Old 11-18-2004, 08:57 AM   #1
plunk10
Member#: 32342
2004 :derp:
Default What causes headlight lenses to turn yellowish? (non-subaru)
I have a Nissan 200SX where one of the headlight assemblies had a cloudy yellowish tint to the lens. I've noticed that some older cars have this issue. Does anyone know what causes these lenses to look cloudy as they age?
plunk10 is offline   Reply With Quote
Old 11-18-2004, 09:00 AM   #2
dr_wheel
Member#: 60106
I eat pieces of
** like you for breakfast
Oxidation?
dr_wheel is offline   Reply With Quote
Old 11-18-2004, 09:04 AM   #3
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Mosty of the time it's moisture that has gotten in the lens. It will first cause a white cloud, then over time to turn yellow.
Some cars are know for this, and require cleaning regularly, or if it has turned yellow, a replacement. It can be prevented by checking all the seals when the moisture is first seen.
mhoward1 is offline   Reply With Quote
Old 11-18-2004, 09:16 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The plastic discolors over time from heat and UV exposure, in addition to moisture. There are some products that are specifically made to clean and renew yellowed clear plastic, I don't know the names offhand but I'm sure someone does.
Old 11-18-2004, 09:19 AM   #5
plunk10
Member#: 32342
2004 :derp:
that makes sense. Its a 96 model that has never been garaged since I and the original owner have had it. Thats pretty sweet that there are products out there that can take care of the issue. I contemplated finding a used set of aftermarket clear transparent lenses, but the last thing I want to do is rice out my beater
Old 11-18-2004, 09:23 AM   #6
dr_wheel
Member#: 60106
I eat pieces of
Like I said, oxidation.
Old 11-18-2004, 09:27 AM   #7
TheRex
Member#: 37813
are you wanting to de-yellow your headlights? click here
TheRex is offline   Reply With Quote
Old 11-18-2004, 09:35 AM   #8
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I've done this several times to plastic lenses (my escort and my gf's Legacy), and they've all turned out well.
My preffered method is to take my socks & shoes off, roll up my pant cuffs, and soak my feet in the bathtub while I wetsand the lenses... then follow up with a heatgun/hairdryer (gently) on the inside of the lenses to dry them.
If you use some 1000 grit between coats of clearcoat, you can build it up nicely. It will make your headlights sparkle better than new, and resist yellowing for longer.
Old 11-18-2004, 09:47 AM   #9
dr_wheel
Member#: 60106
I eat pieces of
Do you always operate power tools while standing in a pool of water?
Old 11-18-2004, 09:53 AM   #10
tux
Member#: 40949
2015 fxt
bl ack
urine usually will cause that
tux is offline   Reply With Quote
Old 11-18-2004, 10:18 AM   #11
t_wrexxx
Member#: 42790
2002 Bugeye
I've heard that nail polish remover can clear up a set of yellow plastic headlights. Don't know how true that is.
t_wrexxx is offline   Reply With Quote
What causes the CEL to come on relative to temp? 83Rabbit Normally Aspirated Powertrain 5 11-05-2006 12:09 AM
What causes the boost to spike and drop around the target level (gauge=metronome)? The Modaholic Engine Management & Tuning 3 11-20-2005 07:47 PM
What causes a car to backfire? marcus12 New England Impreza Club Forum -- NESIC 6 03-26-2005 08:33 AM
What causes brakes/ABS to act funky? (having troubles) Kostamojen Brakes, Steering & Suspension 3 04-06-2003 03:00 AM
what causes the tranny to fail? Hojai Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-08-2002 08:55 PM
