Old 05-08-2005, 12:16 AM   #51
ASpec818
Member#: 37059
03 WRX
World Rally Blue
I'm having problem with my HID lights I installed into my edm's.the driver's side would fire up instantly when I turn on the lights, but my passenger side would only *sometimes* come on after like a minute or so. I was reading about the voltage drops and such on this thread, but then my HID kit from proxenon came with a seperate relay harness. I used that instead of directly connecting everything. All my connections are secure, properly grounded, and both ballasts and bulbs are fine (I checked by swapping and same results: driver's side comes on while passenger's does not). Also disconnected the DRL module already. Anyone have any suggestions? Maybe a wrong connection somewhere?
ASpec818 is offline   Reply With Quote
Old 05-16-2005, 08:34 PM   #52
MannyBlah
Member#: 35540
2003 WRX
Blue Pearl
good stuff thanks
MannyBlah is offline   Reply With Quote
Old 07-12-2005, 10:31 PM   #53
Squiden
Member#: 85634
Default Flickering Passenger HID
I'm having a similiar issue with some OEM HID's I installed in a '04 WRX, where the driver side comes on fine, but the passenger side flickers and never activates (I've never left it on for more than 10 seconds since I don't want to burn out the ballast). I've disabled the DRLs, and have ground straight back to the battery. I know the ballast is good, because I can plug the passenger side into the driver side and it works great. In my troubleshooting, I noted that if I leave the connector to the small upper bulb (between the low and high beams) unplugged, the passenger side won't do anything, but the driver side works fine! Any thoughts as to what might be going on?
Squiden is offline   Reply With Quote
Old 07-12-2005, 10:55 PM   #54
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Did you disconnect the DRL under the hood or behind the glove box? The module in the engine bay is a dropping resistor, and it does not fully disable the DRL system. The plug next to the glove box is the main control module.
Here:
Hank3 is offline   Reply With Quote
Old 07-13-2005, 01:44 AM   #55
ASpec818
Member#: 37059
03 WRX
World Rally Blue
for me, my problem was the passenger side relay. my relay burned out so i replaced it and it works fine now.
Old 07-13-2005, 08:53 AM   #56
Squiden
Member#: 85634
Default HID Troubleshooting.
I did remove the DRL from behind the glovebox
Old 07-13-2005, 08:54 AM   #57
Squiden
Member#: 85634
I did remove the DRL from behind the glovebox.
Aspec818 - Which relay did you have to replace? I thought both lights were driven off the same relay?
Thanks!
Old 07-28-2005, 01:39 AM   #58
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
what about converting jdm halogen 02 sti headlights to philips h7 d2s hid, is it do able?
bren wrx is offline   Reply With Quote
Old 07-28-2005, 09:26 AM   #59
Hank3
Member#: 16157
'03 Mazda P5 <><
You would have to retrofit them to the back of the JDM light housing. It's doable I'm sure, but it'll take some fabrictaing on your part. Or you can send them in to some of the retrofitters that are out there. It'll cost you a pretty penny though
Old 08-13-2005, 11:39 AM   #60
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Peaty is offline   Reply With Quote
Old 08-13-2005, 05:53 PM   #61
Hank3
Member#: 16157
'03 Mazda P5 <><
Great info as always Peaty - thanks for linking us
Old 09-16-2005, 04:04 AM   #62
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
sooooo, the proper way for me to have HIDs in my bugeye is to get a set of JDM STi lights and then a set of EDM lights and make a hybrid. Thats expensive I have HIDs in my stock housings and I'll be te first one to tell you they suck balls. Anyone wanna buy them
spoolinsuby is offline   Reply With Quote
Old 09-29-2005, 04:53 PM   #63
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Is it possible to just get a set of EDM's and then stick an hid bulb (H1 type) in and be done with it, or are there other mods that need to be done to the EDM projector? I've got a set of EDM's from Suby Dude and just wanted to know what all I would need to do to convert them to HID.
subydude is online now   Reply With Quote
Old 09-29-2005, 04:55 PM   #64
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
You really need to change your username
You CAN just stick H1 HID's in the EDM's but they are not designed for HID. They will look cool, but it won't be as good as having a good halogen bulb, or as good as projectors designed for HID (for instance, OEM Audi S4 projectors or something).
john
Old 09-29-2005, 04:59 PM   #65
subydude
Member#: 80649
Yeah, I put in that name as a joke a while ago and about fell out of my chair when it went through:P
So in other words I could put an HID bulb in, but it wouldn't be as good as a good Halogen bulb. So there really isn't anyway to do a good conversion to HID for an EDM projector without cutting it up?
