Old 08-11-2006, 11:44 AM   #1251
PERRIN
NASIOC Manufacturer
Member#: 6776
wrxprowler: "So what your saying is that the three holes in your sway bar are not for adjusting stiffness but to compensate for whatever other parts you have on your car? Sorry when I bought the bar I thought I was getting adjustability."
Isn't that what adjustability means? If we only had one endlink mounting hole then they would be considered non-adjustable. Our apologies you are unhappy with your purchase. As always we continue to make evolutionary changes to each of our products. We take any and all feedback into account when making these updates and changes. Your opinions and comments will not be discarded.
Thanks again for choosing PERRIN.
Adam
PERRIN Performance
PERRIN is offline   Reply With Quote
Old 08-11-2006, 03:13 PM   #1252
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
When you buy an adjustable anti-roll bar you expect to be able to use that adjustability to adjust the stiffness of the bar.
If the adjustability designed into the bar is there to let you account for "fitment" issues, then whoever designed the bar has no clue whatsoever about suspension design.
Clearly the bar is defective if all 3 stiffness settings can't be used without metal rubbing on metal. Even if the car was fully stock it would see the same rubbing, springs don't change the amount of travel the car has, just the loads at which the travel is seen.
drees is offline   Reply With Quote
Old 08-11-2006, 03:23 PM   #1253
PERRIN
NASIOC Manufacturer
Member#: 6776
drees: There is no clearance issues at stock ride height with PERRIN or proper length endlinks. Many other things can interfer with aftermarket or OEM swaybars. The springs do change the length of travel, and additionally, when the body is lowered over the suspension, the base reference angle to this type of sway bar is changed dramatically. The working range is changed etc. The holes DO change leverage and can increase the bar efficiency, but they also allow for changes to base reference angles on lowered vehicles. My apologies if the previous response led you to believe that we have limited knowledge of suspension geometry.
If we can help further PLEASE let us know. Thanks again to this community for allowing this type of productive conversation and discussion.
Adam
PERRIN Performance
Old 08-11-2006, 05:44 PM   #1254
drees
Member#: 25905
2003 Silver Wagon
My point is this: Lowering springs don't change the absolute range of motion in the rear suspension, they only change the static ride height.
Rubbing will be less on a car that is at stock height, but it will still be there! You should be able to pull the springs out of the car and run the suspension through it's range of travel with no rubbing.
I stand by my claim that an anti-roll bar that doesn't let you use the stiffest setting because you get more rubbing when the car is lowered using stock endlinks or in this case the manufacturer's own endlinks is not designed properly. Maybe these cases are simply a manufacturing error?
I have seen at least 2 cases of this on the board now, so it's definitely not an isolated case. Without this issue being resolved there is no way I would purchase a Perrin bar for my car.
Old 08-11-2006, 06:19 PM   #1255
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
I didnt find one of these in the 2.5 section so I will post here.
I tired to swap the Perrin silicone turbo inlet hose, intercooler hoses and rad hoses from my 02 WRX and none of them fit properly. Is Perrin going to make these hoses to fit the 06 WRX??
Flexx999 is offline   Reply With Quote
Old 08-11-2006, 06:40 PM   #1256
PERRIN
NASIOC Manufacturer
Member#: 6776
Old 08-12-2006, 10:02 AM   #1257
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Perrin,
I had a 2004 WRX and i purchased your turboback. I traded the car w/ TBe in for a new 06 sti. I loved the sound and quality of the exhaust but it destroyed my bumper.. I deperately want to get your TBE again on my 06 being that i have heard some other exhaust and not really feeling it, but dont want the burnt bumper problem.
1).What changes if any have been made to the TBE?
2).Is your TMIC compatible with a 20G?
3).What are the advantages of your dual tube over your single tube cat back?
