Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 06-29-2001, 08:35 AM   #1
Flatfour
Member#: 906
Thumbs up 5-Spd Project
I wanted to mention to you guys that I will be starting the 5-spd conversion project on our SVX in about 2 months (when our Rex gets in)!
I have a Legacy-Turbo Trans with the Hydraulic Clutch system, which will apparently bolt right up. Mounting, pedals, driveshaft and the rest will be tricky but I am committed and have a pretty good machine shop I can get to.
I will likely stay with the Turbo's 3.91 ratio, since I also have the 3.91 LSD for the rear.
Anyway , I have a decent dig cam and will try to post up stuff as I go if anyone's interested..
As allways, any help or input would be much appreciated..
Must have 5...
Flatfour is offline
Old 06-29-2001, 03:01 PM   #2
kvnobrien
Member#: 3861
Default Good Luck
I would love to be updated on how things go. I've had the Level 10 trans done, but i'm curious to see if the 5 speed can be done. I've seen a lot of talk since I've bought the car 2 years ago and you seem pretty willing starting this up so I hope you can prove some people wrong.
Kev
kvnobrien is offline
Old 06-29-2001, 03:39 PM   #3
metroplanner
Member#: 6310
Impressive, good luck-
M E T R O P L A N N E R
metroplanner is offline
Old 06-30-2001, 01:30 AM   #4
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Thumbs up
awsome. keep us posted.
SubyRacer is offline
Old 06-30-2001, 02:46 AM   #5
Flash
Member#: 7941
1995 Mits3000GT VR-4
This is a non-Subie owner here but I have a similar car I believe. I own a 1995 Mitsubishi 3000GT VR-4 and wanted to compare that to some SVX owners. I would like to see pictures of your engines, etc. if anyone has them available please let me know.
I also have twin turbo and All-Wheel Drive and it also has All-Wheel Steering above about 30 mph. It also has Active Aero (a lip under the front air dam drops a few inches and the rear wing tilts up at 45-degrees after about 30 mph).
Just curious if anyone takes their SVX to a track or has some AWD experience to share with me. Thanks.
--Flash!
dschilberg@pobox.com
www.speedtoys.com/~dschilberg
Flash is offline
HTML code is On
Increase in strength ? RA 5 spd vs wrx 5 spd ? SideWay Transmission (AT/MT) & Driveline 1 11-14-2008 12:51 PM
jdm sti 5 spd vs. 05 5 spd auto-and-hatin-it Newbies & FAQs 1 05-30-2008 01:41 PM
jdm sti 5 spd vs. 05 5 spd auto-and-hatin-it Transmission (AT/MT) & Driveline 3 05-30-2008 01:23 PM
5-spd manual vs 6-spd manual StuBeck Off-Topic 81 05-20-2005 12:12 AM
STi 6-spd STS on a 5-spd WRX o2sys Transmission (AT/MT) & Driveline 17 03-14-2005 02:53 PM
Message Board Statistics All times are GMT -4. The time now is 04:29 AM.
