Old 11-11-2004, 11:59 PM   #1
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Default STI NGK Colder plug numbers from SEMA.
Last edited by Wombat North; 03-18-2005 at 08:54 PM. Reason: NGK stock number had changed
Wombat North is offline   Reply With Quote
Old 11-12-2004, 11:21 AM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
I think those plugs come gapped for NA applications... (0.044")
Edit: There's even contradicting info on NGK's site... if you look up the spark plug for a 2005 Legacy Turbo, they give you "LFR6AIX-11". The "11" means a 1.1mm gap (~0.044"), but they show a gap of 0.030".
http://www.ngksparkplugs.com/apps/ca...engineid=36236
On the NGK site, looking up the spark plug info for a 2004 WRX, STi, or Forester XT is all screwed up.
x99percent is offline   Reply With Quote
Old 11-12-2004, 11:58 AM   #3
Wombat North
Member#: 21267
STI, EWG 8cm Green
FWIW
Info on STI plugs was taken out of the new catalog he had with him. Catalogs and Websites can be wrong as others produce them so I gave out the techs direct line for anyone who wishes to confirm the #'s.
Here's the toll free also
887 473 6767 press option 2
Old 11-12-2004, 01:13 PM   #4
x99percent
Member#: 27108
2004 STi
2004 A4
I looked up LFR7AIX on sparkplugs.com... that's where I saw the gap of 0.044".
Then I went to NGK's site and got nowhere fast.
... [time passes]
I placed a call to sparkplugs.com. They pulled one off the shelf and verified that their online catalog is incorrect (the catalog showed 0.044", link). The gap actually measured 0.032"-0.033".
Ordering a set now!
Old 11-12-2004, 01:20 PM   #5
titsataki
Member#: 4402
... [time passes]
Ordering a set now!
So those are the colder plugs for the STi as well? (05 STi that is)
cheers
Nick
titsataki is offline   Reply With Quote
Old 11-12-2004, 01:32 PM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
I am unaware of any changes to the motor.
Old 11-12-2004, 02:16 PM   #7
titsataki
Member#: 4402
did you order them on line?
sparkplugs.com does not list plugs for the STi?
Never mind it does not list the 05 MY.
the ones you are getting are those right?
LFR6AIX-11
Thanks
Nick
Old 11-12-2004, 02:22 PM   #8
x99percent
Member#: 27108
2004 STi
2004 A4
LFR7AIX = one range colder, w/ proper gap.
Old 04-22-2005, 11:42 PM   #9
2phless
Member#: 69343
1998 TransAm cnvrtbl
My set came today! Sparkplugs.com
free sticker too!
2phless is offline   Reply With Quote
Old 04-23-2005, 01:19 PM   #10
Irishman
Member#: 29933
2004 STI
Silver/Silver
What benifit is there to run colder plugs? Is it more for modified cars?
Irishman is offline   Reply With Quote
Old 04-23-2005, 08:44 PM   #11
MattSTi
Member#: 54885
2004 PSM STi
2006 Mazda MX-5 Race Car
These plugs (LFR7AIX #2309) are properly gapped for the STi from NGK. I just received my set from Topspeed, who claimed that they were properly gapped, and I called NGK tech for confirmation. According to the tech, they come gapped at .0030 from the factory. I'm definitely going to check it out for myself before putting them in my car.
Irishman- I'm not an expert, but colder plugs are supposed to increase the cars knock threshold, thus adding a bit of safety (or headroom to tune). I bought them because I would like my car's tune (UTEC, TBE, Intake, FMIC) to be as safe as possible. If you search there should be some good threads with more in depth discussion on the topic.
-Matt
MattSTi is offline   Reply With Quote
Old 04-23-2005, 09:48 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 04-24-2005, 12:29 AM   #13
Irishman
Member#: 29933
2004 STI
Silver/Silver
Great info on that website. Thanks.