Boxer112 is offline   Reply With Quote
Old 08-13-2006, 05:00 AM   #1258
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
rewt: Thank you in advance for your purchase! If you specify when ordering that you are using a WRX block we can provide that line instead of the STI. (They are being produced right now and are not available today, but will be VERY shortly. Sorry for any delay.) Thanks again!
rebos123: Sorry for any inconvenience. Grab your invoice and call me or Jeff at the number below. We can suggest some in the field fixes or issue an RMA to get it back and inspected/repaired/replaced. We are happy to help. Each is supposed to be pressure checked prior to packaging. This one must have slipped! Thanks for the purchase!
Thanks again guys/gals! Sorry for not getting back to you sooner. Jeff and I are not getting notifications on this thread, even though we are both still subscribed. As always if you don't get an answer here in 12-24 hours, call us or e-mail. Again, NO AOL, CS or YAHOO e-mail addresses. The spam filters on those servers routinely block replys. We can get your mail but can't respond. Give us a phone number PLEASE!
Adam
PERRIN Performance
503-643-4677
Adam,
Left you guys a voicemail over the weekend. Plz give me a call and let me know what I need to do to get the leaks fixed on my TMIC. Thanks
rebos123 is offline   Reply With Quote
Old 08-14-2006, 11:33 AM   #1259
PERRIN
NASIOC Manufacturer
Member#: 6776
Boxer112: Thanks for asking. Several things have changed in the past several years. one of which is more distance between the bumper skin and tip, longer tip, resonator and also heat shielding included with each system (this was VERY recent.) On race systems that routinely spend a lot of time on the dyno an extreme amount of heat can build up in the rear of the vehicle (this occurs on all systems not just PERRIN) and the use of the heat shielding prevents damage to the bumper in this situation.
The dual tube allows much higher flow vs. a std. 3" system. It also reduces noise emissions as well. This will outflow by 40% over a std. 3" tube.
The TMIC on the STi will work with a 20G.
Thanks again for asking.
rebos123: I just stepped into the office and will get VM shortly. Did you leave it on mine or Jeff's? Either way we will get back in touch ASAP!. Thanks for your patience.
Adam
PERRIN Performance
Old 08-14-2006, 12:48 PM   #1260
bluekn8286
Member#: 79024
2004 Subaru WRX
I had a quick question, I purcahsed a perrin dual-tip peformance cat-back exhaust for my WRX, I was wondering why on some days the exhaust seems loud (its not a bad loud; its exactly how I would want it to sound), but on other days the exhaust would be pretty quite. I understand at WOT its going to be louder and it depends on the way that you drive the car, but I have tested it at similar throttle response levels on similar days and I would still notice a difference. I was wondering if this might be normal and I am just being paranoid or its abnormal and I need to worry, please help me out.
bluekn8286 is offline   Reply With Quote
Old 08-14-2006, 08:33 PM   #1261
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
adam, thanks for ur response.. once situated in my new location. i will be ordering a new TBE.. thanks
Old 08-14-2006, 10:14 PM   #1262
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
How do Perrin fuel rails for a wrx fit with the 30r kit? Has anyone tested this yet?
Token-Negro is offline   Reply With Quote
Old 08-15-2006, 01:14 PM   #1263
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
could your car be pulling timing sometimes
IDK just a thought...
gcm05 is offline   Reply With Quote
Old 08-15-2006, 01:49 PM   #1264
PERRIN
NASIOC Manufacturer
Member#: 6776
Boxer112: Thank you! Hope to hear from you soon!
bluekn8286: I will ask Jeff and get back to you. I can't think of anything taht would do that though.
Token-Negro: Again, I will ask Jeff if there is any interference, but I do not believe there is any issue. Thanks for asking!
Talk to you all soon!
Adam
PERRIN Performance
Old 08-15-2006, 07:17 PM   #1265
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
i am running the dual tube on my 05 wagon, cattless and it is pretty damn loud. But sounds meaner than any other exhaust by far!!!!!!!!!!! It rules...
gingertooth is offline   Reply With Quote
Old 08-15-2006, 07:33 PM   #1266
MydogBob
Member#: 123137
Hey Adam
I still have the Perrin ant-lift kit that clunks and grinds when I have to brake. Any fix. Hasn't killed me, so no hurry I guess. ..
