Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds
Old 11-17-2004, 03:31 PM   #1
Matt Monson
Member Sales Rating: (1)
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Default Testing the waters: EJ20G complete swap
I might be selling my swap. It is a 1993 EJ20G from a JDM Legacy 2.0GT Closed deck motor with underpiston oil squirters. Has the small VF-10 turbo on it. AWIC intercooler that requires no hood scoop(needs a pump and heat exchanger). It comes with a 1994 WRX ECU and a stripped (ready to install in your 1st gen Impreza) wiring harness. This should run 220hp on US premium pump gas. Switching to a 90 degree inlet TD05 would hit close to 300. Comes with a front crossmember. Also has boost solenoid, pressure sensor, MAF and an SVX ignitor converted to run the coil on plug ignition. What's this worth to you?
Old 11-18-2004, 11:21 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
nobody wants this? I will sell it for half of what a front clip would cost you...
Old 11-18-2004, 11:53 AM   #3
supermoose
Visiting NASIOC Timeout
Member Sales Rating: (6)
Member#: 9093
1995 RHD STi RA Ver2
swap starr
so the wiring is stripped out ready to splice? where you putting it into? how is your crazy NA motor project?
(i been away from nasioc for long time)
h
supermoose is offline   Reply With Quote
Old 11-18-2004, 12:45 PM   #4
96Imprezadent
Member Sales Rating: (3)
Member#: 62556
1995 Fastest EJ18T
[email protected] Record Run.
its worth a lot to me but it doesnt mean i have the cash to buy it, lol. Plus id rather not have to ship a motor from CO to PA. how much are you looking to get?
96Imprezadent is offline   Reply With Quote
Old 11-19-2004, 11:39 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
h
Yep, in fact the harness was spliced into a 1990 Legacy and I decided that the car was too much of a POS to grace with the conversion. And I recently acquired a blown EJ257 shortblock and am selling the swap to finance the 12:1 CR pistons and rebuild to drop it into my crazy NA 2.5RS project.
I would like to get $1250 plus freight for the complete swap even though I am in for around $1400. I would also sell the '94 WRX ECU and already prepped wiring harness for $400 to someone who wanted to source an engine and crossmember local to them...
Old 11-19-2004, 12:01 PM   #6
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
So would that be 850 for just the engine minus the harness and ecu? I'd love to have but and deffinately short on cash now. how soon are you wanting to sell? Are there any sites I can find info on this engine? Is it sohc? Thanks
-Courtney
--oh yeah did you also say it has coil over plug ignition?
9 is offline   Reply With Quote
Old 11-19-2004, 01:09 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Courtney,
Sure, I would sell just the engine for $850. Unfortunately, I no longer have home internet and all my tech bookmarks are on my home computer. This is what I can tell you about the engine:
It is a first generation EJ20G that was used in the JDM and AUS market 1989-1994 Legacy RS/2.0GT/Liberty. The Liberty is what they call it in AUS, the RS was the sedan and the 2.0GT was the wagon. The 5 spds came with either a VF-8 or VF-12 turbo from the factory and were rated at 220ps. The autos came with a VF-11 (real similar to a TDO4-13g) and were rated at 200ps. This particular engine is from an 1993 2.0GT automatic. Running it with the better maps and higher stock boost of the WRX ECU I would expect 220hp. But with a TD05-16 conversion, this engine could easily runn 300+chp in stock form.
It is a closed deck block with under piston oil squirters and forged crank and rods. The pistons are cast. This block is identical to the early WRX blocks found on '93's and '94's before they went to the open deck design. I got it because it was way cheaper and easier to find than a closed deck WRX engine from that era.
The heads are a high flowing DOHC design using a rocker designs with HLA's. These heads are actually better than the first gen WRX heads that were direct actuation with HLA's. The WRX valves will start to float at a slight lower rpm than the Legacy one will.
The AWIC does not require the use of a hood scoop on the car, but carries a weight penalty of around 30-35lbs when you factor in the water and plumbing. And it is a coil on plug ignition...
Lastly, I may be using the shortblock on another build and would sell the heads/manifold/injectors/rails/AWIC for $500...
Old 11-20-2004, 12:04 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
bizzump...
Old 11-20-2004, 04:41 PM   #9
Skully
Member#: 48990
98 Impreza RS
RBP
i was wondering if you would sell the Crossmember. I need one that i can run WRX up/down pipes with.
Skully is offline   Reply With Quote
Old 11-22-2004, 05:22 PM   #10
kingsubi
Member Sales Rating: (59)
Member#: 19239
2011 WRX
sent a pm
kingsubi is offline   Reply With Quote
Old 11-24-2004, 12:14 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
kingsubi,
Got your pms.
Skully,
Sure, I would do business with you again. It is going to be expensive to ship, but shoot me an offer via pm
And I will be off-line for a few days over the holidays, so have patience on replies. But this is now officially a part out thread and the only thing from the swap not for sale is the shortblock itself. That is going in the Legacy Turbo I bought yesterday...
Old 11-24-2004, 02:54 PM   #12
kingsubi
Member#: 19239
2011 WRX
Matt pm box is full
quick question:
Matt,
found out some stuff and wondered if you had the answers. The JDM harness that this cam efrom did it have a mutli-coil pack like the USDM WRX engines??
Some of the JDM WRXs did not have this type and were centered on the manifold with three wires whereas the USDM ones have one for each plug.
Let me know,
James
Old 11-25-2004, 05:12 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
PM box is cleared. This harness is not for use with a coil pack at all. The '94-96 WRX's were coil on plug ignition like the modern WRX's. I had to alter an SVX ignitor to use in place of the 4 channel ignitor that the ECU was expecting. I would include this ignitor as well as the original plugs to whomever buys this...
Old 11-29-2004, 02:19 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
monday after holiday bump...
Old 11-30-2004, 10:30 AM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
nother bump. Any part from this swap is available...
Testing the waters: NY - 04 STI 6-speed trans swap rayc Drivetrain 22 11-12-2006 12:13 AM
Testing the waters: NY- 04 STI engine swap rayc Engine/Power/Exhaust 17 11-11-2006 09:17 AM
Testing the waters: Pioneer 7" indash screen with Navi and complete wiring madlarkin Private 'For Sale' Classifieds 72 03-01-2006 08:26 PM
Testing the waters: Pioneer 7" indash screen with Navi and complete wiring FS/FT madlarkin MWSOC Private Classifieds 15 02-28-2006 02:55 PM
Testing the Waters: Possible FS - Rota Tarmac II's w/Yokohama AVS ES100 mykrrrr Private 'For Sale' Classifieds 6 06-12-2004 12:27 AM
