Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-15-2004, 05:29 PM   #76
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
I apologize for the asshat statement...There is a forum for reviewing vendors and if you have something to say, type it there and bump it every day if you like. If you have some personal issues with perrin, then PM or Email them to work it out.
They have provided this thread as a service to us with their products. Due to my satisfaction I felt I should chime in. My point being that if you have something that you would like to bring to the attention of the public, post it in the vendor review. But give every detail of the transaction and when/why problems becan to occur. Otherwise keep it between the two of you
Gfunk720 is offline   Reply With Quote
Old 11-15-2004, 05:40 PM   #77
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Correct. Plus the fact that Jeff Perrin is one of the most intelligent AND nice guys I have ever met. Jeff and others have been a great help in building my wrx.
Lots of Perrin stuff on it. Back to topic.
Out.
unkadave is offline   Reply With Quote
Old 11-15-2004, 05:43 PM   #78
PERRIN
NASIOC Manufacturer
Member#: 6776
WRXSHAGGY: Well yes and no. H&R Germany produces those springs for us to OUR specifications. The H&R retail PT# is completely different from ours (excluding diameter). We are then able to offer the best possible TUNERSPORT™ spring for the WRX. By utilizing their advanced facility, steel, etc. we have a completely sag free, block tested, high performance street spring set.
Santofontana: The simplest way to answer your question is that our springs are progressive rate. The first .75" past loaded height is 15% softer than stock to improve freeway ride on plus sized wheel fitments. The max. increase over stock is 45% at full damper compression. This allows a very compliant street spring with the sporty characteristics required for light autocrossing and spirited back road driving. Hope that helps. If not let us know!
Gfunk720: Thank You!
PERRIN PERFORMANCE
PERRIN is offline   Reply With Quote
Old 11-15-2004, 05:44 PM   #79
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Lets not let this unkadave incident ruin the thread - everyone mind your own business.
santofontana is offline   Reply With Quote
Old 11-15-2004, 05:45 PM   #80
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Thanks for answering my questions Perrin!
Old 11-16-2004, 07:53 PM   #81
PERRIN
NASIOC Manufacturer
Member#: 6776
Default santofontana:
Glad we could help. As always just let us know if we can help further!
PERRIN PERFORMANCE
Old 11-16-2004, 08:14 PM   #82
mikey 66
Member#: 52392
Perrin, i have an 03 wrx with port and polish td05-18g turbo from deadbolt.
is your turbo inlet hose a compliment to this turbo?
any problems?
mikey 66 is offline   Reply With Quote
Old 11-16-2004, 08:22 PM   #83
Hagwag02
Member#: 63445
2002 WRX Wagon
any problems?
To piggy back on this question... I am planning on getting a Deadbolt TD05 16g Monster P&P to replace my stocker. Turbo Inlet hose will be compatible with both units, right?
Thanks.
Hagwag02 is offline   Reply With Quote
Old 11-16-2004, 09:56 PM   #84
.RYAN
Member#: 69463
08 Daily - Legacy
Do Perrin suspension products have a no rust warrenty or something to that nature? Living in a place where snow is on the ground 8-9 months out of the year Im sure isnt good on anything.
.RYAN is offline   Reply With Quote
Old 11-17-2004, 11:41 AM   #85
PERRIN
NASIOC Manufacturer
Member#: 6776
Default Deadbolt turbos....
fit just fine with the inlet hose and the hose will produce additional HP over the stock flimsy plastic one. This is true for both the 16 and 18G versions. Hope that helps and thanks for asking!
WRXSHAGGY: Good question. All our products are warrantied for any type of failure. All of our exhaust systems are either 304 or 321 stainless steel which will NOT rust. The swaybars are 4130 chromoly steel, powdercoated to prevent rust. Any other 'metal' items are aluminum which again won't rust. Hope that helps. If a product fails during the warranty period for any reason contact us for a replacement. Thanks for asking.
PERRIN PERFORMANCE
Old 11-18-2004, 03:05 PM   #86
pux888
Member#: 8356
02 STi swap
12 WRX limited
i have a perrin up pipe that has a crack in the weld that meets the flange at the turbo, how common is this?
pux888 is offline   Reply With Quote
Old 11-18-2004, 03:32 PM   #87
PERRIN
NASIOC Manufacturer
Member#: 6776
Default Pux888..
Thank you for asking. This problem is EXTRMELY rare. The 1/2" flanges and TIG welding all but eliminate the possibility. We have had (3) total (not including yours) in the past 3 1/2 years that have ever had a problem. Two out of the three were traced back to customer mistakes by not re-mounting the turbo support bracket. Thereby the entire uppipe/turob/downpipe and a portion of the exhaust were all supported by the welds on the up-pipe. Regardless, all three were warrantied for the customers. Call our offices 503-643-4677 talk to tech support and they can issue an RMA# for the part and give you specific instructions how to return it. We would be happy to help just give us an opportunity.
PERRIN PERFORMANCE
Old 11-18-2004, 03:57 PM   #88
pux888
Member#: 8356
02 STi swap
12 WRX limited
thanks for your time. i did think this would be a rare problem as i have not heard of one myself.
Old 11-18-2004, 05:02 PM   #89
PERRIN
NASIOC Manufacturer
Member#: 6776
Default pux888...
It was nice to speak to you via telephone. As always let us know if we can help further!
PERRIN PERFORMANCE
Old 11-18-2004, 05:41 PM   #90
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I am the proud owner of Perrin rails, rear sway, endlinks, CAI, Wilwood brake kit and SS. The products are outstanding; I commend your company.
