Old 11-20-2004, 08:30 PM   #1
willfong
Member#: 62031
02 S2000 for sale
Showroom condition!
Question Where to buy online discounted OEM WRX oil filters for the best price?
Hello all,
Anyone know know where I can buy discounted OEM Oil Filters for the WRX? Whom has the best prices and shipping?
I checked out http://www.allsubaru.com but their shipping is rather expensive.
Thanks,
Will
willfong is offline   Reply With Quote
Old 11-20-2004, 08:49 PM   #2
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
How close do you live to a dealer. That would be your best option if you don't want to pay for shipping. Or just buy aftermarket of your choice, fram or purolator or whatever. I live 1 1/2 hours away from the only dealer in this state so I just buy aftermarket filters.
skyhawk is offline   Reply With Quote
Old 11-21-2004, 10:42 PM   #3
InfamousDX
Member#: 25413
langstonspeed.com
wilkinssubaru.com
Old 11-22-2004, 01:36 AM   #4
willfong
Member#: 62031
02 S2000 for sale
Showroom condition!
InfamousDX...
Thanks Mike! Anything new? Shoots me an email bro.
-W
Old 11-22-2004, 10:39 AM   #5
BryanH
Member#: 993
I recently got a chance to chop a purolator oil filter and a OEM oil filter in half and take a look at them....I would have to say the rumors I have heard about purolator making these for Subaru are true as the similarities is design were shocking.
Get the PureOne oil filters if you want to compare. part no 14660.
BryanH is offline   Reply With Quote
Old 11-22-2004, 05:25 PM   #6
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
I bought mine from www.subaruparts.com . The good thing is they accept my Subaru Bucks coupons.
Gunner is offline   Reply With Quote
Old 11-25-2004, 10:51 PM   #7
andrewt461
Member#: 70647
2004 WRX
do they make filters for the 04+ wrx?
andrewt461 is offline   Reply With Quote
Old 11-26-2004, 01:39 AM   #8
willfong
Member#: 62031
02 S2000 for sale
Showroom condition!
Thanks for the info guys.
I looked at Purolator's website and found that for an 04 WRX the part # for the PureOne oil filter is: PL14612
And I found that www.allsubaru.com has the OEM at a reasonable price with shipping.
Will
Old 11-26-2004, 08:11 AM   #9
Karl
Member#: 13110
It's not a "rumor". It's printed on the OEM filter itself, made by Purolator for Subaru.
Karl is offline   Reply With Quote
Old 11-26-2004, 01:14 PM   #10
poison
Member#: 37678
I have to recommend against the PureOnes. Though they are in fact one of the best filtering filters, they are one of the worst flowing. The bypass is set to open from 14-17lb on the PureOne, and 20-24 on the OEM. That, combined with the restrictive filtration media, means that under heavy load the bypass valve will open, flowing completely unfiltered oil through your engine.
On the other hand, the OEM filter made by Purolator is a Premium Plus, one of the highest flowing filters made. The OEM filters 2-3 times the oil per minute that the PUREONE does. It has the Bypass valve set exactly to Subaru Specs, and I would trust Subaru to spec the proper filter for the car they designed. The OEM filter filters 9/10ths of the Primium Plus, but when you factor in that it won't be going into bypass at every freeway on-ramp, it probably surpasses the PureOne. Plus it is half the price.
poison is offline   Reply With Quote
Old 11-26-2004, 02:07 PM   #11
rick-l
Member#: 33868
2003 wrx
srp
Do you have any data to show that the pressure on the media will ever exceed 14 pounds per square inch on a filter with less than 10,000 miles on it?
rick-l is offline   Reply With Quote
Old 11-26-2004, 03:12 PM   #12
poison
Member#: 37678
http://theoildrop.server101.com/cgi/...=6;t=000513;p=
http://www.oilfilterstudy.com/index.htm
In the second study, the Premium plus flowed 17.2 oz per minute and the Pure One flowed 5.3 oz per minute.
Now you tell me that a car designed with a 17.2 opm flow and a higher BPV spring rate in mind will be fine with a filter allowing 5.3 opm flow and a lower BPV setting?
Those flow rates are not for our filter size, but the ratio should remain consistent between sizes.
I would trust Subarus spec on this one.
Old 11-26-2004, 03:47 PM   #13
rick-l
Member#: 33868
2003 wrx
srp
What is the oil flow rate in our 4 cyl engines?
Would warrantee repair be denied because you used this filter?
I use the $5 filter and it sounds like I am doing more harm than good.
Is there anything beside an opinion that this is true?
Old 11-26-2004, 08:48 PM   #14
poison
Member#: 37678
Who knows? It depends on your driving habits. I know the manufacturer knows.
No, they cannot deny warranty because of that. The only way they could is if they were handing out oil filters for free and you insisted on using aftermarket filters, according to the Moss-Magnussen Act .
Which $5 filter? The Premium Plus? It is awesome.
Purolator Premium Plus
Cost $2.99 -- Meijer
ADBV material: nitrile
Spring type: leaf
Baseplate hole area: 0.440 sq/in
Filter area: 345 sq/in; 64 pleats
Center tube hole area:* 1.46 sq/in
Total Weight: 425 grams
Filter and endcaps weight: 4 oz
Average largest pore size:* 57 Ám
Smallest pore size:* 22 Ám
30W 70F Oil flow @ 10psi:* 17.2 oz per minute
Summary
This filter appears to have good filtration capability and excellent flow.
