Old 06-29-2001, 01:47 PM   #1
OsakaGangsta
Member#: 1864
2000 Impreza 2.5 RS
Silverthorn Metallic
Default Random Technology's high flow cat
Anyone using this http://www.randomtechnology.com/new_products_imp.html ?
What are the main benefits of a "high-flow cat" and what does it offer that a good cat-back doesn't? Also, I was planning on getting a Stromung with the 2.25" midpipe...will this cat work with it? It says the inlet and outlet of the cat is 2.5" but I emailed Random and he said it would be compatible with 2.25" piping.
I was just hoping that someone here had some dyno data or a personal experience with this...
OsakaGangsta is offline   Reply With Quote
Old 06-29-2001, 03:32 PM   #2
jacktam1
Member#: 1783
2000 2.5RS
do you know how much for that?
jacktam1 is offline   Reply With Quote
Old 06-29-2001, 03:44 PM   #3
OsakaGangsta
Member#: 1864
2000 Impreza 2.5 RS
jacktam, I dunno yet. I'm waiting for them to respond to another email.
Old 06-29-2001, 03:50 PM   #4
OsakaGangsta
Member#: 1864
2000 Impreza 2.5 RS
Dan,
The RAN #822504 would run $293.61. Normal delivery time is 10 working days.
Handling and Ground UPS would run $9.95
Old 06-29-2001, 04:26 PM   #5
jacktam1
Member#: 1783
2000 2.5RS
Thanks for info man..
it's kinda pricey, I'd rather get the header first.
Old 06-29-2001, 05:03 PM   #6
Stavros g
Member#: 1526
Rally Blue
wouldn't the 2.5" inlet and outlet reduce back pressure too much?
Having the same effects as a 2.5" exhaust does now on torque?
Stav
Stavros g is offline   Reply With Quote
Old 06-29-2001, 05:26 PM   #7
jeffg
Member#: 2958
2001 WRX (GC8)
Do you guys not what a catalytic converter is? On the 2.5RS we have 2 of them. They have an internal pipe diameter of about 1.75" and are very restrictive. The random piece you are looking at is a replacement for both of the cats, with 1 cat that is designed to flow high amounts of exhaust. You would still need a cat-back exhuast system to go with this, as well as headers or a turbo system. They will not decrease back pressure to level that will hurt performance, if they gain performance on a NA engine, that is still up in the air.
Jeff
jeffg is offline   Reply With Quote
Old 06-29-2001, 06:02 PM   #8
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
So in other words if you took out the cats by replacing them with a 2.25" straight pipe you would see even more power gains? right?.....
SuBart is offline   Reply With Quote
Old 06-30-2001, 10:53 AM   #9
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
At the top end, most likely. At the bottom end, you'd probably lose torque. You'd need to replace or rework the ECU since it'll go into limp mode as soon as it realises that the cats aren't working. You could probably wire something up on the O2 sensors to fool it.
d00f is offline   Reply With Quote
WTB: random tech high flow cat for GC RS soobyfan Private 'Wanted' Classifieds 13 10-13-2004 04:42 PM
Installed random tech high flow cat converter: Full exhaust review. powerlabs Normally Aspirated Powertrain 30 05-26-2004 07:14 PM
2nd Gen Random Tech High Flow Cat? Imprezafan1 Normally Aspirated Powertrain 3 02-10-2003 11:47 PM
random tech high-flow cat installed Poppa smurf Normally Aspirated Powertrain 34 10-06-2001 10:20 AM
First impressions: Random Tech's high flow cats... jhuang76 Normally Aspirated Powertrain 14 02-15-2001 08:03 PM
