Old 06-29-2001, 11:56 PM   #1
elemental
Member#: 2701
'00 obs
Default my little RS and it's screech
ok... so i get in my car, it's a hot day, after i turn it down im in a hurry to open the window... so pull the switch... loud 'eeeeeeh' noise surprises me as the window is rolling down... why might this be? alternator problems? it doesn't happen after the car has run for a minute or two... just when i start it up, and this is a recent development, haven't heard it before, but i got my car in the fall so maybe it has to do with the hot temps... im not sure
anyone? and this is an MY98 RS, driver's side, not sure about passenger's
elemental is offline   Reply With Quote
Old 06-30-2001, 08:06 AM   #2
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
sounds like a loose alternator belt.
LUME is offline   Reply With Quote
Old 06-30-2001, 09:55 AM   #3
bender
Member#: 1839
if the noise is comimg from the engine compartment, it's probably a loose or worn belt
bender is offline   Reply With Quote
Old 06-30-2001, 03:53 PM   #4
elemental
Member#: 2701
'00 obs
k, even if it doesn't do it all the time?
Old 06-30-2001, 05:25 PM   #5
steve_d
Member#: 315
okay....to see if your belts are loose do this...
for every 12"of belt between pulleys, you should be able to twist the belt 1/2 twist. if you can go beyond that, it's too tight.
or you can press on the belt...it's outlined in the owner's manual how much it should move...
if there's any cracks in it, replace the belt.
I just replaced mine this morning with nice new ones....mine were the originals with 80 k on them.
or is it the window that's making the noise?? You weren't specific if it was underhood or in the door.
sjd
steve_d is offline   Reply With Quote
Old 07-01-2001, 03:21 AM   #6
elemental
Member#: 2701
'00 obs
i dont actually remember =) it was a while ago (happened a few times though), hasnt done it for a while, just thought id see if you guys knew.
Old 07-03-2001, 09:41 PM   #7
elemental
Member#: 2701
'00 obs
not alternator, i checked the belt, not loose and it also happened yesterday, it comes from inside the door... something wrong with the window motor maybe?
GA: My little RS hootie South East Region Forum 11 01-25-2010 01:03 AM
My 05' RS, and a Friends 03' WRX Justin911 Member's Car Gallery 7 02-27-2006 08:20 PM
Bought coilovers for my 2005 RS and they don't fit! gharari Brakes, Steering & Suspension 116 08-14-2005 11:06 PM
the new focus RS and it's OZ's DougM Brakes, Steering & Suspension 14 10-25-2002 07:36 PM
Got my MY01 RS and now it's time for some mods! Isidoro Normally Aspirated Powertrain 7 05-31-2001 06:34 AM