Purolator Pure One
Cost $4.99 -- Meijer
ADBV material: Silicon
Spring type: leaf
Filter area: 330 sq/in; 62 pleats
Center tube hole area:* sq/in
Total Weight: 470 grams
Filter and endcaps weight: 5 oz
Average largest pore size:* 42 Ám
Smallest pore size:* 10 Ám
30W 70F Oil flow @ 10psi:* 5.3 oz per minute
Summary
This filter appears to have excellent filtration capability and lower than average flow.* Good construction with a silicon ADBV.
Bah, I just spent 15 minutes searching for the piece I was looking for.
Basically, I just can't see how you can imagine that a car that was intended to run a 17opm filter would do just as good as a filter that runs 1/3 of that flow. Absurd. The engineers know what they're doing. If it was 3opm difference, fine. But it has triple the flow with a bypass that is more resistant to opening. Why would you use anything less?
Plus, UOA's with Premium pluses are stellar. It is not like you are giving up filtration.
Old 11-27-2004, 02:55 AM   #15
rick-l
Member#: 33868
2003 wrx
srp
Was this filter precisely designed for this application or selected because it is a very common widely used filter?
What flow rate is required? What is the differential pressure across the filter at the flow rate of our engines? Are you saying the bypass will open in normal operation?
Does the filter bypass ever open except when the oil is cold? Do we even know what that pressure is for this specific size filter?
Which is better more filtration or above average flow? We have two opinions.
On the other hand it will run fine and last a long time with a FRAM filter also.
Old 11-27-2004, 03:49 PM   #16
poison
Member#: 37678
The filters in that comparioson were chosen because they fit his application: A ford or something.
I don't know what flow rate is required. I can't say definitively that bypass does or does not open in OUR filters, but logic would dictate that IF FHI spec'd a filter with a very high flow rate, very good filtration, and a bypass pressure of 20-24, and you install a filter with 1/3 the flow, excellent filtration, and bypass pressure of 11-14, there is a distinct possibility the filter will NOT run as intended ie it will be in bypass much more than the OEM would be. We all agree that the less time in bypass the better.
I do not understand why you would insist on using something other than the OEM if the OEM is an excellent product, which it is. If it was shown to be a bad filter, fine; but it has been shown, time and time again to be one of the best filters around regardless of price. Factor in price and there is no comparison.
But hey, if you need to be different...
Old 11-27-2004, 04:32 PM   #17
rick-l
Member#: 33868
2003 wrx
srp
The OEM product is the one you buy at the dealer with the subaru logo on it not the one at autozone.
I just took exception to an opinion being presented as fact.
Old 11-27-2004, 08:58 PM   #18
poison
Member#: 37678
It is not an opinion, it has been proven. I just don't have the patience to spend another 15 minutes looking for you.
The OEM is the same Premium plus you can buy at Auto Zone, though the bypass may be set differently. The filtration will be the same.
As far as Fram filters...bah, go do your own research.
Old 11-28-2004, 12:41 PM   #19
willfong
Member#: 62031
02 S2000 for sale
Showroom condition!
Hey Guys,
Interesting read this has turned out to be! Well I went to the autoparts store and looked at Purolator's app guide for their recommendation for their oil filters yesterday. Weird, they recommend the PureOne 14660 for most engines and the 04 2.0T WRX. For the 04 2.5T STi they recommend the PremiumPlus L14612.
Then while on their website they recommend the PremiumPlus L14612 for both the 04 WRX and STi! Haha I am confusie! What you guys think?
Will
Old 11-29-2004, 04:13 AM   #20
Max Umbarger
Member#: 1112
2006 FXT
RBP
I get my purolator 14460 at sears for 1.69 a piece. I havn't asked but they never have it on the shelf I aways have to ask for it. The price for 80% of those purolators on the shelf are 2.79. They must take the price down for being in the back and not in the box. oh well they still say purolator 14460 on them and have used them for years on the 3 imprezas I've had.\
Max Umbarger is offline   Reply With Quote
Old 11-29-2004, 04:15 AM   #21
Max Umbarger
Member#: 1112
2006 FXT
RBP
Now I wonderif they'll be the same price with the Sears/K-Mart merge? Better not dick it up cause I'd be 60 miles away from purolator then.
If that does happen then, (same as title of thread) who has cheap filters online?
Max
Old 12-07-2004, 03:52 AM   #22
Max Umbarger
Member#: 1112
2006 FXT
RBP
bump
Old 12-07-2004, 04:12 AM   #23
InfamousDX
Member#: 25413
Max
If you look upwards, you will find this question has been answered.
Where to buy pre-modified OEM WRX triple gauge pod, that fits 52mm tasq Interior & Exterior Modification 0 05-22-2005 07:28 PM
OEM subaru oil filters, where to buy online? 409Industries Service & Maintenance 1 01-18-2005 10:18 PM
where to get Blitz SBC I-d for the best price? PrinceWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-12-2001 10:14 AM
Who has WRX Spring/Struts for the best price? Nick Brakes, Steering & Suspension 2 12-14-2000 07:57 AM
What is the best Oil Filter for the RS. I keep hearing that Mobil 1 doesn't make one. wrxman555 General Forum Archive 12 11-09-2000 03:33 PM
