Old 11-20-2004, 06:18 PM   #1
Rickyh
Member#: 40453
Default two stage water injection?
Someone give me their thoughts on this. 350 bux seems like a good deal if this works.
two stage h20
Rickyh is offline   Reply With Quote
Old 11-20-2004, 06:33 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Its a pretty average shurflo kit. Most folks who build their own, can piece together the same setup for about $100-$150 less, depending on what you need for your application. If you don't want to go to the trouble of finding and ordering all the pieces it would be a decent starter system. If your spending that sort of money you ought to also look at the SMC water injection kit before you make your choice.
The advantage of building your own is you can get just the pieces you want instead of using a setup that is pretty generic. I've actually spent a bit more on my system but I built it up a few pieces at a time, and I built it just the way I wanted it. The learning process as you build and refine the setup is also very valuable.
The Aquamist is the top of the line, but will set you back a bit more money.
Almost any water injection setup is a good deal when you consider the value for expense.
Larry
hotrod is offline   Reply With Quote
FS : Meth / water injection kit NEW! defi gauges boost, egt JT's06sti Engine/Power/Exhaust 7 06-17-2010 11:45 PM
brand new coolingmist dual stage water injection system anthonyrb98 Engine/Power/Exhaust 17 03-06-2007 12:16 AM
Snow Performance Water Injection - Stage II ngeren TXIC Private Classifieds 2 04-26-2006 12:43 AM
02 WRX TurboXS Stage IV + Water Injection GETYUP Private Vehicle 'For Sale' Classifieds 5 04-23-2005 09:06 PM
water injection and cobb stage 2 HWG map feels good !! phamster Water/Methanol Injection, Nitrous & Intercooler Cooling 11 04-23-2005 03:01 PM
