Old 11-21-2004, 10:41 PM   #1
Blue_Rexer
Member#: 43621
2011 FXT
Default 05 wrx stiffer than 03 wrx?
well I just picked up my 05 WRX on friday and after driving just over 500 miles since then, I have noticed that the car feels a lot stiffer than my old 03 wrx which I also bought new. I am not aware of the struts/springs needing any kind of break in period to loosen up. I am not complaining about this as the handling and road feel is amazing, I was just wondering if I am crazy or someone else felt the difference or knows something I dont? I faintly remember something in the suspension being changed in 04 but I am not positive and cant seem to dig up the info...
Blue_Rexer is offline   Reply With Quote
Old 11-21-2004, 10:47 PM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The 04 and 05 WRXs have multi-phase strut valving.
ANZAC_1915 is offline   Reply With Quote
Old 11-21-2004, 10:53 PM   #3
Blue_Rexer
Member#: 43621
2011 FXT
Thank you very much, I will look into this further now..
Old 11-22-2004, 01:38 PM   #4
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
Isn't stiffer better for handling the car?
dmatthew is offline   Reply With Quote
Old 11-22-2004, 01:41 PM   #5
STi-MAN
Member#: 70252
05 STI
blue
in my dictionary it is.
STi-MAN is offline   Reply With Quote
Old 11-22-2004, 02:15 PM   #6
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
anyone know if the spring rates are different between 02-03 and 04-05?
kennyvb is offline   Reply With Quote
Old 11-22-2004, 04:03 PM   #7
Blue_Rexer
Member#: 43621
2011 FXT
Yes it handles noticeably better than my 03, sacrafices a bit of ride quality but who cares about that when you can slide around a corner at 70
Old 11-22-2004, 07:16 PM   #8
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Spring rates are unchanged as far as I know. The strut valving is greatly improved; I have heard unconfirmed rumors that some of the suspension bushings and bits are a bit stiffer as well, taking out some of the slop.
DrBiggly is offline   Reply With Quote
Old 11-22-2004, 07:25 PM   #9
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
the 05's have inverted struts now just like the sti. there are alot of suspension improvements on the 05's. ill go look for the list and post again if i can find it.
adeliciouspizza is offline   Reply With Quote
Old 11-22-2004, 07:30 PM   #10
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
found it. there were changes made from 03 > 04 as well.. this only covers 04 > 05. over all its a much better handling car.
'04 vs '05 changes
Sep 15, 2004
Source: Subaru UK
Impreza WRX STi Type-UK Gains:
– Heavily revised chassis for even more involving handling
– Longer wheelbase, wider rear track
– Major suspension geometry and caster angle changes
– New helical front limited-slip differential (LSD)
– Standard driver's control centre differential (DCCD)
– Standard yaw rate sensor
– More rigid steering and front suspension mountings
– Wider wheels - now 17x8 ins with 225/45 tyres
– Improved aerodynamics thanks to engine and floor covers
– Now 25,995 OTR
Impreza WRX Gains:
– Inverted suspension struts - just like STi - for precise handling
– Revised, sharper-feeling steering
– Aluminium front suspension lateral links
– Same 19,995 OTR price for saloon and 20,495 for the 5-door
Impreza 2.0 GX Gains:
– New, larger 7-spoke 16x6.5 ins alloy wheels with 205/50 tyres
– Rear anti-roll bar to exploit extra grip and sharpen handling
– Price reduction of 450 for saloon and 300 for 5-door
– Means saloon is now 14,500 OTR with 5-door at 15,600
All 2005 Imprezas Gain:
– Smaller diameter 3-spoke steering wheels
– Plusher - and extended - cloth door trim
– Plusher roof lining
– New, flush-fit centre console
– New air-conditioning controls
– New, quality-feeling switchgear
Old 11-22-2004, 08:26 PM   #11
Blue_Rexer
Member#: 43621
2011 FXT
Great info, thanks a lot! I was going to say "wow my WRX feels like the STi I test drove" but I was afraid I would get flamed... haha
Old 11-23-2004, 09:38 AM   #12
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Will the 05 struts bolt directly on my 03?
dbrier is offline   Reply With Quote
Old 11-23-2004, 10:37 AM   #13
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Weitek,
I am not sure that the WRX struts in '05 are inverted; I think that only applies to the UK and Japanese model cars and not the US cars.
Old 11-23-2004, 10:38 AM   #14
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
As long as the '05 struts are not from an STi then yes it should bolt right up. There may be a possibility of some tophat incompatibility however that shouldn't be hard to work out.
Spotted 04-05 wrx and 02-03 wrx on Taconic northbound around millwood ossining area Trigun001 Tri-State Area Forum 0 01-29-2007 09:24 PM
yoyo guys i have a Q about coilovers on a 05 STI and a 03 WRX lay out! Azn-Jap STI Vancouver Impreza Club Forum -- VIC 7 02-14-2005 09:12 PM
05 STI IC on 03 WRX wrxxxrated Mid Atlantic Impreza Club -- MAIC 7 09-14-2004 09:43 AM
05 Sti Seats in 03 WRX, Possible? newsman Interior & Exterior Modification 5 08-25-2004 04:27 PM
Poss to use 05 dual exhaust on 03 WRX? Owenator Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-17-2004 04:42 PM
