half inch left and right. Is this normal? C'mon subie specialists, help me out!
Old 06-28-2001, 12:51 PM   #6
Scoober01
Member#: 3649
2001 Impreza 2.5 RS
Blue Ridge Pearl-Red acc
Default Not sure about that..
Be carefull. I first got the cusco bushings thinking harder is better. I also picked up a short throw shifter. Yes the feel is much more of a click-in. I had them install free by a local shop. I took it out for a test drive and found my shifter wildly vibrating at all rpms. I could still hear it over the stereo, pumped up with windows down. It was too much. This was with the stock leather shift-top even. I took the car back the same day and had the STI bushings install. The stock bushings were gravy soft, the cusco bushings were rocks. the STI bushings were very sold hard rubber. The outside was kinda soft but the more you tryed to bend them the hader they would get. I had them installed and loved them. They felt exactly the same as the cuscos with no vibration at all. The shifts still click in and felt very stiff.
Just my .02
best of luck
Ryan D. the OG Ryan
Scoober01 is offline   Reply With Quote
Old 06-28-2001, 12:56 PM   #7
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
Talking
Where did you get the STi bushings? How much where they? Don't break me now!
Old 06-28-2001, 02:08 PM   #8
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
Hmm, I don't feel any abnormal vibrations through the shifter after I installed them. Are you sure that everything was torqued down correctly and that they were installed with the metal plate on?
Old 06-28-2001, 02:26 PM   #9
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Default I think Kartboy bushings are harder...
I think Kartboy bushings are probably harder (I have Cusco). Doesn't N1 or somebody make a bushing set that is Delrin? This is a hard white nylon and would be harder than either Cusco or Kartboy...
Doug
Edit: I just pulled out my RS shifter and replaced it with a Graham Goode. I have the Cusco bushings. I have noticed a buzzing/humming noise that seems to be coming through the shifter since I changed it. It isn't bad, and there isn't any visible vibration, but I didn't notice it before with the RS shifter. I wonder if the rubber in the middle dampens the vibration on the RS shifter?
dvancleve is offline   Reply With Quote
Old 06-28-2001, 02:28 PM   #10
jeffg
Member#: 2958
2001 WRX (GC8)
As far as smoother shifting I would look at replacing the tranny fluid with something like Redline MT-90.
jeffg is offline   Reply With Quote
Old 06-29-2001, 01:22 PM   #11
da_pain
Member#: 4159
I second you Jeff... I had my transmission oil changed on my car (which is not a subaru, yet!) to Redline oil and the feel is much better. Before the change, I had a real hard time downshifting in 1st when going 5 mph... but now, it's working way better, so I can sell the damn car more easily and get the impreza!
Good luck,
-phil
da_pain is offline   Reply With Quote
Old 07-03-2001, 02:01 PM   #12
kar250c
Member#: 1172
2000 2.5 RS Coupe
Blue Ridge Pearl
Rallispec shows:RS008 RalliSpec Shifter Stay Bushing $35
Machined from delrin.
They are very light, hard and grey. I had those installed with their short shifter and engine/trans mounts from Primitive. There is a little vibration transmitted to the frame at idle, but nothing moves and the shift pattern is extremely tight and precise.
kar250c is offline   Reply With Quote
Old 07-03-2001, 03:10 PM   #13
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
I have the rallispec bushings... they are excellent. No Buzz from them, and really really solid.
Midwayman is offline   Reply With Quote
Old 07-09-2001, 11:46 AM   #14
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
Talking getting rid of it...
after much consideration, i have come to the conclusion that i getting rid of the short-throw shifter. I used it for a week and I want to get another one... $100.00 for the entire set. OBO
any takers?
Old 07-09-2001, 12:47 PM   #15
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Post
pm'ed ya rowdy
DanzBorin is offline   Reply With Quote
Old 07-09-2001, 03:55 PM   #16
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
Default on the lookout...
I see ya... I mailed you back...
New tires = smoother shifting? unity General Community 6 02-11-2004 10:13 AM
lightweight flywheel=smoother shifting? quest Newbies & FAQs 4 01-22-2004 11:12 PM
Idea for making AWD 4EAT shift smoother! d4d4d4d4 Transmission (AT/MT) & Driveline 6 07-12-2003 02:44 PM
How to make shifting smoother? Oo DaRk StAr oO Transmission (AT/MT) & Driveline 23 03-23-2003 10:38 PM
smoother shift with Outback? If yes, why? iBlueVirus Normally Aspirated Powertrain 7 05-30-2001 12:06 AM
