Old 11-21-2004, 04:34 PM   #1
ProjectL
Top Scoob 018
Member#: 66952
03 Wrx Wagowned
95 L swapped ver1 fmic'd
Default Semi noob question, do i have to change all 4 tires at once?
Hey guys sorry if this belongs in the noob section, I did some searching and I wasn't able to come up with much. I was at discount tire co. the other day because my two front tires on my brothers '03 wrx wagon are near the bitter end. The rear tires have a decent amount of tread left. The salesman said that it's necessary for me to replace all four tires at once because of issues that arise with the AWD transmission. So my question is, is this necessary and if so should I sell them the two tires for $50 or post them up here for sale? I apologize if this thread is flame worthy, if so everybody get your flame on.
-Tyson-
ProjectL is offline   Reply With Quote
Old 11-21-2004, 04:45 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
You want the tires around the same diameter - so if the rears are hardly worn, you could probably get away with putting two new tires on the front (of the same type as the rear ones) - ideally, you should periodically rotate your tires so that they wear evenly.
If nothing bad happened when the fronts were worn down to nothing, but the rears still had tread, why would having the situation reversed a little bit be any more of a problem? (i.e., more tread on the front)
Old 11-22-2004, 05:19 PM   #3
ProjectL
Top Scoob 018
Member#: 66952
03 Wrx Wagowned
Thats what didn't make sense to me. I think I'm going to replace two and put them in the rear like pronto recomended. Thanks guys for your help
Thanks
-Tyson-
Old 11-22-2004, 05:30 PM   #4
Pronto_Breakneck
Member#: 74874
1991 Legacy L
White with rust accents
DrD's advice about the four tires being the same diameter is correct. The new tires should go onto the rear, though, not the front. Although it might seem counterintutive, the most effective rubber always goes in the rear, regardless of the drive axle configuration of the car.
Our forum sponsor, Tire Rack, has an article on this:
http://www.tirerack.com/tires/tirete...llnewtires.jsp
Pronto_Breakneck is offline   Reply With Quote
Do I have to change the spark plugs at 30K Travistee Warranty Issues & SOA Problems 16 06-01-2010 09:14 AM
Do I need to replace all 4 tires? (Sort of urgent I guess) formula91 Tire & Wheel 9 12-17-2007 05:11 AM
i have a bunch of pictures at 3mp and i want to resize all of them at once.. alacrity024 Off-Topic 17 01-14-2007 08:41 AM
Do I have to change all 4 tires at the same time datwrx Tire & Wheel 12 11-27-2006 06:51 AM
Subaru FAQ: Do I have to replace all four tires? gypsymoth Service & Maintenance 3 09-03-2002 07:14 PM
