Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 11-12-2004, 03:56 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default NEW!!!! GT SPEC 14 Point SubFrame Replacement Brace!!!!!!
This part is brand new just released by GT Spec. It is a 14 point underbrace set that allows you to remove the bulky factory subframe!!!!! This will save you 12.5 lbs on the front end and increase the rigidity of the chassis. It is a 3 piece set that is made up of 14 points. Here are some pictures.
The pictures above are of the first version of the brace. Some of the bars have been moved but the general design is the same. The bar that is covering the oil filter has been moved and will not cause issues when changing your oil.
We can get these to you for 659 Shipped!!
Let me know if you have any questions.
Ben
801.619.1779
parts@rallysportdirect.com
aim: rallysportdirect
www.rallysportdirect.com
RallySport Direct is offline
Old 11-12-2004, 05:07 PM   #2
BLACK02WAGON
Member Sales Rating: (4)
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
with these in place could you still run the plastic cover? I would be kind of concerned to run without it.
BLACK02WAGON is offline
Old 11-12-2004, 05:43 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
No the platic cover does need to be removed to install this part. You shouldn't run into any problems removing it from your vehicle.
Ben
801.619.1779
aim:rallysportdirect
Old 11-12-2004, 07:49 PM   #4
BlkSTi04
Member Sales Rating: (1)
Member#: 54410
Does this fit with the Anti-lift kits?
BlkSTi04 is offline
Old 11-12-2004, 07:51 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
It should but we are test fitting them this weekend. I will let you know on monday.
Ben
Old 11-12-2004, 07:52 PM   #6
JalopySiR
Member Sales Rating: (3)
Member#: 39378
2004 Carless
98' VFR800Fi/02' RC-51
Advantages of this over the Do-Luck unit, which costs about half, and retains the factory splashguard?
I'm not trying to be a prick, but I am in need of a new subframe, and am shopping around.
JalopySiR is offline
Old 11-12-2004, 08:02 PM   #7
BlkSTi04
Member#: 54410
Great. I have Perrin Positive Response kit. Waiting to hear back from you.
BlkSTi04 is offline
Old 11-13-2004, 12:14 PM   #8
dwx
Member Sales Rating: (5)
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Any chance of breaking up the kit into two pieces?
dwx is offline
Old 11-13-2004, 01:04 PM   #9
FLEMON
Member#: 64806
Does this piece have issues with the GT-Spec Gen 2 headers like the Do-luck..?
Can the Cusco lower arm barr be used with this brace?
FLEMON is offline
Old 11-13-2004, 01:08 PM   #10
ErikAnderson
Member Sales Rating: (9)
Member#: 26739
i wonder if this will clear my giant DNpreformance headers?
ErikAnderson is offline
Old 11-14-2004, 08:46 AM   #11
ttenneb
Member#: 30013
2003 wrx wagon
will this fit with the cusco v2 brace?
ttenneb is offline
Old 11-14-2004, 11:03 AM   #12
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
I take it there aren't any issues with the oil filter?
02R6 is offline
Old 11-14-2004, 03:12 PM   #13
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Any issues with fitting a skidplate? (i.e. rallyarmor skidplate)
Psydotek is offline
Old 11-15-2004, 04:06 PM   #14
RallySport Direct
Member#: 33174
We are Open Late!
There are a couple reasons why this is better then the do-luck.
1. This will clear most aftermarket manifolds. It has been fitted to a car with the GT spec Gen II manifold. And it works fine.
2. Availablitity - Do luck parts are hard to get ahold of. The GT Spec piece will be easier to get ahold of.
3 Rigidity - The doluck piece only has I belive 8 points. The Gt spec Piece has 14 points so it will be more rigid then the Doluck.
4 Price - The cheap price is the steel version. This will be heavier then the GT Spec. The aluminium one is more expensive but close to the same weight and still has less points.
02R6 - No problems with oil filter. The pictures are of the old design. You can see in the picture
ttenneb - It fits with the GT Spec Brace so it should fit with the cusco since they mount the same way.
Erik Anderson - I would not be able to tell you at this point. It depends on how much bigger than the GT spec they are. I will try and find out for you.
Psydotek - Most likely not sorry.
Ben
Old 11-15-2004, 04:33 PM   #15
RallySport Direct
Member#: 33174
We are Open Late!
Also I forgot to mention. Gt Spec are now using triple internal wall (quad-tube) design for all the new production braces. This is a upgrade from the old production which is only double internal wall. Currently cusco and greddy are only using double internal wall. The guys over at GT Spec are always pushing for the highest quality products.
Ben
Old 11-15-2004, 05:40 PM   #16
typerman
Member#: 26263
fitment on older imprezas?
typerman is offline
Old 11-16-2004, 11:02 PM   #17
Clavo
Member Sales Rating: (2)
Member#: 22303
2002 WRX Wagon WRB
2006 W211 e55 AMG White
As well as fitment for an '02 WRX Wagon with ALK ?
Clavo is online now
Old 11-17-2004, 04:57 AM   #18
SSTINGER77
Member#: 45635
02 WRX Wagon
looks dope... but tad expensive
SSTINGER77 is offline
Old 11-17-2004, 05:09 AM   #19
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
are the subframe hard to remove? and how easy is the installation? bump for spiffy product.
hey1 is offline
Old 11-17-2004, 01:48 PM   #20
RallySport Direct
Member#: 33174
We are Open Late!
Yes the wagon shares the same subframe so it will fit your vehicle with the ALK.
The subframe is not to hard to remove. It is pretty much a unbolt the stock one then bolt this up. One of our customers said he did the install in 25 min.
Ben
Old 11-17-2004, 05:42 PM   #21
Torch
Member#: 10172
Do you mind educating a noob as to what the benefits of something like this would be?
Thanks,
Torch
Torch is offline
Old 11-17-2004, 05:56 PM   #22
RallySport Direct
Member#: 33174
We are Open Late!
It will save 12.6lbs in weight on the front end. This will decrease you power to weight ratio and increase your acceleration. It will also stiffen up the chassis. This will make the car handle better and become more predictable. This is like putting on a strut tower brace x100.
And of coarse the number one reason to buy this is the BLING
Ben
Old 11-18-2004, 07:50 AM   #23
petawabit
Member Sales Rating: (66)
Member#: 18978
96 brighton
05 AP2 ,09 GE8
same question as typerman, do those fit on the older imprezas?
petawabit is offline
Old 11-18-2004, 10:43 AM   #24
Torch
Member#: 10172
Ben
Oh, so it replaces something.
I get it.
Thanks.
Torch is offline
Old 11-18-2004, 10:51 AM   #25
ejh25
Member Sales Rating: (41)
Member#: 65267
Is there any way to get the splash guard to fit back on? During winter time I wouldn't want to have all the salt and slush sprayed up into my engine bay. I like the brace and can see why it would be so effective but the splash guard in my mind is a necessity.
ejh25 is offline
Closed Thread
FS: GT Spec 14-pt Subframe replacement brace bhhamblin RMIC Private Classifieds 17 07-16-2008 08:06 AM
FS: GT-Spec 3-Piece Subframe Brace mav1c Suspension/Brakes/Handling 35 01-12-2007 10:49 PM
GtSpec 14-point Subframe Braces = Nice! engineerx Brakes, Steering & Suspension 29 01-05-2007 11:42 AM
New Products Released - GT SPEC 14 Point Subframe Replacement Braces RavSpec Suspension/Brakes/Handling 33 03-27-2005 07:16 PM
