Old 11-24-2004, 07:49 PM   #1
Jaredm83
Member#: 65816
2014 Forester XT
Default Can I put all "GM Synchromesh" in my tranny?
Hey all, Im getting ready to change the gear oil in my tranny. Can I put all sunchromesh in there or must i put some 75w90 in it also? Does anyone know if the synchromesh is gl-5 ? I need answers before 5 because the only place in town that has the redline 75w90 closes at 5!! Oh, and whats the capacity of my tranny if anyone knows off hand? Oh, ps, is a 98 Impreza L with a 5 speed.
Jaredm83 is offline   Reply With Quote
Old 11-24-2004, 10:22 PM   #2
rogerd
Member#: 59934
2005 Legacy GT Wagon
Atlantic Blue
GM Synchromesh is NOT GL 5 or GL 4 - it's specifically designed for a straightforward synchro transmission that does not have a crown wheel and pinion type final drive in it - they require a lube that supports very heavy tooth loads where the teeth slide over each other. The reason GL5 is specified by Subaru and others is to properly lube the final drive.
rogerd is offline   Reply With Quote
Old 11-25-2004, 10:15 PM   #3
JalopySiR
Member#: 39378
2004 Carless
98' VFR800Fi/02' RC-51
I've had straight, undiluted synchromesh in my tranny for around 15,000 miles. Everything has been great, so far (knock on wood) I don't see why it wouldn't work, knowing the reason GM contracted Pennzoil to manufacture this magic fluid. It's a good story. I put it in my brother's Supra R154 5spd and it completely eliminated a horrendous 2nd gear grinding.
I love the stuff.
JalopySiR is offline   Reply With Quote
Old 11-26-2004, 07:09 AM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
GM syncromesh is basically a dexron III auto fluid for all intensive purposes.
mr2guru is offline   Reply With Quote
Old 11-26-2004, 08:50 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
1qt synchromesh
1qt lightweight shockproof
and the rest 75w90 Castrol HypoyC
Old 11-26-2004, 04:27 PM   #6
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Have to give another vote for Uncle Scotty's blend, cleared up my first gear grind. I'm pretty happy with it after having Neo in it for about 20K.
jjunior887 is offline   Reply With Quote
Old 11-27-2004, 02:15 AM   #7
Jaredm83
Member#: 65816
2014 Forester XT
i put in about 2 qts of redline 75w90 synthetic and about 1.7 qts of synchromesh, cleared all my grindling problems... thanks guys
Old 11-27-2004, 09:53 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
1qt synchromesh
W00t ! ! !
Old 11-27-2004, 09:56 PM   #9
5spdfrk
Member#: 46407
blew
Haha, I wonder if you would chime in w/ your concoction!
5spdfrk is offline   Reply With Quote
Old 11-28-2004, 11:45 AM   #10
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Hey whatever works, and it does, well.
Old 11-28-2004, 02:22 PM   #11
5spdfrk
Member#: 46407
blew
Yeh, from what I hear it is teh stuff. When I change the rear diff fluid, I am also going to do US's concoction.
Old 11-28-2004, 02:59 PM   #12
rogerd
Member#: 59934
Atlantic Blue
You do not need any special "concoction" in the rear. The issue is only with the tranny where you have to lube both final drive and the "gearbox".
Old 11-28-2004, 04:25 PM   #13
5spdfrk
Member#: 46407
blew
Yeh, after reading what I typed I see how you could think that. What I meant was that when I go to change my rear diff fluid, I will change the tranny fluid at the same time.
Old 11-28-2004, 04:50 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
I used Amsoil 2000 75w90 in my rear diff.....seems to be working just fine....I would NOT use my 'cocktail' in the rear diff.
Old 11-28-2004, 04:58 PM   #15
5spdfrk
Member#: 46407
blew
Dont worry, I wan't. I have the common whine at 55-60 and I am guessing that it is in fact my rear diff. I have heard that putting better fluid in there will help reduce it. Is this true?
Old 11-28-2004, 05:03 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
Dunno about the whine....mine makes no noise...that I can hear, anyway
Old 11-28-2004, 10:34 PM   #17
rogerd
Member#: 59934
Atlantic Blue
My 95 always had a slight whine at speed in 3rd and 5th (but not 4th). I put that down to gearbox build tolerances/quality. Dumping the 75/90 and going to Valvoline Durablend 80/90 quieted things some - but made no difference to the "slow" synchro on 2nd. Basically these trannies are weak, and no amount of oil selection will fix that.
Old 11-28-2004, 10:49 PM   #18
5spdfrk
Member#: 46407
blew
Mine is usually in 4th and 5th when I am off the go pedal. If I press the gas it almost goes away, but is still there. I guess I need to make an appointment w/ the subie dealer. To bad they are over an hour away.
Old 11-28-2004, 11:38 PM   #19
Storm
Member#: 5218
96L Most Over-
Developed Beater
Lightbulb
I just got this from a known reputable source. He's extremely detail oriented when it comes to what goes in, on, or under his cars. Take it for what it's worth. I plan to try it myself.
I wouldn't bother with such a long-winded note ordinarily, but this is
different.
