Old 11-16-2004, 07:06 PM   #1
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Default Weight of OEM WRX wing?
Whats the weight of an OEM WRX wing? I trying to setup a UPS pick up & I dont have a home scale, nor do I want to carry it into the grocery store to weigh.
MF-DIF is offline   Reply With Quote
Old 11-16-2004, 07:16 PM   #2
yertle
Member#: 71910
2005 WRB WRX - Stg 2
2013 DGM WRX 5-dr
Not sure, but don't forget you also need to include the box and packing materials. I think the best bet is to just weigh it somehow.
yertle is offline   Reply With Quote
Old 11-16-2004, 07:57 PM   #3
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
that thing is light....Im pretty sure
AdamRX is offline   Reply With Quote
Old 11-16-2004, 08:04 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The wing itself weighs about 5 lbs.
Old 11-16-2004, 08:18 PM   #5
Section 8
Member#: 821
balance it with a known volume of water over a railing or something, teeter-totter style on a board (just makesure the container with water and the wing are equal distances from the balance point.
Water has a mass of 8.34 lb/gallon.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 11-17-2004, 07:19 PM   #6
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
cheeRS,
Greg
:squint:
Old 11-17-2004, 09:14 PM   #7
yertle
Member#: 71910
2013 DGM WRX 5-dr
Yeah... sure sounds like a good way to break your wing to me
Old 11-18-2004, 11:36 AM   #8
tux
Member#: 40949
2015 fxt
bl ack
but how much does the container weigh that holds the water? :P
tux is offline   Reply With Quote
Old 11-18-2004, 12:04 PM   #9
Section 8
Member#: 821
I suppose if you were pretty dense, you could manage to damage the wing. THe best method would be to just ask a friend to help if you have that problem, and you could use your head for the balance point.
I assumed that anyone could figuer out the method. I guess I was wrong.
Find you beam for balancing, place it on the balance point (unless you are slow in the head you won't pick the peak of your house or some other witless place to do it ), put a container to hold the water on one end and balance it. After you have done that, mark the center of the balance point, and where the center of the container is. Then measure the distance between the two lines, and place a third line on the beam on the oposite side of the center balance point. At this time, your simple balance is now "zeroed". The distance in the pictue is a tenth or two shy of 5 inches.
Hint: I didn't take a picture, but I used coffee cups that would not support the ends when it was ballanced, but would support one end while it was lower than the other so that the whole thing wouldn't slide off on to the counter. This is where a second set of hands or a little fore sight helps.
Next place the item you would like to find the mass of centered on the mark opposite of the container, and start adding water to balance the system. When it is level, it is ballanced. It will hep to go a little past level to insure that you don't have somthing wrong where it won't allow the beam to teeter freely. It helps the accuracy allot if you use a curved balance point. If you are so inclined, you can use a knife edge for even more accuracy.
You might be able to see the water level in the picture, but it is just below 7oz of water. You can search online to find that 1 oz of water is equilivent to 0.0078125 US gallons.
Multiplying 7 * .0078125 gives you 0.054675 gallons or approximatly 0.055 gallons.
SInce a gallon of water equals 8.34 gallons, multiply 8.34 * 0.055 and you end up finding that the Master Chief action figuer weighs 0.4587 pounds.
I did this while I was making/eating an egg sandwich for breakfast. THe whole process (minus the time to post this crap for the retards and smartass's ) took about 8 minutes.
Obviously your best bet would be to package it first if you intend to send it because you pay for total weight, not just whats in the box.
Another method of this same idea, is to put a known mass on one end of the beam, and balance it with what you want to find the mass to. When it is balanced, 1. measure the distance to the known mass and multiply it by the distance and record the result, 2. then find the distance to the unknown mass and 3. Divide the number you recorded in 1 by the distance in 2 and you will have the mass of the object you didn't previously know.
Oem Wrx Wing And Oem Wrx Fog Lights ChrisNJ69 Exterior/Styling 0 09-27-2009 05:02 AM
weight of OEM EJ257 valves kingsti Built Motor Discussion 3 01-24-2007 02:29 PM
WTB: 04 silver sedan trunk with no wing or with oem wrx wing Tobey Private 'Wanted' Classifieds 0 05-19-2004 10:44 AM
can't find weight of OEM WRX wheels Se3n Tire & Wheel 8 09-23-2003 12:07 AM
