Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-04-2012, 10:03 AM   #1851
Wrx STI 504
Member#: 235470
2005 Wrx STI
Have a 3076, interested in a turbo blanket. What turbine housing does it have. T3 or t4
Wrx STI 504 is offline   Reply With Quote
Old 05-04-2012, 11:06 AM   #1852
PERRIN_Chris
Member#: 186665
2014 BRZ
All of our turbo kits are T3, thanks!
PERRIN_Chris is offline   Reply With Quote
Old 05-04-2012, 11:23 AM   #1853
Wrx STI 504
Member#: 235470
2005 Wrx STI
Thanx
Old 05-12-2012, 07:58 PM   #1854
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i have an 08 wrx with a vf52 swap. i just tried to put the spacer you sent me on my perrin tmic. its the one for the newer wrxs that spaces the tmic higher away from the slave cylinder. that thing is useless! its too high. and now one of my vf52 threaded holes are partially stripped. did you think maybe sending out longer bolts for the spacer? now i have to bolt and nut one of my turbo bolt holes. im done with your overpriced products!
424wrx is offline   Reply With Quote
Old 05-14-2012, 11:15 AM   #1855
PERRIN_Chris
Member#: 186665
2014 BRZ
424, sending PM.
Old 05-14-2012, 11:41 PM   #1856
italy wrx
Member#: 36450
2003 WRX
My Perrin down pipe has cracked twice at the transmission bracket. Is this a weak point? It cracks at the weld.. I'm considering cutting the bracket off..
italy wrx is offline   Reply With Quote
Old 05-15-2012, 11:03 AM   #1857
PERRIN_Chris
Member#: 186665
2014 BRZ
Italy, It's not a normal stress point. Make sure that the transmission bracket isn't being forced. When it's installed, it should be mounted on the turbo loose, and it should slide into the transmission bracket easily by pushing up on the downpipe. Then tighten down the downpipe on the turbo, then transmission bracket, then to the catback.
Old 10-27-2013, 11:59 AM   #1858
GVR4 420
Member#: 105450
2005 Forester XT
Seems its been a while since a question was asked but I'll revive it. Deals with installing a Perrin inlet in a 05' forester xt, with the rerouting of the pcv and teeing it into the tmic line...can I just keep that sensor plugged in and attached as it is and just cap that matching spot on the perrin unit?
GVR4 420 is offline   Reply With Quote
Old 10-27-2013, 04:47 PM   #1859
GVR4 420
Member#: 105450
2005 Forester XT
A little more searching answered my question...tee into the tmic breather tube and attach other end to PVC in block, then just cap off that port on the inlet
Old 10-28-2013, 03:48 PM   #1860
PERRIN_Mladen
Member#: 339582
2014 Limited BRZ
CBS
Glad we got you taken care of
PERRIN_Mladen is offline   Reply With Quote
Old 10-28-2013, 04:35 PM   #1861
stimania
Member#: 233957
2012 STI Hatch
What size T-clamps come with the 08+ cold air intake? Want to freshen them up.
stimania is offline   Reply With Quote
Old 10-30-2013, 12:01 AM   #1862
lschluter10
Member#: 372291
2010 WRX Sedan
WR Blue
Post
Is there anywhere at all online that I can get a Perrin downpipe? I just got my CatBack from the Perrin site and ordered a downpipe from another site but they were out of stock. Is this what any listings for the downpipe are going to end up as?
lschluter10 is offline   Reply With Quote
Old 10-30-2013, 12:20 AM   #1863
Wrxstage2yukon
Member#: 371966
WOW! Lots of stuff on here and many good points, some of you complaining to much, if you know anything about aftermarket it's that it's always fight to make it fit!
I have to give it to PERRIN under the hood of my 03 bugeye is PERRIN RIGHT OUT! And not one part came without instructions or the hardware, any questions over the phone answered and emails did take a few days but hey there's a lot of us emailing them and I betcha it's maybe only a couple people at the computer writing back, give them a break
For you PERRIN
I would love to see a red air filter for the Intakes, diff covers ( I swear I saw one but called and didn't make it, I assume I'm mistaken of someone made it and hacked something up, anyways would be awesome, your short throw bushings I have to say I hated I had them in for no more than 3 days and put the stock back in, there still sitting In my tool box for some reason.
MAKE A TOP MOUNT!!!!!! Make gauge clusters, inside fabric panels, diff cover, sti spoiler speacil with a Perrin badge, side mirros carbon fibre but PERRIN! Radiator!!!! Man you guys should pay me for these ideas lol, your market would stretch a lot more to of you found a more economical way to produce parts and supply a cheaper price, mishi moto, brans like them make awesome pArts and blow you guys outta the wAter in that department
Wrxstage2yukon is offline   Reply With Quote
Old 10-30-2013, 12:36 PM   #1864
PERRIN_Mladen
Member#: 339582
2014 Limited BRZ
CBS
The clamps that are included, are 312 T-Bolt clamps.
