Old 11-22-2004, 03:38 PM   #1
Ryokosman
Member#: 69997
12 Impreza Premium
Default Dakota Digital Tire pressure/ Temp Gauge
I've been in the market for a tire pressure monitoring system and I feel this could be the hot setup.
For whats its worth to ya guys,
I emailed Dakota Digital inquiring if the extremely high brake temp's that we see on our STi's would damage the "strap on" sending units that the system comes with.
Here is their reply:
Hello Eddie,
The max temp the sensors are designed to work at is 257F(125C). Above
these temps, the may simply not operate properly or may be damaged.
Even though your brakes are reaching temps well above safe level, I
would not expect your tires(or rims) to be reaching that kind of temp.
I have seen that racing tires may run above 200F, but how far, I have
not seen documentation.
I would start with test of IR heat gun on the rim after a few hot
laps, or the extended run which has your brakes up to temps mentioned.
I wouldn't expect temperatures to stay above unsafe levels,
except under extremely hard braking, which should have time to cool,
unless immediately stopping with no cool down lap. I think I would
expect tire failures if the rims were above that temp for any length
of time.
Best regards,
Greg mailto:gwickre@dakotadigital.com
Ryokosman is offline   Reply With Quote
Old 11-22-2004, 05:03 PM   #2
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Way expensive!! Check out the monitoring system that tirerack sells.
Undepelo is offline   Reply With Quote
Old 11-22-2004, 05:26 PM   #3
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
SmarTire ........ doesn't have temp issues
Old 11-23-2004, 12:21 PM   #4
Ryokosman
Member#: 69997
12 Impreza Premium
Default Thx!
Thanks for the replys. I'll check it out.
Ryokosman
52mm Red Digital LED Trans Temp Gauge w/ Sender WRXwife Drivetrain 3 04-18-2010 03:27 PM
WTB: Defi amber imperial oil pressure/temp gauge non-ricer Private 'Wanted' Classifieds 4 12-10-2009 04:42 PM
06 sti and installing oil pressure/temp gauge nation1979 Newbies & FAQs 20 05-08-2009 11:09 PM
Oil Pressure + Temp. gauge installation Natoe Electrical & Lighting 4 07-27-2005 04:50 AM
Which is more accurate, digital or normal tire pressure gauge ? nor1212 Newbies & FAQs 3 07-25-2001 01:34 PM
Message Board Statistics All times are GMT -4. The time now is 02:40 AM.
