Old 11-22-2004, 02:38 PM   #1
dunk
Member#: 15359
Default 2003 WRX Motor into 2002 Forester
I'm planning on installing a 2003 WRX Motor into my 2002 Forester. Wondering if theres any issues I might overlook.
My one concern is that the Forester is an auto, will this make a big difference.
Extra parts that I will need. i couldn't find any threads that dealt with auto transmissions, or Foresters.
thanks
Duncan
dunk is offline   Reply With Quote
Old 11-22-2004, 11:19 PM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
search for any post that deal with older imprezas and legacies
same lego in the forester, you will need to figure out what ecu to use
Hyper is online now   Reply With Quote
Old 11-23-2004, 05:23 AM   #3
dunk
Member#: 15359
Just curious, because I couldn't find any information about it, what difference does it make which ECU I use.
Duncan
Old 11-23-2004, 11:46 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the best path
sell 2002 forester
buy used 04 FXT
more power /warrenty and probblay cheeper
Old 11-23-2004, 12:28 PM   #5
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The automatic transmission is going to give you issues. You will need to get an engine that came out of a WRX that had an AT as well as the harness and ECM.
Jaxx said it best. Sell it and get the XT, it comes with a warranty afterall.
Z
Zephyr is offline   Reply With Quote
Old 11-23-2004, 01:56 PM   #6
dunk
Member#: 15359
What issues will I have with the auto. Couldn't find anything specific searching.
Duncan
Old 11-23-2004, 02:25 PM   #7
dunk
Member#: 15359
Subura parts lists the same part number for the auto and WRX ecu. I'm just curious, other than running the required signals from the ECU to TCU, what other additional issues would there be. Anybody with experience out there.
Duncan
Old 11-23-2004, 03:03 PM   #8
dunk
Member#: 15359
All right, looking at this a little closer.
Couple questions that need answering.
What is the differences between the WRX TCU and Forester 2002 TCU. I only have manuals right now for the WRX, still in research stage. On the WRX, there are only 8 wires that run from the TCU to the ECU. Assuming the Forester's TCU has the same outputs, can't I just run the wires from the existing harness into the WRX ecu?
Duncan
Old 11-23-2004, 03:32 PM   #9
dunk
Member#: 15359
Looking at my Wiring diagram which has both turbo and non turbo diagrams. I assume that the 2002 Forester TCU is the same unit as the 2002 RS ecu, and as such, here is the wiring path between the TCU and ECU on both turbo and non-turbo
TURBO TCU -> ECU
a3-b7 throttle position
a2-b9 throttle position
b17-c9 engine speed
c14-a18 Torque control 2 signal
c5-a19 Torque control 1 signal
b10-c14 Torque control cut signal
a1-b28 AT load signal
c21-b20 AT diagnosis input signal
NON-TURBO
b2-c17 throttle position
b1-c15 throttle position
b4-a30 engine speed
a21-b17 Torque control 2 signal
a13-b16 Torque control 1 signal
a2-a31 Torque control cut signal
b20-c11 AT load signal
a4-b4 AT diagnosis input signal
So it looks like the same signals are being shared between the TCU and RS ECU and TCU and WRX ecu.
-Duncan
Old 11-23-2004, 04:34 PM   #10
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Looks like you answered your questions. You are still going to need a harness that is for auto WRX.
Z
Old 11-23-2004, 07:00 PM   #11
dunk
Member#: 15359
Well, I'm not sure, because the exisiting harness in the car now hooks the TCU to the harness. Couldn't I just cut the wires off and splice them into the manual harness?
Duncan
Old 11-23-2004, 07:20 PM   #12
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
hey hold on
you are making a good and important point
TCU in automatic WRX works in a different way then TCU in Forester as far as I am concerned (we should bug member legacy777 for this )
they are programmed differently, so you would need to get TCU as well, otherwise you might end up with one wheel drive car
Old 11-23-2004, 07:28 PM   #13
dunk
Member#: 15359
Actually I speed said that I could use the Forester TCU if I wanted, what I'm trying to figure out is the differences between the harnesses. Can you plug a WRX TCU into a Forester harness.
If so, I should be able to integrate the forester TCU harness into the WRX manual harness.
Duncan
Old 11-23-2004, 07:54 PM   #14
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
well being that there are 8 extra wires that you'll have to add to the harness if you use an MT harness it's going to get a little ugly. It would be far easier to match harness for harness.
Z
Old 11-23-2004, 08:27 PM   #15
dunk
Member#: 15359
Yes, but those 8 wires should be on the existing Forester harness. It's only 8 wires.
Duncan
Old 11-23-2004, 08:45 PM   #16
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The pins on the plugs are completely different.
Z
Old 11-23-2004, 09:32 PM   #17
dunk
Member#: 15359
I still don't think we're communication on the same plane. I plan to use the Forester TCU, the plugs from the forester harness, cut the wires after the plugs, and then splice (solder) these wires into the WRX harness.
Duncan
Old 11-28-2004, 04:17 PM   #18
dunk
Member#: 15359
Anybody have any good sources on auto harnesses and TCU's. I've tried searching but have had no luck
Duncan
2005 STI motor into 2002 wrx 5spd. NEED WIRING anyone please help navyissuesuby Subaru Conversions 7 08-03-2007 09:35 AM
SOCAL WTB :: 2.0 wrx motor ( 2002 - 2003 ) kghost Private 'Wanted' Classifieds 0 01-26-2007 08:44 PM
JDM WRX motor into US WRX? turbo2 Subaru Conversions 35 12-06-2004 09:11 PM
WRX swap into a Forester. omahasubaru Forester Forum 5 03-23-2001 05:11 AM
