Old 11-11-2004, 04:23 PM   #1
scrt8gntman
Member#: 55356
02 WRX Wagon
Default Pitch Circle Diameter
Does anyone know what the PCD (pitch circle diameter) of an 02 WRX Wagon would be. I am guessing it is 5x100 48mm offset. Is that correct?
scrt8gntman is offline   Reply With Quote
Old 11-11-2004, 06:19 PM   #2
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Actually the stock rims are 53mm offset, but you got the 5x100 part right.
khail19 is offline   Reply With Quote
Old 11-12-2004, 01:20 AM   #3
bheinz57
Member#: 37870
2012 ISM WRX
'07 FXT Sports
Doesn't PCD refer to the center bore of the rim? Like 56.1mm for Subies in general. I don't know, that's just what I thought. Brian
bheinz57 is offline   Reply With Quote
Old 11-12-2004, 08:30 AM   #4
Porter
Member#: 486
2004 Forester XT
bug spattered
PCD is the bolt pattern.
Hubcentric measurement is the center bore (56.xx mm).
Porter is offline   Reply With Quote
Any difference between stock 04 STi pitch mount and wrx pitch mount Serkan Brakes, Steering & Suspension 1 02-10-2010 08:45 AM
FS (OH): STi pitch stop, JDM STi pitch stop coolblue05 Engine/Power/Exhaust 10 11-21-2009 10:28 PM
Group-N Pitch Mount identical to '05 Pitch Mount? WolfPlayer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 10-07-2007 08:16 AM
DMS40 mounting bolt diameter and pitch jeffg Brakes, Steering & Suspension 1 01-16-2003 08:11 PM
Intake diameter vs throttle body diameter Kevin Thomas Normally Aspirated Powertrain 0 03-03-2002 07:46 PM
