Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 06-30-2001, 02:26 AM   #1
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Default Bleeding/Replacing Clutch Fluid
Way back in the dim ages, when the frogs ruled the Earth, someone from the NESIC region popped into a thread on bleeding the clutch line (I *think* it was Wayne, and I can't find it in the archives) and said that you should not pump the clutch when you bleed it but push, hold, close, release, open, push, hold... I've had this braided stainless clutch cable I got back with the stainless steel lines that went in back in February (yeah, call me lazy) which I figured I might as well do. Can anyone confirm/deny this proceedure for bleeding the clutch line?
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
Conjunction Junction, what's your function?
Old 06-30-2001, 07:47 AM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Not sure if I was the guilty party...
But it's really no different than bleeding brakes. Fill reservoir, pump, repeat.
-WaC
Wayne
wac is offline   Reply With Quote
Old 06-30-2001, 12:35 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Thank you sir... I know somebody said it . Looks like I may finally do this today.
Brian
Come See The Magic World Inside the Abandoned Refrigerator!
Old 07-01-2001, 08:11 PM   #4
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
I can confirm your procedure is correct. This is how I also do it on brakes too. If you "pump", then any air quickly gets broken into a million bubbles and just takes longer to bleed.
During your line change, have your helper hold his or her finger over the (slave) cylinder hole so it doesn't go dry on you. Good luck
Chris N is offline   Reply With Quote
Clutch Fluid Air Bleeding tossty Transmission (AT/MT) & Driveline 14 09-23-2012 09:08 PM
Replacing the clutch fluid hose - easy?? bluemicamatt Newbies & FAQs 1 11-21-2009 10:08 AM
Clutch fluid bleed bwco Vancouver Impreza Club Forum -- VIC 8 02-19-2005 04:07 AM
Bleeding Clutch Fluid? HIHO Legacy Forum 1 04-08-2002 08:16 PM
Clutch fluid flush/replacement? GQ Transmission (AT/MT) & Driveline 0 03-31-2002 04:18 PM
