Old 11-15-2004, 10:56 PM   #1
Jay04WRX
Member#: 34075
2008 LGT spec.B
QSM
Default One side Rota's & the other side stock rims, Can I drive?
Typically town fair tire screwed up and what else is new. They torqued the lugs on one side of the car way too tight for me to loosen. I already changed to stock on the drivers side but the passengers side has the 17" Rota's on.
Question is "Is it Ok to drive to town fair tire which is 5-10 miles away with 2 diff wheels on either side?
Jay
Jay04WRX is offline   Reply With Quote
Old 11-15-2004, 11:08 PM   #2
Danno
Member#: 3013
2002 WRX Sedan
Mithril
NO NO NO. Put the Rotas back on the driver's side!
Danno is offline   Reply With Quote
Old 11-15-2004, 11:11 PM   #3
imprezavness
Member#: 59563
2004 white WRX
confused
bye bye dif.
imprezavness is offline   Reply With Quote
Old 11-15-2004, 11:12 PM   #4
Jay04WRX
Member#: 34075
2008 LGT spec.B
QSM
Ok I need to get this taken care of tonight.
Old 11-16-2004, 01:11 AM   #5
Boxologist
Member#: 21118
Originally Posted by imprezavness
bye bye dif.
baloney. ur spare is more off sized than the difference between a correct +1 sizing and stock. its a falsehood that has been spread too far.
get a tape measure out, take off the wheels(or jack the car up to get teh wheel up), and measure the circumferences around teh center of teh tyres. if the measurements at the proper pressure are within a 1/2" of each other, ur good to go.
u'll get more variance in the same set of tyres if one is 10 psi less than another allowing it to deform and the sidewalls bow.
Boxologist is offline   Reply With Quote
Old 11-16-2004, 01:17 AM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I'd rather put the Rotas back on than take the chance... 1/2" isn't much.
jamesfacts is offline   Reply With Quote
Old 11-16-2004, 07:27 AM   #7
Jay04WRX
Member#: 34075
2008 LGT spec.B
QSM
Thanks for the advice guys. Late last night I put the Rota's back on and I will have a shop take off those lugs. I am not going to risk driving and messing up the Diff.
Another questions though. Does it matter if I use the splinedrive lugs on the stock wheels or should i use the stock lugs? Does it matter?
Jay
Old 11-16-2004, 01:16 PM   #8
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Splinedrives are fine for stock wheels, but they stick out too far so they don't look right.
khail19 is offline   Reply With Quote
TGV DELETES:Motor on one side whats on the other stretchedk7 Factory 2.5L Turbo Powertrain 3 05-29-2008 12:26 AM
One side Rota's & the other side stock rims, Can I drive? Jay04WRX General Community 20 11-16-2004 08:03 PM
can a relationship work if one person drinks and the other does not? phillywrx Off-Topic 28 05-06-2004 02:12 PM
What mattress will stay stable on one side if somebody jumps on the other side? Cjchaps Off-Topic 12 01-21-2004 06:00 PM
Why does one side of my dipstick read so much higher than the other side? dsc Service & Maintenance 6 02-07-2003 07:29 PM
Message Board Statistics All times are GMT -4. The time now is 04:36 AM.
