Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 11-17-2004, 10:38 PM   #1
DMK
Member#: 74984
2005 Legacy GT Wagon
Default Timing Belts and Check Engine Light
Hello,
I just found this site and thought I would post a question. I have a 1992 loyale wagon that I just change the oil pump in, when putting the timing belts back on I missed a tooth on the driver side. I didn't know that I skip a tooth until I was driving home from work with a little less power then usual. I took the timing cover off and notice the problem, after I adjusted the belts so everything lined up and I thought that my problem was over. Today driving Home from work the check engine light came on, so does anybody know what the relationship between my check engine light and the recent repair.
Thank for your help
DMK is offline   Reply With Quote
Old 11-18-2004, 01:25 AM   #2
hartage
Member#: 71141
Originally Posted by DMK
Hello,
Thank for your help
Why don't you scan your car and get the code? Actualy being pre 95 your car should have a way to flash the code to you. If you have a manual that tells you how, see what tripped the cel. If your not really interested in finding out why just pull the battery cable for 10min and reset the ecu. It shouldn't come back on, if it does you have a problem.
hartage is offline   Reply With Quote
Old 11-18-2004, 02:15 AM   #3
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Calebz is offline   Reply With Quote
Old 11-18-2004, 10:27 AM   #4
DMK
Member#: 74984
Thanks for the help. The code it flashed was 34 (EGR Solenoid or Circuit), I checked the EGR valve and it seems to working, so I will replace the solenoid and see if that fixes the problem.
Old 11-18-2004, 02:19 PM   #5
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Ya odds usually are its the solenoid. They are like $74 or so from the dealer.
Flowmastered87GL is offline   Reply With Quote
Old 11-18-2004, 08:42 PM   #6
DMK
Member#: 74984
Looks like the new EGR Solenoid fixed the problem.
thanks again.
Cruise Control and Check Engine Light.. i need help!! PhatAsiankid03 Electrical & Lighting 9 04-02-2004 04:07 PM
Engine Hesitation and Check Engine Light Bricoleur Outback Forum 2 03-22-2004 09:09 AM
Need help turbo now sputers and check engine light is on! AWJunkies Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-18-2003 02:21 AM
Air Filter and Check Engine Light pro2cer604 Vancouver Impreza Club Forum -- VIC 6 03-17-2002 07:00 PM
