Old 01-08-2005, 05:24 PM   #26
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Originally Posted by sidewayz
Im rocking H4 singles at a 6000k light...I blind people coming at me.. do I care?? nope. I can see. These lights are the best money I ever spent.
Please post the exact times and locations when/where you will be driving, so those of us in Tri-State can avoid you.
Old 01-09-2005, 05:43 PM   #27
JeffInMonterey
Member#: 71395
Thanks to all for the great information on the pitfalls of installing HID lamps as a retrofit. There is a great deal of hype on the web regarding bulb temp, light output, and color. If only my son would listen....
JeffInMonterey is offline   Reply With Quote
Old 01-09-2005, 06:05 PM   #28
dithergizzard
Member#: 58232
Do you not realize that oncoming cars whose drivers can't see anything because of your lights also pose a safety hazard to you, not only everyone else around you? Or does that not bother you either?
I can see.
You can see, yes...but much less than you would with properly installed HIDs.
Only if you enjoy terrible beam pattern, reduced light output, and blinding people (which you seem to).
IMHO, you chose the wrong thread to post your comments in, sidewayz.
dithergizzard is offline   Reply With Quote
Old 01-09-2005, 08:00 PM   #29
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I can see.
You can also see a possible head-on collision with your car when the blinded drivers swerve to your lane.
Hank3 is offline   Reply With Quote
Old 01-28-2005, 02:11 PM   #30
YellowDubRX
Member#: 39172
Anybody know the Kelvin degrees on the 05 STi and if anybody has tried getting a higher K bulb.
YellowDubRX is offline   Reply With Quote
Old 01-28-2005, 02:37 PM   #31
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's probably already mentioned in this thread someplace, but anyway-
ALL OEM HIDs are 4100K, this of course includes the STi. Changing the OEM D2R bulbs for aftermarket ones with a higher temp rating will reduce the amount of usable light output while increasing glare and is counterproductive.
Old 01-28-2005, 04:33 PM   #32
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
great posts. thanks
Rapid_Roo is offline   Reply With Quote
Old 01-28-2005, 09:53 PM   #33
jlogan9
Member#: 15511
What base type do the EDM STi lights (2002) use? I am having a hard time finding this information.
jlogan9 is offline   Reply With Quote
Old 01-29-2005, 12:05 AM   #34
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
EDM STi lights are H1 low beams. Not hard to find at all, if you have them just look at the bulb. Also widely posted here and elsewhere.
Old 01-29-2005, 12:22 AM   #35
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
great info and links.....thx
Bishop is offline   Reply With Quote
Old 02-01-2005, 07:20 PM   #36
rockwvu
Member#: 57101
So if i have a MY04 WRX, and I buy a set of STi headlamps, do i need anything else? will i still have high/low? If i go aftermarket, will i still have high/low beam? Thanks.
HOw much am i looking at pricewise to get the STi parts i need to work?
rockwvu is offline   Reply With Quote
Old 02-01-2005, 09:20 PM   #37
dithergizzard
Member#: 58232
If you buy OEM STI HID assemblies, you will still have high-/low-beam, except your lows will now be OEM reflector-based D2R HID. Anything aftermarket you do will not affect your high-beams unless you touch them; most of the modification we talk about here for MY04 is for the low-beams, as these are separate from the high-beams in the newer models. You will have to search for prices, but it's not cheap. Generally in excess of 1000 USD all together, AFAIK.
Old 03-01-2005, 12:20 AM   #38
veightkiller
Member#: 78967
2011 335i
so jdm headlights are not the way to go then.....i guess im just going to add 2 more driving lights for a better light-output
veightkiller is offline   Reply With Quote
Old 03-03-2005, 06:39 PM   #39
live_2race
Member#: 82199
02 WRX and S2000
Unhappy
I am reading this thread and wondering? What is the easiest way to hook up 04 JDM HIDs. I bought them thinking they would be pretty cool. I can't figure out what the easiest way is to wire them in. Maybe I could find out what kinda plugs I need, try and find them and then splice them into my wiring harness. To top it all all off, I am doing this to an 02 WRX. Has anyone done this or know of a site that has pictures and descriptions that can walk me through the process??? I don't want to ruin a $900 pair of JDM HIDs. Any help would be much appreciated.
