Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 11-22-2004, 04:37 PM   #1
DJWRX
Member#: 10340
Default Fuel Smell When Cold Out...Fuel Rail/Injectors?
When its cold out and I first start the car, I get a strong fuel smell coming from the passenger side fuel rail. It only happens when there is a sharp drop in temp outside and goes away once the car is warmed up. I'm thinking this is probably the injector seals, but wanted to see if anyone else has had this problem.
Thanks,
Tim
DJWRX is offline   Reply With Quote
Old 11-22-2004, 04:54 PM   #2
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
There's a TSB for the fuel smell. check the maintenance forum for the number. basically a fuel line running under the intake manifold needs to be changed.
Tom
SlideWRX is offline   Reply With Quote
Old 11-22-2004, 05:17 PM   #3
DJWRX
Member#: 10340
Thanks
Old 11-22-2004, 05:58 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Link to the thread in the Warranty forum-
http://forums.nasioc.com/forums/show...hreadid=131755
Note that if you are past the 3/36 warranty period this repair, if applicable in your case, will not be done for free. This is not a recall (although it should be), it is only a TSB similar to the one for clutch shudder. The cost of this repair is not insignificant because of the amount of labor involved, the intake manifold must be removed to replace the faulty lines.
Fuel Smell in Cold weather WpgUberu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-08-2014 06:28 PM
MY02 WRX Wagon - Fuel Smell When Cold speaker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-13-2009 03:17 PM
WRX fuel smell when bitter cold smosh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-10-2004 05:49 PM
TSB-fuel smell in cold weather freeze Mid West Subaru Owners Club Forum -- MWSOC 20 02-19-2004 04:40 PM
Anyone here in Canada get the dreaded fuel smell on cold start ups? Scoobie Newbie Canada Region Forum 11 02-20-2003 12:44 AM
