Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-28-2001, 09:45 PM   #1
XBD
Member#: 7877
WR Blue
Default Curious about the 3 Cat. converters
Im close to purchasing a WRX (or ordering one)... and Im curious about the stock exhaust,....
What do you all think the implications of having 3 catalytic (prolly misspelled) converters is?
I know normal they restrict exhaust flow when there is only 1 of them,...but the WRX has 3 right? that gonna really restrict the flow?
Also I know as some Cat. converters age sometimes they sorta melt inside and performance is degraded...this gonna be 3 fold or something similar on the WRX?
Is there any point on putting a performance exhaust system on after the 3 converters if thats the only section you ugrade? i.e. muffler or something (in terms of power gain)
The 3 converters is so it passes american emission standards right? if so if you remove one or more it gonna make you flunk a emissions inspection?
Thanks in advance
XBD
XBD is offline   Reply With Quote
Old 06-28-2001, 11:32 PM   #2
Dori Dori
Member#: 6780
1993 Nissan
3 cats. One before the turbo on the exhaust manifold (header) and two after.
Buy a turbo back exhaust and both will be replaced w/ one high flow cat.
A new set of headers will eliminate the one before the turbo.
A cat-back exhaust will only replace one cat (the last one) with a high flow cat. To eliminate the 2'nd one, you'll need to replace your downpipe.
Of course they are restrictive and I have heard people (i really have) say "take off the cats and you'll have 340hp". This is of course untrue. Who knows how much of a gain you would have w/out them in place b/c most exhaust (turbo back that is) systems remove them and add the better exhaust piping. If I had to guess though prob (all three) 20-30hp.
Dori Dori is offline   Reply With Quote
Old 06-28-2001, 11:46 PM   #3
XBD
Member#: 7877
WR Blue
That sounds like that will really simplfy the exhaust and improve flow....will it pass emissions like that?
Whyd they slap on 3 cats in the first place? for emissions?
Also how much (ball park) would the above you describe cost to do?
Old 06-29-2001, 01:28 AM   #4
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
3" turbo back exhaust usually range around $900-1500 depending on what you get. Vishnu up-pipe will run you around $280.
illmatic is offline   Reply With Quote
Old 06-29-2001, 01:42 AM   #5
jmott
Member#: 6713
2007 Prius
brown
You could get an aftermarket exauhst with a single hi-flow cat and still pass emissions in most states.
jmott is offline   Reply With Quote
Old 06-29-2001, 10:26 AM   #6
Tuning Factory Inc.
Vendor
Member#: 3600
Turbos and cats do not mix period. Cat backs will not touch any of your 3 cats. I have removed the last cat due to fitment problems installing a JDM spec exhaust. It is not a huge difference. The front one and the first rear will probably net bigger gains in response and power. I also estimate around 20-30 hp. Just as a sidenote, many turbo cars pass with no cats whatsoever. My old Celica All trac turbo had numorous reports of passing emmissions with no cats at all.
Tuning Factory Inc. is offline   Reply With Quote
Old 06-29-2001, 10:37 AM   #7
Dori Dori
Member#: 6780
1993 Nissan
I guess thats why its called a cat back. Woops
Old 06-29-2001, 01:44 PM   #8
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
One of the other things about the WRX and cats is this, the Turbo provides sufficient backpressure that removing the cats and going with a larger diameter exhaust actually helps. In lots of other vehicles making those same changes is detrimental to performance due to lack of backpressure...
Akirasoft is offline   Reply With Quote
Old 06-29-2001, 04:28 PM   #9
nqwan
Member#: 2916
02 duburu arr exu
the rex didnt need all the cats that it has, subaru threw them all on to make it a low emissions vehicle
nqwan is offline   Reply With Quote
Just bought a 2005 Impreza 2.5 RS, curious about the pros and cons Ian1085 General Community 3 06-01-2005 11:11 PM
Where do I get the pipe to eliminate the first cat converter with the 02 in it?? RyanA Normally Aspirated Powertrain 8 10-05-2004 04:52 PM
curious about the GOV?? sTijov Political Playground 4 01-04-2004 09:05 AM
curious about the 2.5rs old and new? initialx Newbies & FAQs 2 12-01-2001 04:24 AM
