Old 11-09-2004, 05:41 PM   #1
riceburner22
Member#: 25354
Default P2096 code; anyone else get this???
first, the car is a 05 STi. i have a perrin catless downpipe and hks catback. i also have the resistor in the O2 sensor. these are the only mods. now every 300-400 miles i'll get the P2096 code (fuel trim system too lean, bank 1). what do i need to do to fix this? i tried the search for the code but only 3 threads came up with no fixes. can anyone help?? thanks in advance.
riceburner22 is offline   Reply With Quote
Old 11-09-2004, 10:03 PM   #2
riceburner22
Member#: 25354
anybody???? guess not.
Old 11-10-2004, 12:08 PM   #3
909STi
Member#: 62490
2005 WRX STi
FP Green'd & Yimi Tuned
Do you have any other mod's that might be causing this? Or are these your only mods?
909STi is offline   Reply With Quote
Old 11-10-2004, 02:33 PM   #4
riceburner22
Member#: 25354
just the downpipe and catback. everything else is completely stock.
Old 11-10-2004, 07:44 PM   #5
04STiguy
Member#: 36234
2005 WRX STi
CGM
I have the same problem. Same mods. No fix yet.
04STiguy is offline   Reply With Quote
Old 11-10-2004, 07:46 PM   #6
04STiguy
Member#: 36234
2005 WRX STi
CGM
I have this problem too. Same combo. No fix yet.
Old 11-11-2004, 10:15 AM   #7
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
i'd wager it's because the cel 'fix' does not really fool the ecu well enough to pass muster.
i've read arguments that your ltft's are adversly effected by a static rear o2 signal.
i'm kind of stupid about the whole subject but if you search there is an amazing thread on the subject..
DISCOPOPE is offline   Reply With Quote
Old 11-18-2004, 09:12 PM   #8
wlord1
Member#: 44493
yea i get it as well . i have not fixed it either and im running the mechanical spark plug anti-fouler setup thing using the two pieces - im gonna try removing one of em and see if the sensor is fooled better - maybe drill the hole bigger i dunno, its is annoying
wlord1 is offline   Reply With Quote
Old 11-18-2004, 09:38 PM   #9
keyser_soze
Member#: 57445
yea i got the same thing ...about 4 times already....and it usually happens when i'm just like crusing at low rpm ...in the highway...but it did happened once when iwas not moving in nutural waiting for my garage door to open ....
it sucks i hate it...if anyone figures it out please post
i have 05 APS All TBE, CAI, FMIC
keyser_soze is offline   Reply With Quote
Old 11-18-2004, 09:44 PM   #10
riceburner22
Member#: 25354
i was gonna try switching to the anti-fouler but since that doesn't seem to work i'll stay where i'm at. right now i just clear the code with my scanner and call it a day.
Old 12-12-2004, 11:12 PM   #11
02Maxima
Member#: 71438
I just got this code today on my 05 STI. Is there a fix? How do we fix this and what is causing it????
02Maxima is offline   Reply With Quote
Old 12-13-2004, 10:37 PM   #12
02Maxima
Member#: 71438
Someone has got to know why this code comes up and how to fix it. Anybody?
Old 12-14-2004, 04:00 PM   #13
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
maybe the resistor and the 05 stis just dont mix , maybe the changes in the sensors
WRXout is offline   Reply With Quote
Old 12-14-2004, 06:25 PM   #14
keyser_soze
Member#: 57445
every one is 05 correct?
Old 12-14-2004, 06:56 PM   #15
02Maxima
Member#: 71438
Yes, everyone suffering from this, seems to have an 05.
Old 12-14-2004, 07:08 PM   #16
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
Anyone with a high-flow cat getting this code?
-J
Jitenshakun is offline   Reply With Quote
Old 12-17-2004, 06:33 PM   #17
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
05, high flow cat, just got the code today for the first time.
Mods:
Perrin BigMAF Intake
Perrin Inlet Hose
Perrin FMIC
FP Green
Perrin Injectors
GP Moto 4-2-1 headers/uppipe
Vishnu (Taipan XP) TBE
Walbro 255
blinguskahn is offline   Reply With Quote
Old 12-18-2004, 05:43 PM   #18
Jitenshakun
Member#: 61586
2005 STi
hmmm. I wonder it the Cobb AccessPort for our '05s will take care of it?
-J
Old 12-19-2004, 09:32 AM   #19
909
Member#: 18776
You need the perrin 02 simulator. I had the same problem you all describe, used the resistor etc....
The 02 sensor must sense a fulctuating resistance, not a constant resistance. The resistor trick won't work.
This solved my 2096, 4000 miles and not one code.
909 is offline   Reply With Quote
Old 12-19-2004, 12:24 PM   #20
keyser_soze
Member#: 57445
thank you!
Old 12-19-2004, 01:51 PM   #21
Jitenshakun
Member#: 61586
2005 STi
Is this the right fix?
Will the fix have to be removed when I get my AccessPort?
-J
Old 01-03-2005, 08:16 AM   #22
DaHellWidU
Member#: 67496
2011 Legacy GT
another victim
DaHellWidU is offline   Reply With Quote
Old 01-03-2005, 09:59 AM   #23
scrmblr2
Member#: 24631
2005 STI
Default me too
Code: P2096 - Post catlyst Lean Bank 1
Year/Make/Model: 2005 Impreza WRX STI
Mileage: 3750
Fix for problem: None now. Any suggestions?
Comments:
Well, I have the following mods done:
APS CAI
gruppe-s V2 Header w/ o2 sensor(no resistor or mech fix) and egt
Ported vf39
helix uppipe
txs dp
txs high flow cat w o2 resistor, and currently the mech fix as well
txs tappered mid pipe
txs 2.5 rfl muffler
UTEC tuned
It usually takes about a week of driving to and from work for the cel to come on. Only know this because I installed all parts before utec was tuned. I could not pull the code myself, subrau had to pull code. My understanding is it is the exhaust manifold o2 sensor. Was thinking I could wire a resistor mod on that o2 sensor and that would fix problem. Any one else get this code, or able to fix it?
scrmblr2 is offline   Reply With Quote
Old 01-03-2005, 10:11 AM   #24
DISCOPOPE
Member#: 43339
2oo4 STi
no, i don't think you want to mess w/ your front o2 sensor.
Old 01-03-2005, 10:29 AM   #25
909STi
Member#: 62490
2005 WRX STi
Thanks for the advice 909. I have the same problem and I couldn't figure out what to do. I have Ecutek though, and so I thought it might have had something to do with my tune, I guess not.
Anyone else get this email? Orion Texas Impreza Club Forum -- TXIC 13 04-18-2002 05:42 PM
did anyone else get this email? NateDogg General Community 7 12-29-2001 10:15 PM
Anyone else get this e-mail? Tkacik General Community 2 11-11-2001 04:25 PM
Anyone else get this? Die Civic Transmission (AT/MT) & Driveline 1 08-19-2001 02:28 AM
('93-'01) Anyone else get this mag from Subaru? Skirvdawg Impreza Forum 14 04-13-2001 09:44 AM
