Old 11-17-2004, 03:59 PM   #1
Wagon Joe
Member#: 34436
Default help with mudflap install
I splurged and got a set of the Prodrive rally flaps. The install went smoothly on everything except for a U-shaped bracket for the rear flaps. It's supposed to somehow connect to one of the factory holes, but after the other fixings were placed, there doesn't seem to be a place within reach to bolt down the bracket. For the time being, I reversed the position of the bracket and temporarily hooked it around the metal wheel liner. Anyone have any ideas on where I went wrong?
Thanks for the help!
Wagon Joe is offline   Reply With Quote
Old 11-17-2004, 06:37 PM   #2
jester5
Member#: 57274
2004 WRX
foam insulation maybe to fill the void
-Jeff
jester5 is offline   Reply With Quote
Old 11-18-2004, 11:21 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
were there installation instructions along with the mud flaps?
i'll take a look at a copy of these instructions. maybe i can help, although i've never done this install
Old 11-18-2004, 01:15 PM   #4
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
It looks like if you shift the bracket over one hole it will line up with the factory hole that currently has the plastic push clip in it. Just a thought.
jac04 is offline   Reply With Quote
Old 11-18-2004, 01:37 PM   #5
Wagon Joe
Member#: 34436
good idea... I'll give that a try.
Old 12-03-2004, 04:43 PM   #6
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
On the U you are supposed to pop out the rivet so It can go through.
Mine didn't work like that so I didn't use them.I used the factory hardware for the rear lip and that is all that is holding mine on..but they never move.
enewtabie is offline   Reply With Quote
Old 12-08-2004, 10:34 AM   #7
Wagon Joe
Member#: 34436
Thanks for the suggestions folks. It turns out that these flaps are just too wide for the wagon. I confirmed the width difference with my coworker's 2005 2.5 RS. The distance between the pop-rivet (where the U-bracket connects) and the bottom hole in the bumper cover is 7 1/4" in the sedan and only 6" in the wagon. The only way to get these flaps to fit would be to chop off about an inch off the inside of the flaps, cut an inch off the metal brace and drill additional holes in the brace and the flaps. I wasn't expecting this when I paid $250 for a set of flaps that was advertised as fitting my vehicle.
ALBANY - Need Help with an Install? Let me help! RubbleDTD Tri-State Area Forum 22 07-06-2009 11:25 PM
Help With Hid Install With Oem Parts On 06 WRX dan1587wrx Electrical & Lighting 18 08-15-2007 07:43 PM
I need Help with my install! HELP! mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2004 02:11 AM
Plz help on mudflap install.... mindchatter STi Forum Archive 5 08-07-2003 08:50 PM
Help, Please!!! Newbie needs help with SRV303 install! mhelouin Car Audio, Video & Security 0 06-14-2003 06:12 PM
