Old 06-28-2001, 09:17 PM   #1
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Unhappy broken seat lifter - help fixing?
Ok... went to sit in my 96 OB and the seat dropped all the way down. Got out, and it went all the way up. The adjuster arm does nothing but turn. I've taken the various covers and stuff off, but get to a sealed unit. Feeling around under the seat, it looks like a 3/4-round gear on the arm turns a 1/4 round gear on the seat. They don't seem to be engaged for some reason. Anyone ever experience this, or have any ideas how to go about fixing it without replacing the whole seat?
Thanks...
rrubel is offline   Reply With Quote
Old 06-28-2001, 10:22 PM   #2
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Lightbulb
Your in luck say's the fat guy! Mine did the same thing about a month ago. I thought I had broken the seat after slaming back on my floor jack after an autocross. The next day I noticed it bouncing up and down when I got in and out, and the height adjuster didn't work. But enough with the BS, here's the fix:
You don't even have to remove the seat! There are two bolts that hold the front of the seat to the frame that slides in the frame rails, If you move the seat almost all the way forward you can use a 1/4 drive socket to remove them. They are not the primary bolts that hold the seat assembly to the floor. Remove those bolts and the seat will pivot back on the rear supports. You should be able to access the gear mechanism then. There is a little screw that holds the gear in place. Mine had come loose and was allowing the gears to not engage with each other. If you line them up and tighten the screw it should work just fine. You have to line them up in the correct place or the handle will be in the wrong position. If you mess up just loosen the screw, slide the gear out a bit and try it again. You may want to apply a little locktight to the screw once you have the position correct. I noticed mine is getting a little loose again. Hope that helps, or makes enough sense to anyway!
Steven
pleiades is offline   Reply With Quote
Old 06-28-2001, 11:11 PM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
Man, I love this place!
richeich is offline   Reply With Quote
Old 06-30-2001, 12:10 AM   #4
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Originally posted by pleiades
Your in luck say's the fat guy! Mine did the same thing about a month ago. I thought I had broken the seat after slaming back on my floor jack ...
Man oh man, if that works, I'm sending you beer money (or soda money, whatever you're into). I'll try it first thing tomorrow.
[RICHR]
Old 06-30-2001, 06:23 PM   #5
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Talking wahoo!!
You da man! That was indeed my problem - the screw had fallen out completely (and of course got lost somewhere in the car, so I had to find one that would fit). Replaced it, and everything works fine. I'd send you a 6-pack of beer, but might get in trouble with the authorities for shipping across state lines. Contact me, and we can work out something. You saved me a BIG headache.
Thanks again!
Old 07-01-2001, 10:17 PM   #6
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Thumbs up
No problem! Glad I could be of assistance! Maybe we could get that put in the tech page of the board, if there is one. Someone would need to write better instructions though. I would probably have most people really confused, especially the RS owners!
Steven
Need Help Fixing Seat OneShirtChris South East Region Forum 1 04-06-2009 03:43 PM
Help Fixing Driver Seat Wobble OneShirtChris Interior & Exterior Modification 8 04-02-2009 01:09 PM
Help, fixing seat belt strap polaris Vancouver Impreza Club Forum -- VIC 2 11-19-2008 03:50 PM
Broken WRX spoiler...easy fix? fireball_jones Interior & Exterior Modification 7 09-18-2005 11:10 PM
broken ebrake, how to fix? dojoromeo Legacy Forum 3 05-26-2002 09:25 AM
