Old 11-15-2004, 02:37 PM   #1
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Default v8 Brembos | What's the correct way to spread the pistons?
I had an old backing plate from a used pad that I used to spread the pistons out so the new pads would fit down in the caliper. I've somehow lost it and was wondering what was the correct way to install new pads? My way seemed kinda hokey but did work.
Thanks......
TreyS is offline   Reply With Quote
Old 11-15-2004, 02:44 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
I just bought a $5 caliper spreader at the auto parts store
but some use a C Clamp or pry bar
Old 11-15-2004, 03:20 PM   #3
TreyS
Member#: 42478
2004 WRX STi
White/Gold
How do you get the spreader down in there? I've used the C-Clamp and spreaders on normal calipers but these are too different for me to see using them here.
Big screwdriver and an old pad has worked so far but I often wonder if I'm damaging anything in the process like the dust boots.
Thanks.
Old 11-15-2004, 04:08 PM   #4
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Thanks.
Nope. Thats the best way to do it IMHO.
-Tom
trhoppe is offline   Reply With Quote
Old 11-15-2004, 07:19 PM   #5
teiva-boy
Member#: 22825
Use a big f'ing slip-joint plier and an old brake pad.
teiva-boy is offline   Reply With Quote
Old 11-15-2004, 08:09 PM   #6
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
This is the proper tool. Although its a Porsche specific tool, it works universally on multi-piston brakes. Go figure. Expensive, but it makes quick work of pad changes in the pits.
PS, don't forget to select the proper width of your pads for the jaws.
http://shop.store.yahoo.com/eagleday/brmato.html
Here's an older style that is a lil cheaper and a bit slower, yet should still work.
http://www.samstagsales.com/images/kk126-00.jpg
thesmokingman is offline   Reply With Quote
Old 11-15-2004, 09:34 PM   #7
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Thanks guys.
I guess I'll stick to what's been working so far.
Old 11-15-2004, 09:44 PM   #8
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Welcome to the world of specific tools.
Old 11-15-2004, 09:48 PM   #9
srf
Member#: 50646
2004 WRX STi
Java Black
Wonder if those are patented. Good business opportunity.
srf is offline   Reply With Quote
Old 11-15-2004, 10:59 PM   #10
majmun
Member#: 18298
2004 STi
Just continue doing what you've been doing. Use the old pads (or current pads) as a lever. Works great and doesn't cost you a cent.
majmun is offline   Reply With Quote
What is the correct way to attach harnesses to a harness bar? DiscoWagon Newbies & FAQs 2 06-18-2006 08:15 PM
What's the correct way to say "I like to live in a nice neighborhood"?? -=C=- Off-Topic 36 06-20-2003 05:20 PM
Which is the correct way to reset the ECU?? z28dan Factory 2.0L Turbo Powertrain 5 06-26-2002 07:15 PM
what is the correct way to do a dOnut? byam52 Brakes, Steering & Suspension 15 01-04-2001 12:00 AM
What is the correct way to make a fast corner when dricing a STD car.????? gerardchau Technical Forum Archive 3 09-19-2000 07:46 PM
Message Board Statistics All times are GMT -4. The time now is 07:57 AM.