live_2race is offline   Reply With Quote
Old 03-13-2005, 10:46 PM   #40
justbcuz
Member#: 81699
2003 wrx
black
02 subaru oem jdm sti hid, bought used one ballast is missing plug can i hard wire right to the tabs on the ballast? or how can i replace
justbcuz is offline   Reply With Quote
Old 03-17-2005, 02:08 AM   #41
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
You could replace them with something that won't spray HID into oncoming traffic
Old 03-31-2005, 01:16 AM   #42
Petew
Member#: 37026
MY01 WRX
WRC Blue
anyone got some pics of 01/02 sti lights vs 01/02 sti HID's?
Petew is offline   Reply With Quote
Old 04-15-2005, 01:40 AM   #43
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
I have an issue with this FAQ. One of your last pieces of advice is to install relays. This doesn't make any sense. All Subaru headlights are already actuated by relays.
wagman01 is offline   Reply With Quote
Old 04-15-2005, 08:09 AM   #44
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, but-
The factory setup has relays for the common headlight power on each side. The ground side is switched, w/o relays. HID's, due to their high startup current, can't be plugged directly into the OEM wiring. While it is possible to use the existing power circuit/relays with direct (chassis or battery) grounding for the HID ballasts, another option is to use battery power through external relays switched by the headlight circuit. Either way works if done properly.
Old 04-17-2005, 12:37 AM   #45
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
So, will there be an any gain adding neg side relays with stock lights?
Has anyone measured voltage drop on a WRX with stock wiring / lights?
realwomble is offline   Reply With Quote
Old 04-17-2005, 01:50 AM   #46
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not really HID related, but the answer is yes. I've measured the ground-side drop at around 1.5V or so which is enough to affect brightness. However with the stock lights it may not make that much difference given the limitations of the 9007 bulb design. You can certainly go ahead and try it.
Old 04-26-2005, 03:37 AM   #47
V REX
Member#: 11102
02 WRX,05STi sold
B5 WB Nogaro S4
What brand bulbs are in the USDM STi? Just wondering if swapping to another brand of OEM D2R bulbs will change the color output. I've heard the Osram is a bit diff then Phillips and so on.
Also what would happen if you put OEM D2S bulbs in reflector housings? I think they would put out more light but would there be a bad glare? I have some spare bulbs so I was thinking I might try them and see what happens.
V REX is offline   Reply With Quote
Old 04-26-2005, 08:02 AM   #48
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't know what brand bulbs are used but it's probably either Osram or Philips. It shouldn't matter, all OEM HIDs are 4100-4300K. Using alternate bulbs with a higher color temperature will only reduce the usable light output and won't improve performance.
Don't use D2S bulbs, as you are already aware they will produce more glare. The D2R bulbs have an anti-glare mask printed on the bulb, the D2S bulbs do not.
Old 05-04-2005, 08:19 PM   #49
0260B4U
Member#: 33249
2003 WRX
white
just got a CATZ kit, but heard they no longer have US dealer? Is that true? Kinds OT, but i dont even know where to start.....
0260B4U is offline   Reply With Quote
Old 05-04-2005, 11:29 PM   #50
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
There are no more aftermarket HID dealers in the US as it is illegal to install them.
Well, there might be some, but none from major MFG.'s, as there's no money in it.
tooocool49723 is offline   Reply With Quote
AKIC FAQ Please read before starting new threads... Kiwi Fella Alaskan Impreza Club Forum -- AKIC 2 02-18-2011 09:24 PM
The Rules! Please Read Before Posting! SQUAD_907 AKIC Private Classifieds 1 01-10-2009 05:59 AM
Attention! Read before posting in any Scammer threads! Mulder Scammer Central 0 08-11-2008 08:03 PM
Welcome to the Subiesport Forum -- Read before posting! ricochet Grassroots Motorsports Magazine Forum 2 08-15-2006 09:37 PM
