Old 11-20-2004, 11:19 PM   #1
IMPEXRALLY
Member#: 29120
03 WRX 5MT
WR BLUE
Default Newbie Q. Is it possible to have 17inch wheels (front) and 18inch wheels (rear)
As subject stated, is it possible to have this setup in a 2003 WRX?
just curious any pros cons? Thanks in advance!
IMPEXRALLY is offline   Reply With Quote
Old 11-21-2004, 12:17 AM   #2
strangerq
Member#: 13095
No it is not possible with an awd car.
strangerq is offline   Reply With Quote
Old 11-21-2004, 12:30 AM   #3
jackassery
Member#: 48655
2003 WRX
Sonic Yellow
Curious as to why it wouldn't work so long as the overall circumference of all tires is still within spec of each other(1/8 inch IIRC)?
jackassery is offline   Reply With Quote
Old 11-21-2004, 01:18 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
They'll work IF the "overall circumference of all tires is still within spec of each other(1/8 inch IIRC)."
For performance type I think you'd want some more thread up front. Either that or run different offsets front and rear to create different front and rear track.
FuJi K is online now   Reply With Quote
Old 11-21-2004, 01:45 AM   #5
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
The C4S has different width 18x8 front and 18x11 rear and of couse different tires. As long as the diameter is +/- 0.10" or better you should be okay.
powerslide23 is offline   Reply With Quote
Old 11-21-2004, 09:30 AM   #6
cooleyjb
Member#: 55727
#533 Spec Racer Ford
A thread a few days ago hit on this.
Yes 911's have different sized rims yes you can put different sized tires front and rear. Some people have race setups like this.
However you must match the DIAMETER of the two tires. And in order to make sure the diameter of the tires is same do not use a tire size calculator. Use the specs from the manufacturer because the sizes a tire is sold in is just roughly it's actual size.
As for doing this on a WRX my only question is Why???
cooleyjb is offline   Reply With Quote
Old 11-21-2004, 10:09 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Also, if the weight was off by more than a little, it could cause problems with the center diff trying to compensate....
I believe this may be an exercise in determining the failure point of some part of the drivetrain.......so don't, unless ya got lots of $$$$
Old 11-21-2004, 10:12 AM   #8
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Yeah...I have to ask...why?
Too much margin for error with the possibility of different diameters and different weights. The diffs won't like either.
mav1c is online now   Reply With Quote
Old 11-21-2004, 06:00 PM   #9
strangerq
Member#: 13095
lol. like i said. no.
Old 11-21-2004, 06:09 PM   #10
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
If the tire sizes are mismatched it borks the AWD system, that difference has to be displaced in some means of force, ie friction, ie wear. Dont do it, I believe this is covered in the manual.
Trunk_Monkey is offline   Reply With Quote
Is it possible to work in a cubicle and still have Street Cred? Spool_up Off-Topic 44 09-26-2006 09:50 AM
Is it possible to have a thread composed of entirely 'sloganed' pictures/ linux>windows Off-Topic 3 03-22-2006 10:32 AM
Is it possible to have a cyber stoning? CandyO Off-Topic 20 07-14-2004 04:04 PM
Is it possible to have too much money? HoRo1 Off-Topic 7 06-21-2004 07:38 PM
('93-'01) Is it possible to have an icon for the different cars Eric SS Impreza Forum 58 07-25-2001 02:00 PM