Cheers
MydogBob is offline   Reply With Quote
Old 08-18-2006, 11:20 AM   #1267
burnin4
Member#: 59764
10 sec STi
10 sec Z06
Will the Perrin EL Headers be compatible with my Ultimate Racing externally gated uppipe/rotated mount? thanks!
burnin4 is offline   Reply With Quote
Old 08-18-2006, 01:18 PM   #1268
PERRINJeff
NASIOC Manufacturer
Member#: 74110
gingertooth,
Catless makes most systems pretty loud. My Dual Tube on my catless STI is loud, but not farty loud, or as loud as many others out there. Around SEMA time you will see some new changes to what we offer.
MtdogBob,
Call us and we can give you some pointers, it might just need regrease. We have had other customers call with these problems and when they are sent back they are completely dry. We can send you a zirc fitting to install, which is what will be on the newest version of the PSRS.
burnin4,
Yes it will work just fine! Should have some very solid data on an 35R setup in the next week or so. So we will have a stage 2 STI before and after and a 35R. sh
PERRINJeff is offline   Reply With Quote
Old 08-18-2006, 08:53 PM   #1269
littledrummerboy
Member#: 94408
2006 WRX Stg. 2+
World Rally Blue
Originally Posted by PERRINJeff
gingertooth,
are you making changes to the dual-tube exhaust already?! i hope not cuz i just got mine!... you're giving me some buyer's remorse! heheh...
yeah, i've yet to install it (waiting for my catted dp and AP), but the build quality looks excellent
littledrummerboy is offline   Reply With Quote
Old 08-19-2006, 10:30 PM   #1270
wrxprowler
Member#: 101493
2004 Silver WRX
So I took the grinder to my perrin endlinks so that I could actually install them with my perrin rear sway bar... you guys already told us that this is normal for them to fit incorrectly.
So new problem. Now the endlinks are making popping noises whenever I take corners. Is there a fix for this? Or is it normal for your car to make terrible noises too?
wrxprowler is offline   Reply With Quote
Old 08-20-2006, 01:49 PM   #1271
bikefreax
Member#: 110726
2005 WRX Wagon
San Remo Red
Good ol' perrin stuff. It's funny you have to grind "their" swaybar to fit "their" endlinks with out rubbing. I have heard the same issues with popping about their endlinks. Most people had to send them back for then to work on them. Have you called them yet?
bikefreax is offline   Reply With Quote
Old 08-21-2006, 12:44 AM   #1272
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
i had the popping issue when i got my new rear endlinks. I sent them back 3 effing times before they finally got it right. idiots! They didn't beleive me and probably didn't even fix them, but told me they did. but they were loud as hell until i got them back for the 3rd time. now they have been quiet ever since. but then again you probably shouldn't be putting them to a grinder either!
Old 08-21-2006, 01:14 AM   #1273
gcm05
Member#: 105948
why don't you guys just go with cobb for all your sway bar and end-link needs?
Old 08-21-2006, 11:36 AM   #1274
ProdriveRex
Member#: 53921
2011 STI Sedan- DGM
2006 E90 325- TSM
Just installed Invidia Catless DP with 3inch dual tip Perrin exhaust..... OMG. its sooo loud. and Raspy too.... sounds like Harleys... actually Louder
its that how it suppose to be???
ProdriveRex is offline   Reply With Quote
Old 08-21-2006, 01:12 PM   #1275
SW00P_G
Member#: 5591
EJ257 Gt35r
What would it take to get another copy of the FMIC install instructions. Not sure what I did with mine.
SW00P_G is offline   Reply With Quote
PERRIN™ Q&A thread PART TWO 2.5L PERRIN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1136 09-07-2012 03:15 PM
Snow Performance Q&A Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 21 10-13-2009 08:22 AM
Official PERRIN BOV Thread PERRINJeff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 57 07-16-2006 11:36 PM
SBR INC. Q&A thread Built Industries Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 348 10-24-2005 01:23 AM
