Old 11-14-2004, 10:46 PM   #1
wrxxed
Member#: 20567
04 STi
Sil/Sil
Default Why dosent anyone make oem spec'ed wheels?
Why dosent anyone make aftermarket 17(or18)X7.5(or 8) 53 mm offset wheel???? All the wheels on the market end up stressing the suspension ,increase wear and torque steer?
wrxxed is offline   Reply With Quote
Old 11-14-2004, 11:17 PM   #2
Boxologist
Member#: 21118
Liar.
Boxologist is online now   Reply With Quote
Old 11-15-2004, 12:29 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....I don't think so......
I think you are trying to worry about nothing.
Old 11-15-2004, 06:56 AM   #4
WR^2X
Member#: 37617
A quick google search gave:
17x7.5 Allstadt I-3 piece wheel
Team Dynamics Alloy wheels
And others. I'm not saying these are great companies with great wheels (never heard of them, but I am not a wheel expert, either), but they do exist.
WR^2X is offline   Reply With Quote
Old 11-15-2004, 12:37 PM   #5
Yotsuya
Member#: 935
Jack Soo Fan Club
53mm offset is kind of rare; I think Subaru is the only large (loosely speaking) company that uses it. Many aftermarket companies stick with the offsets that will work on more cars.
There are still plenty of choices out there; you just have to know where to look.
Yotsuya is offline   Reply With Quote
Old 11-15-2004, 06:38 PM   #6
reaubideux
Member#: 33666
Prodrive uses 53mm offset on a lot of its wheels but only the 17x7's. They still use +48 for their 17x7.5's.
reaubideux is offline   Reply With Quote
Old 11-16-2004, 08:36 AM   #7
wrxxed
Member#: 20567
04 STi
Sil/Sil
The problem is only the 18 inch prodrives will fit the sti and all in an 8 inch width ans 43mm offset, which becomes an issue if you lower the car(rubbing)! I thought prodrive was a subie specialist? Sure there are many wheels that will fit but nothing that has the same oem specs,prodrive PFF-7 ,18x8 ,51mm is the closest but it weighs 20.25 lbs. The volks offset to fit the sti is 44mm,etc... Get the drift,Im on the market for wheels and am trying to stay as close to oem specs as possible,I guess Im anal !
Old 11-16-2004, 09:23 AM   #8
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Originally Posted by Boxologist
Liar.
Only 4 letters for a post that actually says something, quite an achievement!
Anyway, while big changes in offset could have a negative effect, I don't believe that a few mm's will matter much. It's a really small change if you compare it to the overall suspension dimensions. 48mm is perfectly fine, or even less for wider wheels.
TheWRX is offline   Reply With Quote
Why dosent Subaru give the US the JDM WRX/STi? jack klompus Newbies & FAQs 11 11-05-2007 10:31 AM
Why does'nt anyone make an STi-> RS steering adapter? mpaone Subaru Conversions 6 05-20-2007 09:46 AM
Why dosent Subaru................. shamrock 05 General Community 30 02-25-2007 03:18 PM
Endlinks: Anyone make OEM style but stronger? oversteer Brakes, Steering & Suspension 25 02-25-2007 03:56 AM
Why does a couple pounds lighter wheel make a difference? Andrew Brakes, Steering & Suspension 15 03-16-2001 06:35 PM
