#1 |
Member#: 7934
Vehicle:1999 Impreza wagon silverthorn metallic |
wife blew up the stock 2.2
I found a complete(i.e. everything under the hood,,,engine mounts,brackets air box,accessories,main engine harness,and computer ) EJ 25 from a 2001 forester...my car is an auto and the engine is from an auto....my main question is.... Are the transmissions the same? if not...will the 2.5 work ? and what needs to be done to make it work? will I need the transmission from the forester to make this work? will I in turn need the proper rear diff with the trans.? or are the gear ratios the same? will I need to replace the cat.? and the reast of the exhaust...I have a Y pipe from a 2.5 rs I'm using...but from there backhow similar is the 2.2l exhaust? any other tip or tricks would be very welcome to make this swap go faster and smoother.... I'm a 9 yr veteran tech and a 5 yr veteran car audio installer...so feel free to get technical....I'm ase and mecp certified future questions I may have involve valve body mods to improve shifting ...anyone know of a modified torque converter I can get? any way...this is enough on this topic....lol any input from ya'll would be greatly appriciated
#2 |
Member#: 2196
so what happened to the ej22 damagewise? and do you want to give the ej22 to me?
#3 |
Member#: 7934
#2 and #4 connecting rod bearing went....bent a valve or two in the # cylinder head...
I plan on eventually over hauling the engine and maybe selling it with the comptuer and main harness...I plan on doing a little port work and some other performance mods to it as I get some extra money...the port work and most of the other building stuff I can do myself...I just need the replacement parts...so give it away? no....maybe consider a resonable offer to buy it as is or over hauled |
#4 |
Member#: 2196
does it have the one or two port exhaust on the heads? if it is two port I might be interested in making a offer on it... or at least the heads.
#5 |
Member#: 7934
it's a single port head...borla makes a header for the 2.2 just so ya know
| Thread Tools | |
| Display Modes | |
| ej25 swap into an 02 WRX | wrxfool87 | Newbies & FAQs | 3 | 12-20-2009 07:47 AM |
| Swapping an sti motor into a 99 legacy? | Wobble | Newbies & FAQs | 0 | 12-12-2006 05:36 PM |
| Doing an EJ20 swap on my L, help needed! | spoolinboxer4 | Subaru Conversions | 7 | 07-29-2006 06:20 PM |
| Any '05 WRX owners want to do an interior swap with my '05 STi? | NskGenakuDuckie | Private 'For Sale' Classifieds | 5 | 11-23-2004 04:38 PM |
| Any one have tips for doing an EJ20T swap? | Homemade WRX | Subaru Conversions | 29 | 05-08-2003 06:00 PM |
