Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 11-16-2004, 12:03 PM   #1
criz
Member#: 56497
2008 WRX STi
Default installing TXS stealthback, any install tips?
I'm installing a TXS stealthback in my STi on thursday... anyone have any tips they've learned from previous installs that'll help?
i'm planning on modding the heat shield so I can have it on with the new DP.
can't wait to get this baby on!
criz is offline   Reply With Quote
Old 11-16-2004, 12:14 PM   #2
TheMadScientist
Member#: 23717
2005 Big red
Do not try to seperate the stock DP and third cat. Take them out as one piece. That is about the only hang up some people run into. Otherwise it is straight foward.
TMS
BTW Unplug the O2 sensor and remove it from the cat after you get the exhaust off the car.
TheMadScientist is offline   Reply With Quote
Old 11-16-2004, 12:17 PM   #3
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Use anti-size on the threads of your nuts/bolts and the threads of your O2 sensor.
StiDreams is offline   Reply With Quote
Old 11-16-2004, 12:19 PM   #4
WingNut
Member#: 14951
GDA
do the mechanical fix.
make sure you have all the necessary gaskets (donut gasket comes to mind)!
WingNut is offline   Reply With Quote
Old 11-16-2004, 12:28 PM   #5
criz
Member#: 56497
2008 WRX STi
mechanical fix?
thanks for the info guys
Old 11-16-2004, 12:53 PM   #6
criz
Member#: 56497
2008 WRX STi
oh, and FYI, I have the hi-flow cat too
Old 11-16-2004, 01:01 PM   #7
atc5
Member#: 69264
05 LGT
nice thread, i've got the same exact setup that I will install this weekend.
atc5 is offline   Reply With Quote
Old 11-16-2004, 01:32 PM   #8
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Originally Posted by criz
mechanical fix?
http://forums.nasioc.com/forums/show...hreadid=424666
PBBlaster is your friend too. It works much much better than WD40 to loosen stubborn rusted botls/nuts.
mbiker97 is offline   Reply With Quote
Old 11-16-2004, 01:58 PM   #9
Doughboy
Member#: 27398
2002 Impreza
that's the link. use the anti-fouler plugs...you can get those at kragen's. you will need to drill out the center of one of the plugs so that the O2 sensor will go through and mount to both extensions.
i haven't had a CEL ever with the mechanical fix...and it's simply an extension so you don't have to splice into your wires.
Doughboy is offline   Reply With Quote
Old 11-16-2004, 03:01 PM   #10
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
another helpful hint:
the clocking of the flange between the rear exhaust pipe and the muffler pipe have to match up - so don't tighten the spring bolts between the rear exhaust pipe and hi-flow-cat until you have the bolts in that rearmost flange. If you tighten them early, you could very possibly have it slightly off in the clocking and then the flange holes won't line up very well.
nhluhr is offline   Reply With Quote
Old 11-16-2004, 03:15 PM   #11
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
2008 BMW 335XI Space Grey
Haha cool, I'm installing the same set up too on my STi.
-Wes
Wes_FSTGDB is offline   Reply With Quote
Old 11-16-2004, 03:29 PM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
mechanical fix?
although the link to the thread was provided, it's a long thread with lots of "alternate" and time consuming methods for achieving the same result. The short story is this:
Go to autoparts store and buy "Help!" brand spark plug anti-foulers. They look like threaded O2 bungs and come in a red package. You need one each of part number 42002 and 42009.
Take the one with the crush-washer on it (#2) and drill the center out with a 1/2" drill bit (clamp it in a vise and go at it - it's soft metal so the drilling is easy).
screw the #2 together with #1 and put them in between your rear O2 sensor and the bung on the cat. You'll never get the P0420 CEL after that.
Old 11-16-2004, 04:04 PM   #13
hauvis
Member#: 50262
2000 Protege 90whp
Default Check out this downpipe
Check out this downpipe MRT doesn't mess around....
www.Renickmotorsports.com under exhausts.
hauvis is offline   Reply With Quote
Old 11-16-2004, 04:55 PM   #14
atc5
Member#: 69264
05 LGT
nhluhr - THANKS for this, that's GREAT info...going to Kragen tonight.
Old 11-17-2004, 02:29 PM   #15
awilson529
Member#: 38867
11 Mazda
Definately do the mech. cel fix.
awilson529 is offline   Reply With Quote
Old 11-17-2004, 03:17 PM   #16
criz
Member#: 56497
2008 WRX STi
do the cel fix eventhough I got the hi-flow cat?
Old 11-17-2004, 03:33 PM   #17
AaronWRX
Member#: 7194
2011 997.2 Turbo
^^ yes. do the fix.
AaronWRX is offline   Reply With Quote
Old 11-17-2004, 04:10 PM   #18
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I have not seen a single CEL and have had the stealth back for 8K miles.
Old 11-17-2004, 04:52 PM   #19
Doughboy
Member#: 27398
2002 Impreza
run a search and if you comb through the threads, you will read that others with the hi-flow cat have had CELs pop up on them, even with the electrical fix.
i have a hi-flow cat as well and am using the mechanical fix...not one CEL yet.
Old 11-18-2004, 03:53 AM   #20
awilson529
Member#: 38867
11 Mazda
Also comprare prices of electronic (~$90) compared to mech. fix ($5-$6)
Old 11-18-2004, 01:54 PM   #21
timmah
Member#: 54203
2011 WRX
I did the mechanical fix on my 04 wrx, close to 700 miles and no CEL yet.
timmah is offline   Reply With Quote
Old 11-18-2004, 02:06 PM   #22
TreeSki
Member#: 58626
I also did the mech. fix on my '04...have about 4k miles since and no CELs to report. Mech fix is the way to go, and, for those that say it doesn't work on '04's (in other threads), they clearly did something wrong...
TreeSki is offline   Reply With Quote
Old 11-18-2004, 03:08 PM   #23
criz
Member#: 56497
2008 WRX STi
thanks for the info guys, it is going on tonight
Old 11-18-2004, 03:54 PM   #24
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
With the mechanical fix on my STI, i haven't had a CEL in over 10,000 miles... and I've gone catless for big chunks of that time. Previously, with the TurboXS (and Hi-Flow Cat), I was getting CEL's every few hundred miles.
Old 11-18-2004, 04:10 PM   #25
TreeSki
Member#: 58626
p.s. i'm catless as well
Just installed TXS Stealthback, got some questions lordmickytron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-13-2004 02:24 PM
TXS Stealthback install w/pics and wagon fitment? wylie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-21-2003 12:47 AM
TXS Stealthback install? SubieBlue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-05-2003 08:12 AM
txs stealthback in the mail!! any tips or pointers for install? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-23-2003 12:13 PM
just installed my txs stealthback teiva-boy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-11-2002 09:31 PM
