Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 11-15-2004, 12:56 AM   #1
jimball21
Member#: 44407
2004 wrx
black
Default check engine light blinking
Okay I doubt its a big deal but i am curious on what you guys may think. I have no cats and the car is tuned, but i always had a cel, but thats okay cuz i know its the exhaust causing that to be on. But now i notice sometimes when i punch it ,usually in 5th, the cel starts to blink on and off. Is it cuz of the cold weather or some bullshiet like that and me punching it, or should i really look into it..
jimball21 is offline   Reply With Quote
Old 11-15-2004, 01:03 AM   #2
Panic
Member#: 48699
2008 Evo X GSR
Apex Silver
I would be somewhat concerned about this...Most tunes on our WRXs/STis eliminate the cat inefficiency codes that you are referring to. Perhaps your tune does not. Now I am no expert on flashing CELs but the flashing cel may be the engine detecting knock and throwing the blinking CEL. It would definitely be worth going to the local autozone or pep boys and having your codes read. Good luck.
Panic is offline   Reply With Quote
Old 11-15-2004, 01:04 AM   #3
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
You should get a cel fix because assuming it is only on because of the emissions eliminates the entire diagnostics. Rather than speculating on the cause, pull the code. AZP has a reader and can tell you in no time flat.
turboICE is offline   Reply With Quote
Old 11-15-2004, 01:08 AM   #4
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
umm, normally blinking is bad, do a search... u probably have some misfire goin on(ping/knock)
YaZahX is offline   Reply With Quote
Old 11-15-2004, 01:11 AM   #5
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Ya, what is the car tuned with. If you have a UTEC it flashes the CEL when the car is knocking.
N'CTRL is offline   Reply With Quote
Old 11-15-2004, 01:16 AM   #6
jimball21
Member#: 44407
2004 wrx
black
yeah it is tuned with a utec.. I think im gonna lower the boost a little then. Maybe because of the weather there is some boost creep and it can be causing this. Unfortunatley my boost gauge is off and autometer sucks. But i am going to check this out asap!!! thanks alot guys.
Old 11-15-2004, 02:34 AM   #7
InfamousDX
Member#: 25413
Yea if you're in 5th and punching it at a low RPM, I bet it's some knock. Pull some timing.
Old 11-15-2004, 09:11 AM   #8
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
do you still have the EGT sensor in there? WOT runs in 5th will def make for some hot exhaust!
kbcr3 is offline   Reply With Quote
Old 11-15-2004, 09:58 AM   #9
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Better yet, just avoid 5th gear pulls...it doesn't make sense to pass or otherwise go WOT in such an overdriven gear anyway. No need to adjust the tune as long as you have no det in gears 1-4...
For the past week and a half I've been datalogging and pulling timing on my utec, as I get the blinking CEL now, from cold weather. I think I've got most of it tuned out...its almost worthwhile to have a summer map and a winter map, lol
annointed is offline   Reply With Quote
Old 11-15-2004, 12:46 PM   #10
jimball21
Member#: 44407
2004 wrx
black
would decreasing boost help this problem?? Im actually going by turbo trix in a few minutes to ask them some questions to since i got it tuned by them. Maybe they can hook me up with a winter tune hehe, or junior can get a datalog and see whats going on..
Old 11-15-2004, 03:05 PM   #11
darkmist2k1
Member#: 31364
Ver6 Trek and couple
bottle of gatorade 4boost
good...since ya are talkin about CEL.....i just got one this morning..when i was heat up my car... it a steady CEL....i connect my laptop into the OBD thingy..and it gives me Knock Senor 1 Cicuit Malfunction.... SInce ya talkin about knock and stuff...can anyone give me what that code means... and how can i fix it??
THANX in advance
darkmist2k1 is offline   Reply With Quote
Old 11-15-2004, 04:36 PM   #12
jimball21
Member#: 44407
2004 wrx
black
Yeahi just got back from turbo trix ad junior just changed my timing and allthat good stuff for this colder weather, but he and i both think it could be because of bad Fuel and a lil bit of boost creep. Time to lower that boost.
Old 11-16-2004, 12:45 AM   #13
InfamousDX
Member#: 25413
Stop hitting it in 5th, too!
Old 01-24-2005, 05:46 PM   #14
_sti_05
Member#: 72313
16 STi
i was driving on the highway on a cold night it was about in the 40's my girlfriend tells me to go faster cuz she wants to go home. i step on it and im just about to hit 120 when the car feels like it hit a wall. Then the cruise light and the cel came on. the cruise light was blinking but not the cel. i kept driving and stopped at a gas station. i noticed that underneath the dash near the clutch a green connector or something was loose. i connected it to another plug that was hanging there. it fix perfect so i thought that it went there. when i started the car back up. the cel started to blink.
now im consider cuz ive been hearing that a blinking cel is not good. so i was wondering was me connecting that green plug near the clutch the reason for the blinking cel (hopefully) or could there be a major problem here.
this is my daily driver and i dont want to be driving it with that blinking cel if theres a major problem.
again the blinking cel did not come on untill i connceted that green thing.
im running all catless. 05 STi
anyfeedback would be great
_sti_05 is offline   Reply With Quote
Old 01-24-2005, 06:01 PM   #15
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Probably hit the boost cut originally, you probably have one of those salad bowl bell mouth downpipes that boost creep.
The green connectors are for diagnostics disconnect them.
If you haven't put in a fix for cat inefficiency you will eventually get a CEL again for that.
Old 01-24-2005, 06:37 PM   #16
_sti_05
Member#: 72313
16 STi
yea i believe i hit boost cut, i do have a cel fix for the dp. i will disconnect the wires right now..
hopefully that will stop the blinking.
thanks
Old 01-24-2005, 07:59 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Unplug the green connectors. They are for a diagnostic mode only and should never be plugged together. If you do connect them the CEL will blink constantly, the fans will cycle and various relays and solenoids will go on and off.
And please don't do 120 on public roads.
Old 01-24-2005, 08:04 PM   #18
_sti_05
Member#: 72313
16 STi
yea i know, thats probably the last time ill be going 120.
i unplugged the green connectors and the blinking stop.
the after awhile the cel light went away. and my blood pressure went down
and between yesterday and today i must have changed underwears like 6 times
thanks for the feedback.
Old 01-25-2005, 12:59 AM   #19
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
[email protected] Record Run.
THANX in advance
same thing happened to me a while back. i just reset the ecu a few time and it would come back. But then it didnt come back, been cel free for a month or two. Let it be for a while, maybe it will fix itself
96Imprezadent is offline   Reply With Quote
Old 01-25-2005, 01:25 AM   #20
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
those green connectors should be labeled "do not connect"... i was tempted to until a friend told me what happens when you connect them.
LatentWagen is offline   Reply With Quote
Old 01-25-2005, 01:31 AM   #21
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Whatever causes a MIL does not correct itself. The condition may not arise again, but cars are not self-correcting.
Help! Check Engine Light + Blinking Cruise Control mindz0f1 General Community 3 02-15-2007 10:35 AM
Check engine light blinking!?! Chonojake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-11-2006 10:06 PM
Check engine light blinking!!! rageatm007 Electrical & Lighting 5 07-26-2004 08:54 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 5 08-26-2003 10:08 PM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 09:59 PM
