Old 11-18-2004, 05:08 PM   #1
sampson
Member#: 73850
2011 wrx
blue
Default When replacing headlight bulbs in a 2004
Is it necessary to completely remove the battery on the drivers side?
When I remove the battery, if I have to, must I worry about the security system/remote door lock feature not working?
I've had security systems that needed to be reset if the power was disconnected.
Newbie question here, I searched.
Thanks!
sampson is offline   Reply With Quote
Old 11-18-2004, 05:24 PM   #2
RUDYP00
Member#: 71434
98 2.5RS/STi
Soon 2 B Cosmic White
No, you do not have to remove the battery to replace a headlight bulb. Just put your hands down there and twist and turn it out. If you take the battery out you would have to reprogram the remotes to your car. To reprogram you get in the car turn the key to the on and off position 10 times the last time leaving it on, you'll here the horn sound. Open the door and close the door, hit button on remote.(repeat open and close door for each additional remote).
Thanks,
Tommy
Annapolis Subaru
RUDYP00 is offline   Reply With Quote
Old 11-18-2004, 05:30 PM   #3
sampson
Member#: 73850
2011 wrx
blue
Thanks,
Tommy
Annapolis Subaru
Well that about answers my question.
Thanks for the lightening fast response.
Old 11-18-2004, 10:02 PM   #4
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
Thanks,
Tommy
Annapolis Subaru
I have disconnected my battery many times to reset the ecu, for a half hour at a time, and never had to reprogram my remotes. I also had the battery disconnected all day while installing the stereo and amp. What is the difference between disconnecting the battery and removing it? That is bull, you don't have to reprogram if you remove the battery.
skyhawk is offline   Reply With Quote
Old 11-18-2004, 10:24 PM   #5
Handsdown
Member#: 29355
just put me where?
i removed my battery when i was installing new spark plugs, no reprogramming was neccessary.
keep in mind though, this was on an RS.
Handsdown is offline   Reply With Quote
Old 11-18-2004, 10:53 PM   #6
benolium
Member#: 52174
2015 Sti
Dark Gray
I just replaced the bulbs in my '05 wrx. I disconnected the battery and removed it. It's just a lot easier to see what your doing when replacing the bulbs. I reinstalled it and I did not have to reprogram the remotes.
benolium is offline   Reply With Quote
Old 11-19-2004, 09:12 AM   #7
RUDYP00
Member#: 71434
98 2.5RS/STi
It's not all cars that loose there memory. I just let him know just incase it did. I've disconected my battery for long periods of time and never had a problem.
Old 11-19-2004, 09:33 AM   #8
skyhawk
Member#: 36255
04 WRB WRX
That's not how you made it sound.
Replacement headlight bulbs? Wombat North Canada Region Forum 25 11-26-2004 07:12 PM
Replacing headlight bulbs gjhsu Interior & Exterior Modification 3 12-19-2002 03:50 PM
Help with replacement headlight bulbs oney01 Interior & Exterior Modification 1 11-03-2002 11:57 AM
Replacing Headlight bulbs udaloy Interior & Exterior Modification 1 08-10-2002 09:54 AM
replacing headlight bulbs auricom Interior & Exterior Modification 7 03-23-2001 12:43 AM
