Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-19-2004, 05:32 PM   #1
Schleppy
Member#: 15858
SPB
Default Math gurus, quick question...
I have this equation:
((204 + 54) mod 256) = 258 mod 256 = 2
What is the inverse of this equation? This is for the decryption part of a cryptographic algorithm. What I posted above is the encryption Basically I have 204 (my key) and 2 (the ciphertext), and I need to get that 54 (plaintext) back doing the inverse of that equation, knowing only 204 and 2. I seem to remember something about two's complement, but I can't remember for sure...
Thanks!
-S
Schleppy is offline   Reply With Quote
Old 11-19-2004, 05:36 PM   #2
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
wow, i suddenly feel really stupid. hope that makes you feel better...making me feel stupid and all... i hope you do.
kbcr3 is offline   Reply With Quote
Old 11-19-2004, 05:37 PM   #3
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
it's 5
WRXXXual is offline   Reply With Quote
Old 11-19-2004, 05:38 PM   #4
need2speed
Member#: 68768
need2speed is offline   Reply With Quote
Old 11-19-2004, 05:39 PM   #5
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
ask me when you have a question concerning partial differential equations pertaining to mechanical systems
Old 11-19-2004, 05:43 PM   #6
volume311
Member#: 56615
258-256=2 hope that helps
volume311 is offline   Reply With Quote
Old 11-19-2004, 05:46 PM   #7
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Help clarify the question, do you want to know the key if the crytotext is 2?
mhoward1 is offline   Reply With Quote
Old 11-19-2004, 05:50 PM   #8
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Oh, I get it now.
Mod is Modular Mathmatics, and 256 is the cycle. Think of a clock that rotates every 256 minutes.. so 258=2 or 54+204, so if the orginal is 6, the cipher value could be 6, 262, 518, etc.
Old 11-19-2004, 05:50 PM   #9
Kha0S
Member#: 8808
2011 WRX
DGM 5D
((ciphertext + 202) % 256)
So, (2 + 202) % 256) = (204 % 256) = 204
The trick is, you need to subtract 54, and bound the result between 0 and 256. By adding 256 to start, then subtracting (resulting in a net addition of 256 - 54 = 202), then doing your modulo, you don't end up going negative.
Understand?
/Andrew
Kha0S is offline   Reply With Quote
Old 11-19-2004, 05:54 PM   #10
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Understand?
/Andrew
LIES!
IggDawg is offline   Reply With Quote
Old 11-19-2004, 05:55 PM   #11
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Originally Posted by IggDawg
LIES!
I read it on the internet, so it must be true.
/Andrew
Old 11-19-2004, 05:56 PM   #12
Kha0S
Member#: 8808
2011 WRX
DGM 5D
S E T E C A S T R O N O M Y
C O O T Y ' S R A T S E M E N
M O N T E R E Y ' S C O A S T
Old 11-19-2004, 05:59 PM   #13
Subystud
Member#: 57943
WRX Stage 1+
Back to the basics
Originally Posted by mh_WRX
Oh, I get it now.
So 262 is like the coterminal "angle" of 6? Does modular mathematics go in negatives? I dunno, this is as far as high-school calculus has taken me...
Subystud is offline   Reply With Quote
Old 11-19-2004, 06:00 PM   #14
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
BTW, a better use instead of mod is a Archimedean Spiral or possible a helix.
Old 11-19-2004, 06:01 PM   #15
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
No they go from 0 to the cycle value. So in this case it would just keep repeating 0-256.
Old 11-19-2004, 06:03 PM   #16
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Depends on how you define it. Technically, yes, but in many implementations, it'll get upset with negative numbers.
Since you can avoid negatives with mod by adding the modulus first, then subtracting, it's easy to work around.
/Andrew
Old 11-20-2004, 01:49 PM   #17
Schleppy
Member#: 15858
SPB
Code:
      11001100  (204, the key)
      00110011  (Flip the bits)
    + 00000001  (Add 1)
      00110100  (2’s complement of 204)
    + 00000010  (Add the ciphertext, 2)
   54 00110110  (Plaintext!)
Attn: Juniper router gurus, quick question chkltcow Off-Topic 10 02-28-2007 01:20 PM
OT web gurus....quick question about HTML.. GooseMan Off-Topic 5 06-08-2006 11:34 AM
Graphic Gurus...quick question Drew888 Off-Topic 8 03-14-2005 06:01 PM
OT Computer Gurus...quick question az ej20 fan Off-Topic 5 12-15-2004 01:29 AM
Brake gurus...quick question BlueWRXagon Service & Maintenance 12 09-03-2003 04:05 PM
