Old 11-20-2004, 04:18 PM   #1
scooterforever
Member#: 55011
Default Dyno tuning a 4EAT
Ok, so I am running a VF-34 setup (and supporting mods + EcuTek). My tuner is extremely accomplished, but my car was the first 4EAT he had worked on. The problem he was running into with my car on the dyno is that when he would put any amount of load on, the transmission would downshift and the car would try to leap off the dyno (or at least strain against the restraints). As a result, my dyno maps are crap, even though I know I am making the power one expects out of a VF-34, etc. So what is the solution?
Should he be locking it in 2nd gear for dyno and custom tuning? Am I limited to road dynoing? What are other 4EAT owners' experiences here? When the next group dyno day comes up I would like to put down some decent numbers on the graph (again, I know I am actually making the correct amount of power, so this is just a dyno vs. power-making question). Thanks,
-- scooterforever
scooterforever is offline   Reply With Quote
Old 11-21-2004, 12:31 AM   #2
Russ77
Member#: 69369
yes. get it rolling up to speed in first, then do the testing in second. BUT, it must be shifted into neutral immediately at the end of the run. otherwise, it will buck on the dyno and try to come off due to the inability to upshift causing insane engine braking. it's a somewhat tricky procedure, but due to the way the shifter is gated, you just slap it forward into N. my tuner usually does it right around 6800rpm (on the downward slope of the hp curve anyway).
Russ77 is offline   Reply With Quote
Old 11-21-2004, 02:24 AM   #3
scooterforever
Member#: 55011
Thanks, Russ77 -
scooter
Old 11-21-2004, 02:23 PM   #4
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Tune it on the road ! IMHO road tuning is better for subys on the ecutek b/c you can get a more accutrate ign advance
Dyno Flash is offline   Reply With Quote
Dyno Tune: GST Motorsports L gets a low boost dyno tune for the 2010 season mpj_becks Proven Power Bragging 32 02-26-2010 12:14 PM
What places in Ca do dyno tuning w/ awd dyno? kenlee Southern California Impreza Club Forum -- SCIC 11 08-23-2004 05:39 AM
special procedures for 4eat dyno tuning? Willman67 Transmission (AT/MT) & Driveline 4 02-12-2004 04:49 PM
Tune, Dyno, Tune, Dyno..... 2MANYCARS Tri-State Area Forum 11 03-07-2003 09:24 PM
dyno tune VS street tuning ... you help pick iloveturbos Engine Management & Tuning 12 02-18-2003 01:05 AM
