Old 11-22-2004, 10:58 PM   #1
Utah Saint
Member#: 51422
2008 Imp 2.5i Prem
Spark SIlver
Default 205/55/R16 to a slightly diff size
Hey everybody. My 92's are about junk and I need some new tires before my 92's fail to perform. I was thinking about going Contiextremes. With that said, I was also thinking about going to 215/45/R16 on the stock 01 RS 6 spoke wheels. Think that would be ok? If not the 215, how about the 205/45/R16?
Utah Saint is offline   Reply With Quote
Old 11-23-2004, 04:20 AM   #2
2Stroke
Member#: 36712
2003 WRX Wagon
Is the car in question the '93 Lagacy RS from your car info field? If so, you may have to wait for one of the veterans to respond...
2Stroke is offline   Reply With Quote
Old 11-23-2004, 07:30 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
lots of people swap the 205/55-16 for 225/50-16 with decent results - same diameter, so the speedometer/odometer still read properly, too.
Old 11-23-2004, 07:33 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Not sure on that car, but 225/50 is a very common size to go to from the 205/55
There are also some 225/45's available.
The Doc beat me to it
Old 11-23-2004, 12:45 PM   #5
Utah Saint
Member#: 51422
2008 Imp 2.5i Prem
Spark SIlver
225's will fit on a 7 inch wide rim? Any pics of 225/45's on the stock 6 spoke RS wheels?
Old 11-23-2004, 01:39 PM   #6
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
225/50-16 will fit the RS 7" rim better than the WRX 6.5".
LyveWRX is offline   Reply With Quote
Old 11-23-2004, 06:49 PM   #7
2Stroke
Member#: 36712
2003 WRX Wagon
A 7" wheel is right on the limit of being too narrow for a 225/45-16 tire. For example,
{{{Edit: Toyo actually specs a 7.0" min. rim for the 225/45/16. The following sentence is wrong, but its what I originally posted===>"Toyo specifies a min. width of 7.5" for a T1-S in that size." End of bad info, the rest is OK. End of edit }}}
Falken lists 7.0" as min. width for an FK-451 in 225/45-16. I don't have similar data from Continental at hand.
All the tire companies are happy with a 225/50-16 on a 16x7.
That said, the 225/45 will provide a significant gearing advantage, and a shorter and presumably stiffer sidewall, although that advantage will be partially offset by the narrower than ideal wheel.
A quick check of Tirerack just now showed no Conti 16's in 225/45 or 215/45. Conti 225/50-16's are available in many flavors.
Falken's all season "512" seems to be available in all the sizes being discussed here, but I have no first hand experience with them, I just happen to have a lot of Falken data handy:
http://www.falkentire.com/tires_512_sizes.htm
Old 11-23-2004, 08:45 PM   #8
Utah Saint
Member#: 51422
2008 Imp 2.5i Prem
Spark SIlver
Im looking at Kumho Ecsta ASX's now in 215/45/R16. But the question is, will a 45 series sidewall hold up to a day of rally cross or should I roll with the RE92's until after?
Old 11-23-2004, 10:11 PM   #9
2Stroke
Member#: 36712
2003 WRX Wagon
It might be prudent to run your first time on your old tires. You won't be competitive, but if you then get new tires before the next event, your times ought to improve dramatically. You'll also get to see if folks are using low profile tires successfully.
That said, I think the tires can handle it, as long as there are no huge rocks on the course. If you have some off road or racing experience, ditch the RE-92's. If not, maybe you should still ditch them. OTOH, it might be fun to give the RE-92's one final and very thorough thrashing.
Old 11-23-2004, 10:19 PM   #10
2Stroke
Member#: 36712
2003 WRX Wagon
One other thing is tire pressures. You'll probably want to run 215/45's in the very high 30's on pavement, but in the very low 30s on dirt.
Old 11-23-2004, 10:39 PM   #11
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Originally Posted by 2Stroke
For example, Toyo specifies a min. width of 7.5" for a T1-S in that size
Where are you getting that information? Toyo's website lists a range of 7-8.5" wide wheels for the 225/45 16 T1-s
http://www.toyo.com/tires/tire_specsheet.cfm?id=2
driggity is offline   Reply With Quote
Old 11-24-2004, 05:49 AM   #12
2Stroke
Member#: 36712
2003 WRX Wagon
Oops, from reading the line right underneath that one.
Help or Hurt... 205/55/16 to 205/50/15 tire size... reddevil Proven Power Bragging 0 02-25-2010 12:08 AM
WTB: 1 - Bridgestone RE92 205/55/R16 - Atlanta/Georgia RADON Private 'Wanted' Classifieds 1 08-04-2004 09:21 AM
WTT: 205/50/R16 Kuhmo Ecstas for 205/55/R16 RE92's AttaQ Mid West Subaru Owners Club Forum -- MWSOC 5 06-28-2004 08:51 AM
For Sale: 8 Bridgestone RE-92's 205|55|R16 MonkeyBoy North West Impreza Club Forum -- NWIC 10 02-28-2004 10:01 PM
Tire Pressure for Dunlop SP 5000 in a 205|55|R16 MonkeyBoy North West Impreza Club Forum -- NWIC 9 11-17-2003 07:40 PM
