Old 11-21-2004, 03:00 AM   #1
97JT
Member#: 72712
Default Will Impreza suspension work on a Legacy?
Would a set of coilovers for a 97 impreza work on a 97 legacy wagon? It is very hard to find after market parts for a 97 legacy wagon so I am trying to find alternativs. Also would:
Lower control arms from a 97-00 impreza
Front and rear sway bars from a 97-00 impreza
Cusco rear V Brace for a 97-00 impreza
Rear sway bar end links for a 97-00 impreza
Would any of these parts fit my vehicle with out any fitment problems. I am trying to improve handling. I own a 97 legacy gt wagon.
Thanks
97JT is offline   Reply With Quote
Old 11-21-2004, 01:35 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i put impreza KYB's with Legacy H&R springs on my 99 GT
The struts couldnt really hold up to the extra weight compounded by the fact that the springs were sport springs and lowered the car too much... end result? 4 months and blown strut....
next i put on a coil over set (DMS) and had issues.
rear top hats didnt work at all.. had to cut/dremel/hack them to make them accept the coil over set up...
Impreza Rear end links will work, they should be the same.
Front and rear strut braces are model specific
I'll check on the other items when i get to work on Monday
but i do not believe control arms nor sway bars are compatible between the models.
hope this helps
Jamie
www.subiegal.com
Old 11-21-2004, 09:18 PM   #3
Ryan24
Member#: 451
2000 Impreza 2.5RS
2008 Legacy GT Limited
you need wrx rear tophats for them to work.
found that out last night
Ryan24 is offline   Reply With Quote
Old 11-21-2004, 10:04 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
just curious....why would he need wrx rear tophats for them to work if he's using coilovers meant for a 97 impreza? Maybe I'm missing something here.
Legacy777 is offline   Reply With Quote
Old 11-22-2004, 01:14 AM   #5
Ryan24
Member#: 451
2000 Impreza 2.5RS
he's using impreza coilovers on a legacy
the legacy rear strut tops or tophats (at least for the sedan and maybe the wagon) are the same as the wrx and forester
gc bodied impreza's bolts for the rear tophats are about 1/2" off in the spacing
I tried last night both the new forester and 98 legacy rear tophats on my RS and neither will fit
Old 11-22-2004, 09:48 AM   #6
Legacy777
Member#: 4800
gotcha
Old 11-22-2004, 12:46 PM   #7
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
My friend has '02/'03 WRX struts/springs on his '97 Legacy GT and it works quite well. Nice thing is that it firms the ride up just a touch more than the WRX since the GT is about 100lbs lighter. (Barely noticeable, but still a plus.)
DrBiggly is offline   Reply With Quote
92 Legacy SS suspension, will WRX suspension work? 00boostedRS Brakes, Steering & Suspension 3 11-16-2008 08:38 PM
Will 2007 AccessPORT work on 2008 Legacy GT vadim Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-23-2007 10:05 AM
Will WRX suspension work on the old school Impreza? Streetman Brakes, Steering & Suspension 11 09-13-2004 07:09 PM
Will Impreza strut tops work on a Legacy wagon? dsc Brakes, Steering & Suspension 4 12-03-2002 12:07 PM
yeah!!! old Impreza suspension works on new one! RidinLow Brakes, Steering & Suspension 2 01-17-2001 08:47 PM
