View Poll Results: Did you pass a ODB-II test with Cobb stage 2 and an upipe/resistor?
Passed with stage 2 and upipe resistor 2 100.00%
Didn't pass due to an upipe resistor 0 0%
Didn't pass due to stage 2 reflash 0 0%
Didn't pass due to both stage 2 and resistor 0 0%
Voters: 2. You may not vote on this poll
Old 11-23-2004, 08:26 PM   #1
MO REX
Member#: 52583
2002 WRX sedan
Default Did you pass OBD-II emissions test with Accessport stage 2 and upipe resistor fix?
I did a search and found that some have passed and some have not so I thought I would post this poll.
My car info
02 WRX sedan, Accessport stage 2, TXS DP with 3rd cat and a STI upipe with a resistor fix.
Thanks
MO REX is offline   Reply With Quote
Old 11-24-2004, 11:06 AM   #2
Aspenbullet
Member#: 71240
2002 WRX Cobb Stg II
Aspen White w/Yakima Rack
Default No problems here
I passed with almost the exact same setup (TXS up-pipe, stealthback and stromung axleback with Cobb's Stage 2 reflash and the resistor fix).
Aspenbullet is offline   Reply With Quote
Old 11-24-2004, 03:50 PM   #3
hondaeater69
Member#: 60324
From what I've heard the car has to be driven a certain amount of time after the AP initializes. If you go right after an ECU reset you will fail. Just what I heard though
Old 11-24-2004, 06:17 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you shouldn't need the resistor
Old 11-24-2004, 07:12 PM   #5
MO REX
Member#: 52583
2002 WRX sedan
I'm useing the old version of stage 2 and I've never had a CEL. I just looked at the map notes for the new version and noticed that a lot of the cel defeats are only on the revised map so I think you may need the resistor with an old version.
From Cobb's site
CEL Codes Defeated [WHEN USING AS BASE MAP]
(** means new to latest revision):
P0037 - Rear O2 Sensor Heater Control Circuit Low **
P0038 - Rear 02 Sensor Heater Control Circuit High **
P0137 - Rear O2 Sensor Low Voltage **
P0138 - Rear O2 Sensor High Voltage **
P0139 - Rear O2 Sensor Circuit Slow Response **
P0420 - Catalyst System Efficiency Below Threshold
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas) **
P1312 - Exhaust Gas Temperature Sensor Malfunction **
P1544 - Exhaust Gas Temperature Too High **
I'm prety sure I will be ok with the setup I have now since I have never had a CEL. I think I will take my car to Autozone and have them scan for readiness codes before I go in for the test.
Thanks for the replies.
Pass OBD-II test, Stage 4 w/codes TheShadowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 09-24-2009 08:10 PM
Weird RPM surge with accessport stage 2 kinada423 Engine Management & Tuning 10 10-11-2005 03:44 PM
Passed NY state inspection with AP stage 2 txl146 Tri-State Area Forum 15 08-25-2005 11:21 AM
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 08:08 AM
cant find dyno with cobb stage 2 AND bolt ons (hoses, inlet and what not) jimtweet Engine Management & Tuning 1 03-27-2005 10:03 PM