Old 07-27-2005, 01:56 AM   #14
_sti_05
Member#: 72313
16 STi
-Matt
These are the NGK IX iridium?
saw this info on sparkplugs.com
_sti_05 is offline   Reply With Quote
Old 08-11-2005, 05:25 PM   #15
Inprogress
Member#: 65166
2008 EVO X
do the LFR7AIX need to be gapped? On my packing slip for my plugs that i recieved today it says not to gap as i will break the center electrode if i do...
Inprogress is offline   Reply With Quote
Old 09-24-2006, 10:02 AM   #16
Steveee
Member#: 103940
Curious as well..
Steveee is offline   Reply With Quote
Old 09-24-2006, 10:29 AM   #17
x99percent
Member#: 27108
2004 STi
2004 A4
NEVER gap fine-tip plugs by prying against the tip.
If you have a proper gapping tool, you can set the gap without touching the tip at all. Use feeler gauges or something similar to measure the gap.
Old 09-26-2006, 09:37 PM   #18
MikeGWRX
Member#: 93654
Do these also fit a WRX? I have an extra set of these lying around, if anybody wants them cheaper?
MikeGWRX is offline   Reply With Quote
Old 09-27-2006, 11:46 AM   #19
x99percent
Member#: 27108
2004 STi
2004 A4
STi "long reach" plugs are very different than WRX plugs.
Old 09-27-2006, 12:10 PM   #20
gtx510
Member#: 66118
ALL NGK plugs come pre-gapped. That's what the "-xx" at the end means.
-11 = 1.1mm (0.043-0.044") gap
If there's nothing at the end then it's the standard 0.8mm gap.
http://www.sparkplugs.com/results_cross.asp?pid=LFR7AIX
The LFR7AIX has a 0.8mm or ~0.031-0.032" gap.
And the 2.5L and 3.0L use longer reach plugs like the STi?
http://www.sparkplugs.com/results_fi...pid=LFR6AIX-11
The WRX uses shorter reach plugs like a Miata or BMW would use
gtx510 is offline   Reply With Quote
Old 04-20-2007, 11:37 AM   #21
x99percent
Member#: 27108
2004 STi
2004 A4
Well, it looks like the NGK LFR7AIX plugs are now "obsolete", according to sparkplugs.com ...
A new part number is NGK ILFR7H ... these should last longer than the LFR7AIX, as they are in the same series as the stock plug (meant to last).
Old 10-02-2007, 06:22 PM   #22
AaronWRX
Member#: 7194
2011 997.2 Turbo
but you can still order the LFR7AIX for 8 dollars a plug there.
AaronWRX is offline   Reply With Quote
Old 12-03-2007, 10:32 PM   #23
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Anybody running with the NGK ILFR7H plugs? How are they holding up?
Beanboy is offline   Reply With Quote
Old 12-03-2007, 10:49 PM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
.......they are just like any of the other iridium plugs and should 'hold up' the same
Old 12-07-2007, 02:05 PM   #25
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
whatever you get, do NOT get the -11 plug, regardless what it says on ANY site. Confirmed with sparkplugs.com, which is a very helpful company by the way.
The person I talked to confirmed the site(s) are wrong, and that all LFR7AIX are the same as the "new" ILFR7H. which is $3 more by the way
Holding a LFR6AIX (stock heat range) and a ILFR7H side by side, they
are identical.
aboothman is offline   Reply With Quote
FS (FL) STi red TB - IC coupler & colder NGK Iridium plugs damianblalack Engine/Power/Exhaust 4 08-29-2008 09:21 AM
What should I gap 07 STI NGK 1 heat range colder plugs to?? Destroy Service & Maintenance 4 03-17-2008 03:36 PM
NGK Copper 1 Step Colder Spark Plug Number Needed Hayaboosted Service & Maintenance 4 03-15-2008 03:03 PM
f/s jdm sti ngk spark plugs boost23 SCIC Private Classifieds 10 01-14-2008 12:07 PM
FS: Austin, ACT Streetlite Flywheel (new)/NGK step colder plugs/STi motor mounts livnlegacy TXIC Private Classifieds 10 12-07-2006 02:24 PM
