#1 |
Member#: 11024
Vehicle:2002 WRX Weird black |
Can anyone please give me a detailed instruction on how to replace the alternator? Or, where I can find the info?
Thanks!
#2 |
Member#: 26739
NWIC
not really that hard... just take a marker and mark the threads on the tension belt tightener so you remember how tight to make the belts again. its held on by what, like 2 bolts? My Girlfriend replaced one on the side of the road out in the middle of eastern washington at like 1030pm with a leatherman and a broom handle.
if you still need help i can write up more when i am not at work. on a 1-10 scale of difficulty an alternator change is about a 3, right under tying your shoes in the dark (3.22) and above making a omlette (2.87) |
#3 | |
Member#: 11024
Thanks. Mainly, I was concerend about the belt tension but now I know that, it should be a simple swap. The reason I needed to know was because I will be doing in the dark actually and don't want to be surprised by anything.
By the way, I rate making an omelette to be harder than tying shoes in the dark. Quote:
#4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Most important- disconnect the battery before you do anything.
#5 | |
Member#: 11024
Oh, boy. I learned that lesson. I blew a 80A fuse...
| Thread Tools | |
| Display Modes | |
| Step-By-Step Alternator Replacement Instructions?? | chewbakarox | Electrical & Lighting | 2 | 11-27-2006 05:26 PM |
| Window replacement instructions. Help needed. | ProdriveRex | Interior & Exterior Modification | 4 | 05-20-2004 01:04 PM |
| Looking for EJ25 SOHC Timing Belt replacement Instructions | Rickd | Service & Maintenance | 1 | 10-07-2003 01:26 PM |
| rotor and brake replacement instructions | Lil'Blue | Brakes, Steering & Suspension | 2 | 09-19-2003 02:32 PM |
| Strut Replacement instructions | bbaerotek | Brakes, Steering & Suspension | 3 | 02-18-2002 07:35 PM |
