Old 01-03-2007, 06:34 PM   #51
scooby1220
Member#: 125129
2004 WRX VF34'd
I use dielectric grease on them and it works well. BTW, don't know why dealers are charging you guys so much, my dealer only charged me $2 each, $8 total.
scooby1220 is offline   Reply With Quote
Old 01-04-2007, 11:44 AM   #52
STIStalker
Member#: 92783
2004 WRX
This is the nicest find I have found here in awile.
I bought some used injectors from somebody here and they didn't come with O rings or the grommets so I checked the dealer and yea they said $36.00 each for the O rings and another $25.00 each for the grommet things. That comes out to almost $250.00 plus tax for 4 little rubber pieces. I just sold the injectors the way they were on ebay and got my money back.
STIStalker is offline   Reply With Quote
Old 02-14-2008, 01:40 AM   #53
lithium5150
Member#: 146455
2002 WRX Wagon
Just ordered some myself...
lithium5150 is offline   Reply With Quote
Old 02-14-2008, 03:07 AM   #54
zombiedog
Member#: 25138
85 e30
PRIMERZ!
120k and cracked a piston cuz I love teh boost...O-rings still good!
zombiedog is offline   Reply With Quote
Old 03-12-2008, 03:04 AM   #55
PolarisSnT
Member#: 85905
2004 WRX
Sorry to hear about that.
Have you ever pressure tested your intake system to ensure that no air was leaking past the o rings? I had a borked O ring that was leaking air but not fuel. While installing new O-rings(which did not want to go in) I believe I may have split them. The fuel isnt leaking but that doesnt mean air isnt.
PolarisSnT is offline   Reply With Quote
Old 03-12-2008, 11:46 AM   #56
GeneralTJI
Member#: 152680
You should always lube o-rings for install. Grease, oil, whatever you have handy, but don't try to install 'em dry.
Amen... maybe someone should explain this to the dealer Actually it's party why I got my car cheap, it was stock, original owner, somehow burned a valve... the dealer thought he had a bad injector, put a new one in- wrecked the o-ring during the install, and gave it back to him with gas running out on the ground everywhere.. he got frustrated and sold it to me cheap.... idiots... another reason why I am the ONLY person who works on my own crap.... but thanks to them- I now have my car
GeneralTJI is offline   Reply With Quote
Old 03-13-2008, 01:11 AM   #57
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Viton is good material for O-rings. Thats what they use for all the vacuum and oil seals in the Lasers I work on,... Very resistant to oil, chemicals and extreme heat
jmlaser is offline   Reply With Quote
Old 03-13-2008, 10:37 AM   #58
PolarisSnT
Member#: 85905
2004 WRX
Edit: I mis read the thread. These are the upper most tiny O rings, not the ones that go around the injector and sit in the TGV. I need those, wonder what the dealer charges.
Old 03-13-2008, 02:02 PM   #59
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
I just ordered some as well
Rexwagon03 is offline   Reply With Quote
Old 03-15-2008, 02:39 PM   #60
PolarisSnT
Member#: 85905
2004 WRX
I had to go and pick up a couple from Advanced Auto Parts yesterday. I was in a jam and I bought a 7mm and an 8mm and the 7mm by far fit the best.
Old 03-16-2008, 04:12 AM   #61
zachary.berrier
Member#: 82476
GOD CREATED TURBO
LAG TO GIVE V8'S A CHANCE
you caan get replacements at napa in the little o ring assortment pack
zachary.berrier is offline   Reply With Quote
Old 03-18-2008, 06:01 PM   #62
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
anyone got some spares they could ship out asap (would take 6 or so (two for backup).
xcdhridr is offline   Reply With Quote
Old 03-20-2008, 01:02 PM   #63
PolarisSnT
Member#: 85905
2004 WRX
Bump for another place to buy Viton o rings in a smaller quantity
http://forums.nasioc.com/forums/show...ighlight=viton
Old 09-19-2008, 07:23 AM   #64
KGP
Member#: 107462
I know this thread is old, but figured I would add a source for future reference.
source offers:
replacement injector filters (2-109 or 2-113)
upper o-rings (4-141)
lower grommets (4-140)
upper grommets (4-138)
http://injector-rehab.com/outpatient/injectorparts.htm
KGP is offline   Reply With Quote
Old 03-29-2009, 02:50 PM   #65
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
so would the 7mm or 8mm be the best for a replacement? the fourth post "The 8mm are an exact OEM match. The 7mm are for us risk takers. " got me questioning the 7mm ones..id rather go 8mm if its an exact oem match
jcbluescooby is offline   Reply With Quote
Old 03-30-2009, 09:13 AM   #66
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Get 8mm if you have a choice, just to be on the safe side. But like I said my 7mm lasted longer than the engine.
Old 03-30-2009, 02:25 PM   #67
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
do you have any left? id paypal ya a few bucks..
jdubya301 is offline   Reply With Quote
Old 03-30-2009, 02:27 PM   #68
zombiedog
Member#: 25138
85 e30
PRIMERZ!
I actually have a new bag for my build I'm doing. How many you need? 8?
Old 03-30-2009, 02:44 PM   #69
jack klompus
Member#: 152885
2014 Malibu LTZ
just 4 but I went thru 6 or so chasing down leaks. I wouldnt touch the injectors without 10 o-rings. I got a bag of 25 from Mcmaster for like $4.
jack klompus is offline   Reply With Quote
Old 03-30-2009, 02:53 PM   #70
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
o nice. i will be pming you.
Old 03-30-2009, 03:01 PM   #71
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Yah best bet is just go to McMaster... You'll have it next day.
Old 03-30-2009, 04:33 PM   #72
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
What o-rings and seals do I need to install helix 660cc topfeed injectors? Thanks.
imppu2001wrx is offline   Reply With Quote
Do you take off your wedding ring when you work on your car/whatever? Kiel Off-Topic 58 06-22-2008 11:22 AM
Tell OT about your nighborood pals you had when you grew up KC Off-Topic 2 07-06-2004 11:15 AM
WHen did you finally figure out what it was that you wanted to be when you grow up? The_Triton Off-Topic 29 04-15-2004 11:50 AM
('93-'01) How to tear up your tires (video) munkis Impreza Forum 17 06-11-2001 06:51 PM