On the 2 occasions that I have had to call Adam / Jeff for install questions, they have been very professional and helpful. Johnny on the spot, even See fuel rail thread from two years ago.
I would love you guys to address the question posed about the Perrin rails utilizing a JDM v8 intake manifold, though; I am installing one soon. Thanks for the great service to the community!
Steve Jordan
n2xlr8n is offline   Reply With Quote
Old 11-18-2004, 07:05 PM   #91
pux888
Member#: 8356
02 STi swap
12 WRX limited
PERRIN PERFORMANCE
I really appreciate your time, I know you guys stay busy, and i feel that you have gone out of your way to help. Its this kind of customer service that keeps customers comming back. As long as Perrin carries the product that I need for my car, thats where I'll be shopping.
Old 11-18-2004, 07:16 PM   #92
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Steve Jordan
I can tell you... they will work, but you need to make a bracket. I have perrin rails on my V8 JDM manifold, and it was a lot of work. When you get the manifold and lay it down next to the rails, you'll see what you have to do - PM me if you'd like, I can take some pics.
DarthChicken is offline   Reply With Quote
Old 11-18-2004, 07:55 PM   #93
PERRIN
NASIOC Manufacturer
Member#: 6776
Default Thanks guys...
n2xlr8n: Thanks for the compliment. Darth (may the force be with you) Chicken has offered to help. Let us know if he doesn't provide the answer you need and we will try to investigate further.
pux888: As always never a problem! That is entirely what we are here for. Being "busy" is a poor excuse for poor customer service. Your business is appreciated (as is everyone's) and we wnat to take the time required to make each person happy!
DarthChicken: Thanks for the offer to help this customer!
PERRIN PERFORMANCE
Old 11-18-2004, 08:05 PM   #94
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
It all comes around in the end
Old 11-18-2004, 10:15 PM   #95
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
what kind of grease do you suggest be used with your swaybars? my perrin rear bar is a bit clunky lately and i want to get it greased up before it gets too cold out .. i have the 1st gen bar and you guys send the collars which helped with the walking .. is there a similar fix for the early fronts?
ronaldwrx is offline   Reply With Quote
Old 11-19-2004, 02:09 AM   #96
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Perrin, I have your rear antisway bar and endlinks for my 2004 WRX. Let me first start off by saying AMAZING! The endlinks are terrific piece of engineering good enough to be art and the swaybar is really sturdily mounted with your provided upgraded mounts. My only 'problem' is that the swaybar squeeks in it's mounts where it pivots, that is not at the end links but where the bar contacts the bushings supplied in the kit. I seem to have to about every 3 months or so go under the car and remove the bushing and I re-lube it with some Valvoline sythetic wheel bearing grease. Any suggestions on how to alleviate this problem will be much appreciated.
Thank you.
-Jason Sepe (A satisfied Perrin Customer)
jay25RS is offline   Reply With Quote
Old 11-19-2004, 11:38 AM   #97
PERRIN
NASIOC Manufacturer
Member#: 6776
Default Thanks folks...
ronaldwrx & Jay25rs: We recommend Energy Suspension PT# 9.11104. This Formula 5 Prelube is the ideal choice for lubricating the bushings included in the kit. (This is the same grease we have pre-packed in your kit.) Follow the instructions and you should not have to relube the bar. You might try using a more liberal amount of the grease during the application to prevent leaks. Also, reducing use of high-pressure automatic car washes will also help. In states of the union where the roads are routinely salted you will have to relube the bar seasonally.
Finally, you can get bar clamps for the earlier front bar as well.
As always thanks for the questions and concerns. If we can help further please let us know!
PERRIN PERFORMANCE
Old 11-21-2004, 04:38 PM   #98
caryfd227
Member#: 22512
2015 Subaru WRX
Galaxy Blue Pearl
Uh, you can count two for a PITA install because of the BOC return coupling. The inlet for the turbo went on butter smooth, but I'm working on an hour and a half trying to get the bov hose reattached!!! I am very frustrated to say the least. Any suggestions on getting this damn thing reattached??
Thanks!
Originally Posted by UncleMeat
Perrin - I'm not sure if I just got one from a bum batch or somehow I'm the only one to complain about the BOV return. Chances are it's the former. I understand that no respectable company would intentionally produce a poor quality product, but with the number of people concerned about the inlet hose, I would invest some more QC time on that particular product. Reason being, I rarely see complaints about other Perrin products (including Perrin silicon products) or other inlet hoses (Samco, anyone else?).
caryfd227 is offline   Reply With Quote
Old 11-21-2004, 05:04 PM   #99
caryfd227
Member#: 22512
2015 Subaru WRX
Galaxy Blue Pearl
Angry
Three words... turbo inlet tube.... I would have to say that this is that most bull honkey piece of pain in the rear end thing to install. My up pipe on my WRX was not this bad. I am probably the most angry person in the world right now. I dont have any clue how this could be easy for some one to install... Please someone tell me that I'm not crazy and the BOV return tube is a PITA to get hooked up...
Old 11-21-2004, 06:35 PM   #100
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
A few people have had install problems with the Perrin Positive Steering Response System. Some batch's were missmatched and the instructions were not clear. The main problem was not design (Jeff Perrin) but with Adam Taft and customer service. The instructions were not very clear.
PERRIN™ Q&A thread PART TWO 2.5L PERRIN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1136 09-07-2012 03:15 PM
Snow Performance Q&A Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 21 10-13-2009 08:22 AM
Official PERRIN BOV Thread PERRINJeff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 57 07-16-2006 11:36 PM
SBR INC. Q&A thread Built Industries Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 348 10-24-2005 01:23 AM
