Old 11-24-2004, 10:56 AM   #1
Lordhowe
Member#: 35265
Default What tire pressure?
I just installed a set of 225-45-17 Pzero Nero m+s. what's a good tire pressure that i should stick around?
thx alot, maybe i should post this in newbie section
Lordhowe is offline   Reply With Quote
Old 11-24-2004, 10:59 AM   #2
fliz
Member#: 30342
39F-36R
Honestly, it depends on your driving style and suspension. I prefer higher pressures.
I would either start at the door panel recommendation for 17s (I think it's 36) and go up until it's too stiff or start at 40-42 and go down until it's too soft.
I always keep the fronts 3-4 lbs higher than the rears to keep the center diff happy.
fliz is online now   Reply With Quote
Old 11-24-2004, 12:16 PM   #3
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
I have the same tire in the same size. I currently run 37F/34R on my P7s. IIRC, the recommended tire pressure on the door panel is for 215/17s, and is really low.
Good luck
Jfrankon is offline   Reply With Quote
Old 11-24-2004, 12:22 PM   #4
Lordhowe
Member#: 35265
thx a bunch!
Old 11-24-2004, 01:23 PM   #5
pezman04wrx
Member#: 66558
^^^ How does keeping the tire pressure on the fronts help out the center diff? More rear end traction because of the lower pressures? Just curios ... Thx ...
pezman04wrx is offline   Reply With Quote
Old 11-24-2004, 01:37 PM   #6
fliz
Member#: 30342
there's more weight in the front, so if you keep the pressures the same, the front tires will compress more and have a smaller effective rolling radius than the rears. Keeping the rear tires lower keeps the effective diameter the same and reduces the decel whine often heard on our cars.
P.S. I should point out that I don't have any proof of this theory, but it makes sense to me and I've heard of people increasing the pressure differential between the fronts and rears to reduce deceleration whine from the transmission.
Old 11-24-2004, 01:43 PM   #7
porque
Member#: 57102
39F-37R here on same exact tires. One thing I've noticed is proper tire pressure makes the biggest difference for steering feel than any other mod I've done so far.
porque is offline   Reply With Quote
Old 11-25-2004, 01:40 AM   #8
Lordhowe
Member#: 35265
I'm currenly sitting on 38-36, and it think this is perfect for my set up. Thx again everyone!
what tire pressure to run stock? and what is a good aftermarket tire? jay25RS Tire & Wheel 6 06-13-2011 01:54 PM
new wheels and tires, what tire pressure? nickster Tire & Wheel 5 06-10-2004 12:28 AM
What tire pressure do you guys use for 17" 215 tires? V6 Brakes, Steering & Suspension 4 05-02-2002 04:00 PM
What tire pressure do your guys use? V6 Brakes, Steering & Suspension 18 09-06-2001 03:41 PM
What tire pressures have you found good with the stock RE92 on Bay Area roads whomR Bay Area Impreza Club Forum -- BAIC 7 07-28-2001 07:16 PM
