Old 11-15-2004, 02:21 PM   #1
E30M3Pilot
Member#: 74739
Default Motor Rebuild questions
hello all,
im not a subaru guy (sorry i stick to BMW's Motorsport Division) but today this guy with a boosted 2.5 RS came to me and was asking about a motor rebuild because he smoked the rings on one or more of the pistons...i have done several motor rebuilds but never a subaru....saying that im not sure were to get parts, costs of the job or other information he was asking....
so im asking for some help...
about how much for all the parts? gaskets, pistons, bla bla bla....
any special tools?
real problem areas?
where can i get these parts?
the guy is boosting the RS motor so should i get lower compression pistons? (not sure what the boost psi number is but its got a garret T4 turbo...or thats what he said he had)
more questions later...thanks a bunch
kevin
E30M3Pilot is offline   Reply With Quote
Old 11-15-2004, 05:32 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
tell him itd be cheaper for him to get a new block
then go buy an ej257 block, have the coolant channel machined, welded then charge him 3gs
muhaha
Old 11-16-2004, 01:40 AM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
If you have never worked on Subaru motors before and don't plan on doing too many in the future, I would avoid re-building the motor. They are kinda strange and unlike anything else out there. You need a few special tools that aren't readily available and some reference material you might not be able to get your hands on. I would try and sell the kid on the idea of a new short block (either a 2.0 WRX motor or a 2.5 STi motor). They are very in-expensive especially when it comes down to paying a shop $80 an hour to build one, and will be much more reliable in the long run. Last I checked a brand new STi short block in shrink wrap from subaru was like $1200.
no-coast-punk is offline   Reply With Quote
Old 11-16-2004, 03:26 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
theyre around 1700 now
Old 11-16-2004, 09:49 AM   #5
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
I just called subaru yesterday. a new WRX 2.0L shortblock is $857 new. ($856 and change)
JonofScio is offline   Reply With Quote
Old 11-18-2004, 05:44 PM   #6
RSEnigma
Member#: 32326
'04 S2000
Suzuka Blue
yeah i recommend that if yur not familiar with taking a subaru engine down to the crank that u go with a short block. internals are gona be expensive and disassembling it will be a pain in the butt. nothing's really normal about it, i mean u hafta pull block plugs and then remove wrist pins to get the blocks apart, leaving the pistons in the blocks and rods on the crank. its wierd. if yur looking for a short block u can check the vendors for sale forums on here. there are usually decent deals on there. if its gona stay N/A then i'd say look for a stock block, if yur customer wants to go turbo then there are more options but its gona require lotsa homework. good luck dude.
RSEnigma is offline   Reply With Quote
Old 11-18-2004, 05:52 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
well hes got a 2.5 not a 2.0
motor rebuild meatball18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-11-2007 02:46 PM
06 WRX Motor Rebuild? pr4life750 Built Motor Discussion 1 05-06-2007 07:35 PM
building oil presure after motor rebuild skunkfifty Service & Maintenance 2 03-10-2006 10:41 AM
Atlanta motor rebuild dlowman South East Region Forum 3 01-26-2005 12:05 PM
Good motor rebuild shop by Detroit area RSpeeder Mid West Subaru Owners Club Forum -- MWSOC 5 05-12-2004 10:20 PM
