Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 06-29-2001, 08:26 PM   #1
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Lightbulb Need SAFC Help ASAP!!!
I just got done installing the Apexi SAFC in my 01 2.5 RS and all the wires were connected right and i initialized it with this info:
initialize
pressure, in 5 out 5
cylin 4, throttle up arrow
but when i start my car the check engine light stays on and when bleeping the throttle its revs up then drops down to like 400 and then back upto idle.
what did i do incorrectly, and how can i fix it?
thanks
also the wiring info that i used is:
AFAC ECU
redower green/red
gray:throttle light green
brown: ground 1 black/yellow to ecu
black: ground 2 black/yellow to engine
white:map in pink/blue to engine
yellow: map out pink/blue to ecu
adeck is offline   Reply With Quote
Old 06-29-2001, 08:45 PM   #2
smacksube
Member#: 4067
01 2.5 rs
you probably have the maps backwards, you get a ce light and a weird idle (welcome to limp mode) if the map wires are backwards.
smacksube is offline   Reply With Quote
Old 06-29-2001, 08:56 PM   #3
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
i triedd switching the yellow and white wires so that the map changes but it made it worse and stalled easier and the light stayed on.
Old 06-30-2001, 08:18 AM   #4
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
did you set your sensor settings correctly or even at all? I had the same problem with my car. Does your tach needle bounce up and down and your car shakes at idle? Well if you didnt se the sensor settings correctly here they are:
Hot: 4:4/1:1
Flap: 4:4
Pressure: 1:1
you can check your afc manual and it has those settings for out cars. Jdm that is but it still works it makes the CE light go away and its symptoms. Good luck
Oh yeah if you have a My00 dont tune over 4%. You will put your map sensor out of perameters. The voltage cant go over 4 blanks. From experience pass it on.
Andy
ac_gohan is offline   Reply With Quote
Unichip Owners.... I need your help ASAP! jigga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-27-2002 12:53 AM
Need Exhaust help ASAP Witckraft Legacy Forum 2 08-21-2001 06:04 PM
('93-'01) Need tire help asap!!!(readme please) sube151 Impreza Forum 2 05-11-2001 09:34 AM
Need wiring help, ASAP Greg Sharpe General Forum Archive 0 02-17-2001 08:25 AM
Need Some Help... ASAP! inzomniak Canada Region Forum 10 07-26-2000 02:11 PM