I've been very happy with my Imprezas. Great cars. But the 5MT has
never
been a high point of the car. Frankly, it was my least favorite aspect
of
the cars.
I had the usual issues. Heavy shifts. Balking. Occasional grinds.
The
first-gear lockout. These were all manageable, but took the polish off
the
driving experience.
I've tried MANY different Gear Oils. Most were lousy. Off the shelf
super-slick synthetics were terrible. The best thing I came across was
Redline Shockproof. Still not perfect, but better.
I more or less stopped thinking about it as of late.
But then, after studying the gearbox service manuals, I realized that
perhaps there was hope...
Rewind several years; GM produces a decent, but very temperamental MT
for
their newer cars and trucks. It was so temperamental that a potential
huge-dollar re-do was on the horizon. GM, not being complete idiots,
decided that it was possible to make the tranny work, but it would
require
some major chemical engineering to do so. They hired Pennzoil Corp to
'fix'
their trannies. They did.
The end result was GM Synchromesh MT fluid. Chemically, this stuff
contains
everything our Subaru trannies should need also. So I got to thinking.
And after a bit of Web browsing, I found many opinions. Now, because
this
Synchromesh fluid is application specific, it doesn't carry any GL-?
ratings. This worried some people, regardless of the fact that
chemically
it's more than adequate.
But of the many people that have used it in their Subaru and Honda
trannies,
not ONE was disappointed. Seriously, not even ONE bad experience.
So, after a bit more homework, I found that the fluid is sold at GM
dealerships for about $9.00/Quart. It's made by Pennzoil. Pennzoil
sells
it too, for about $4.50/Quart. But it's hard to find... anywhere but
AutoZone. Go figure.
So off I went to AutoZone to pick up the prerequisite four quarts.
Drained
out the old. Poured in the new. Crossed my fingers... and hopped in
the
Subie.
Well, I'm amazed. Actually, stunned is more like it. First off, it's
still
the Subie 5MT, and not my '95 Prelude VTEC. So it's not perfect. But
the
improvement is astounding. Truly. I would NEVER have believed it if I
hadn't tried it myself.
NO grinds. NO balking. NO first-gear lockout. And MUCH lighter shift
action. Again, I'm astounded.
I have no faith in 'miracle oils' and other such off the shelf crap.
I've
been using quality synthetics in my engines and brakes for years. Just
the
$4.50/Quart stuff. I'm 100% convinced that in general there is NO
benefit
to ultra-premium oils and such. Pure psychology. No science. I'll
NEVER
reap ANY gains by using $12.00/Quart Mega-Hyper-Lube versus the
$4.50/Quart
Valvolene I've been using. So you know I'm a non-believer.
But again, this stuff is truly miraculous. Pennzoil nailed it. Plain
and
simple. And it's cheap to boot. Virtually every bit of frustration
I've
had with my trannies is gone.
So, that's my story. My Subies now shift wonderfully. NO complaints.
Every time I hop in the cars now I can't help but smile. It's that
profound.
I hope this helps. Let me know your thoughts...
EriK
PS. Pennzoil Synchromesh = GM Synchromesh #12345349 or use GM
Synchromesh
FM #12377916
Jay Storm
Old 11-29-2004, 01:10 AM   #20
JalopySiR
Member#: 39378
2004 Carless
I love the stuff.
Like I said...
Oh, and the GL "rating" is GL-S, the "S" is for special!
Old 11-29-2004, 04:22 AM   #21
Max Umbarger
Member#: 1112
2006 FXT
RBP
I go with 3 qts. regular 75-90, and the last .7 gt of pennzoil synchromesh! It's nice!
Max Umbarger is offline   Reply With Quote
Old 11-29-2004, 01:49 PM   #22
Got Groceries?
Member#: 25323
2003 WRX Wagon
1qt Synchromesh + Castrol Hypoy-C for the balance = magic
No joke.
Got Groceries? is offline   Reply With Quote
Old 11-29-2004, 07:52 PM   #23
law
Member#: 36842
2008 2007 Exige S
AW, Black
I have been using 1qt synchromesh + 80w90 valvoline durablend for about 2k miles now with great results...
law is offline   Reply With Quote
Old 11-29-2004, 09:04 PM   #24
OneOBS
Member#: 63076
2004 Outback Sport
Red!
What's the viscosity of GM/Pennzoil Synchromesh?
OneOBS is offline   Reply With Quote
Old 11-29-2004, 10:37 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
None stated AFAIK.
can I put an 08 stereo in my 06 sti blacknbluewrx Car Audio, Video & Security 6 05-20-2011 07:09 PM
just put scottys cocktail in my tranny and... willswhitewrx Transmission (AT/MT) & Driveline 2 04-27-2010 04:03 PM
Can I put a sti turbo on my 04 wrx? obxtoy Subaru Conversions 5 08-10-2005 07:11 PM
Can I put 04+ Wagon tails in my 04+ sedan? electronfrost Newbies & FAQs 4 05-16-2005 06:39 PM
WOW!!! I JUST PUT REDLINE & SYNCHROMESH IN MY TRANNY!!! Jaredm83 Transmission (AT/MT) & Driveline 2 11-25-2004 03:03 PM