Old 09-29-2005, 11:15 PM   #66
Hank3
Member#: 16157
'03 Mazda P5 <><
True HID bulbs come in D2S (for projector light setups) and D2R (for reflector light setups) types. In order to get an HID setup for your EDMs, you'll have to get an adapter ring to change the bulb from D2S to H1. Or you can just buy an HID kit with D2S bulbs and modify your projector unit so that it will house the bulb properly. Instructions on how to do this can be found on the HID forums:
http://www.hidplanet.com/forums/
You will get optimal light output if you were to run an HID kit in projector units that's made for HIDs. Your current EDMs were made for halogen bulbs, and although going with an HID kit "should" be better light output (although it may produce glare due to the optics) than going with a halogen bulb, you will still not be at optimal level without projector units that were made for HID bulbs.
Old 11-09-2005, 12:42 PM   #67
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
These are for:
2002 JDM HID Sti factory ballasts
Wiring into 2002 US wrx
Would the ground be the Large Black/Small Orange combo, or the Large Blue/Small Brown combo? The Large gauge black wire used to be a part of the bulkhead harness. the Small Orange wire on the other end goes to the ballast.
I've already done quite a bit of searching and reading, but no one seems to mention which wire is the ground on a real JDM HID ballast.
The other side looks like this w/ the Ballast:
Logic would say assume the large black wires are the grounds and assume the large blue and large red are the power wires. But with expensive ballasts assumptions are never good
This thread was of good use as well:
http://forums.nasioc.com/forums/show...t=Daniel+Stern
Thanks in advance
SC
IA Performance is offline   Reply With Quote
Old 11-10-2005, 01:49 AM   #68
IA Performance
Member#: 25194
Dark Gray
ok, I was able to cross reference off of another JDM HID unit which had red and black wires coming out of it instead of this color combo seen above. Black is ground, the Blue and Red/Blue are both Power.
Lights are up and working well thanks to some info taken from here, as well as some light wiring alterations needed for our particular customers car.
Mulder- please note polarity reference incase others need the info down the road.
SC
Old 11-16-2005, 09:18 PM   #69
SanRemoRex
Member#: 62298
2008 DGM STi
MkII MR2 Turbo project
An option just popped into my head earlier today. Having already opened my headlights once for clearing, I made some observations. Would it be possible to simply swap in the single reflector piece from STi headlights into a regular '04 WRX housing, then utilize one of the McCllough H1 kits? Seems like the light source placement with respect to the reflector and the output couldn't be that significantly different. This way you could salvage reflectors out of wrecked headlights, and save quite a lot of cash, but still be doing much better than just throwing the kit into stock reflectors. Toss on a set of used levelling motors (likely salvaged from the same lights) and your in business, for still quite a bit cheaper than even a used pair of STi lights. Can anyone (pardon the pun) enlighten me? I've never had a chance to look at some open STi units.
SanRemoRex is offline   Reply With Quote
Old 12-05-2005, 10:38 PM   #70
MSo
Member#: 5008
2002 /06 STi GGA
SRP
Originally Posted by Mulder
JDM HIDs (the OEM ones) use standard D2S bulbs.
The US STi HIDs use D2R bulbs (this info is in the owners manual).
Hi, my Question is :
What is the difference between them? Possible to use D2R in Morettes
Thanks Mike
MSo is offline   Reply With Quote
Old 12-05-2005, 10:45 PM   #71
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Thanks Mike
The difference is that D2R bulbs are intended for use in reflector housings and have a black mask printed on the glass to minimize glare. They are otherwise physically and electrically identical to D2S, so you can use them in projectors, however the light output will be reduced somewhat. You could scrape the mask off (gently so as not to break the glass) and effectively turn them into D2S bulbs.
Old 12-09-2005, 04:50 PM   #72
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
how exactly are projector housings different in terms of whether or not they are made for HIDs or halogens?
KAX is offline   Reply With Quote
Old 12-09-2005, 05:13 PM   #73
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The dispersion properties of the light from HID bulbs is different from halogen bulbs, because the light is generated by different means. In addition the amount of light emitted by the HID bulb is much greater. Therefore the optical design of the housing must be different to properly accomodate the type of bulb being used.
Old 12-09-2005, 06:14 PM   #74
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
I understand why they are different. But what is different about them? How are they made, compared to that of a halogen housing. Basically the point of my question is to see if the housing could be modified to give optimum output for an HID retrofit.
Old 12-09-2005, 06:39 PM   #75
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You would have to consult the lighting manufacturers to get the technical specs on the different housings. I don't think it's something you could achieve on your own through modification. If you want to see for yourself how reflector housings are different, try and get the opportunity to compare an 04-05 STi side-by-side with an 04-05 WRX or RS. Look carefully at the divided sections of the reflector, you'll see that they are sized differently on the two types of housing even though at first glance they appear identical.
AKIC FAQ Please read before starting new threads... Kiwi Fella Alaskan Impreza Club Forum -- AKIC 2 02-18-2011 08:24 PM
The Rules! Please Read Before Posting! SQUAD_907 AKIC Private Classifieds 1 01-10-2009 04:59 AM
Attention! Read before posting in any Scammer threads! Mulder Scammer Central 0 08-11-2008 07:03 PM
Welcome to the Subiesport Forum -- Read before posting! ricochet Grassroots Motorsports Magazine Forum 2 08-15-2006 08:37 PM