I'm honestly not sure as I am unable to check their stock. I know RallySport Direct had a few of the 02-07, but I am unsure if they have any of the 08+ downpipes.
I would suggest giving them a call to see if they maybe have one laying around still.
Old 10-30-2013, 12:52 PM   #1865
PERRIN_Mladen
Member#: 339582
2014 Limited BRZ
CBS
For you PERRIN
Thank you very much for the compliments and ideas!
We love to hear feedback from our customers to help us make better parts. There are millions of different parts that we can make, but we choose to focus on a select few and master them! While we do have some parts that others make and make cheaper, that is not our way to make parts. If we did, everything would come from China, which that is by far NOT the case.
So, when you see our WRX oil cooler, it will not be the cheapest, but it will be pretty dang nice and backed up with data and instructions! Not to mention, it will also come with all of the normal support we provide for all of our products!
Old 10-30-2013, 04:27 PM   #1866
lschluter10
Member#: 372291
2010 WRX Sedan
WR Blue
Post
Ya on their website they only have the 02-07 I might email them and see but I doubt it.
Old 10-31-2013, 12:59 PM   #1867
PERRIN_Mladen
Member#: 339582
2014 Limited BRZ
CBS
Yeah, I have a feeling finding one new is going to be quite difficult.
Wish I knew of anyone that had one so we could help you out.
Old 11-20-2013, 08:01 PM   #1868
lschluter10
Member#: 372291
2010 WRX Sedan
WR Blue
Post
Couple things... Wondering if you guys have any of the oil for the air filter that comes with the cold air intake.
Also wondering how much of a change in sound a cold air intake should produce because I recently installed one with a map, Stage 2, from Perrin. I'm pretty sure I installed it correctly as I have had no drastic drop in boost but around 8-10 pounds of boost the turbo sounds rough and sometimes like a scream. Higher up from 12-17 pounds the turbo sounds good again. There isn't any noticeable smell of burning turbo either. Maybe I'm just not used to the new sound
Old 11-21-2013, 12:54 PM   #1869
PERRIN_Chris
Member#: 186665
2014 BRZ
Lschluter10, We don't sell the cleaner and oil for the PERRIN foam filters, but you may find them locally or online. We use the Unifilter foam filter cleaner, which comes with oil and cleaner.
The PERRIN intake will add some sound, and it will vary depending on load. It is a unique sound, since the foam filter is really free flowing. Maybe a video will help?
Old 12-05-2013, 09:14 PM   #1870
wrxaussie831
Member#: 279113
2011 WRX Sedan
Dark Gray Metallic
Just bought a perrin bov for my 2011 wrx and I'm not sure how to set the adjustment cap and flow control screw? Any help?
wrxaussie831 is offline   Reply With Quote
Old 12-06-2013, 12:04 PM   #1871
PERRIN_Chris
Member#: 186665
2014 BRZ
Hello, here's a link to our instructions which will help.
You're going to want to have the nut on the setscrew to be halfway up the threads, and the cap set to be flush with the 5th line on the body of the BOV. Those are the factory settings, which will work for just about every car out there. Hope this helps, thanks!
Old 03-13-2014, 10:23 PM   #1872
Mangledmess1
Member#: 286858
2002 Impreza WRX
Will the Cobb post MAF hose fit the Perrin turbo inlet hose? 2002 WRX. I purchased them both because they fit oem parts. They are close but the cobb hose is larger than the perrin.
Mangledmess1 is offline   Reply With Quote
Old 03-14-2014, 11:04 AM   #1873
PERRIN_Chris
Member#: 186665
2014 BRZ
Mangledmess1, they should fit fine, the PERRIN inlet has a 2.75" OD outlet coupler, since the COBB tube is silicone, it should be able to sinch down on the metal coupler even if it's a little bigger. Thanks!
Old 03-16-2014, 02:16 PM   #1874
rexwagen
Member#: 244293
2003 wrx wagon
black
I just picked up a new Perrin PSP-EXT-205F downpipe (front section 2002-2005 WRX) thinking I could order the rear cat section too (PSP-EXT-205R), but several shops took my order only to refund my cash since it's been discontinued. No one seems to be letting go of the rear section. Is there a chance there's a PSP-EXT-205R in a warehouse on a shelf somewhere?
rexwagen is offline   Reply With Quote
Old 03-17-2014, 11:06 AM   #1875
PERRIN_Chris
Member#: 186665
2014 BRZ
rexwagon,
I'm sorry, our downpipes have been discontinued for a while now, we don't have any in stock, I'm not sure where you will be able to pick one up, sorry!
PERRIN™ Q&A thread PART TWO 2.5L PERRIN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1136 09-07-2012 03:15 PM
Snow Performance Q&A Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 21 10-13-2009 08:22 AM
Official PERRIN BOV Thread PERRINJeff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 57 07-16-2006 11:36 PM
SBR INC. Q&A thread Built Industries Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 348 10-24-2005 01:23 AM
