Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 11-17-2004, 06:54 PM   #1
Member#: 74967
Default 91 Legacy OBDii ?? Engine Light
Is the 91 legacy ecu compatible with OBDii?
Or is it an earlier version of OBD? or something different?
I can get access to an OBDii reader.
If its not OBD or OBDii then what standard is it? Is there a special reader? and how do i read the diagnostic codes?
The problem with the car is that the check engine light comes on whenever i restart the car after a short break after driving for an extended period. In order to get rid of the engine light i have to turn off the engine and restart.
Any ideas??
Any help appreciated.
EuansLib is offline   Reply With Quote
Old 11-17-2004, 07:17 PM   #2
Member#: 68120
1998 RS 2.0 vf23 STi
I believe it is a ODB1 system but the connector I havent found yet.
There is a self diagnostics procedure you can perform. There is a plug with 1 or 2 wires on it, black if i remember right, that is under the dash on the right hand side of the steering column. With the key off, unplug that connector, turn the ignition to the run position and the check engine light will flash a series of codes. I have a Haynes manual and it lists the codes and what they mean. You can also erase the codes, but I cant remember how.
So basically if you get a Haynes manual it talks all about it.
Hope that helps.
fishheadback is offline   Reply With Quote
Old 11-17-2004, 07:24 PM   #3
Member#: 3224
1G legacy = obd1
how to read engine codes: http://legacycentral.org/library/literature/codes.htm
Jgrahn555 is offline   Reply With Quote
Old 11-18-2004, 08:50 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
OBDII is '96(some '95's) and up.
91 Legacy, Check engine light question submw80 Legacy Forum 4 01-01-2009 11:43 PM
1994 Subaru Legacy Check Engine Light and Fuel Odor Inside Car Modog100 Service & Maintenance 5 04-01-2006 10:32 AM
91 legacy turbo engine/tranny for sale stephon1 Private 'For Sale' Classifieds 0 11-10-2004 12:46 AM
91 legacy turbo engine and tranny for sale stephon1 Private 'For Sale' Classifieds 4 11-07-2004 08:33 PM
Legacy Check Engine Light aross Legacy Forum 13 02-23-2000 01:53 PM
