Old 06-30-2001, 09:16 AM   #1
Neil Wallerstein
Member#: 938
2004 Former STi now
Dakota 4x4
Default WRX Torque Specs for Exhaust Header Bolts
Could someone who has the shop manuals give me the torque specs for the WRX Exhaust Header Bolts.
Thanks
Neil Wallerstein is offline   Reply With Quote
Old 06-30-2001, 01:48 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
The bolts into the engine should be torqued to 40 Nm (28.9 ft-lb) and the bolts that connect other pipes to the exhaust manifolds should be torqued to 35 Nm (26 ft-lb). The manifold cover bolts should be torqued to 19 Nm (13.7 ft-lb). And all gaskets exposed should be replaced with new ones. If you have to remove the front O sensor from the RH exhaust manifold, make sure it's cooled down and re-install it (after applying anti-seize compound to the threads) with 21 Nm (15.2 ft-lb) of torque.
Jon [in CT] is offline   Reply With Quote
Torque specs for Cosworth rod bolts for EJ25? Navid Built Motor Discussion 0 10-20-2007 10:57 PM
Torque specs for exhaust headers ('05 RS) Airboy Service & Maintenance 2 08-09-2005 05:34 PM
Torque specs for exhaust header bolts Airboy Normally Aspirated Powertrain 0 08-04-2005 03:40 PM
Torque Specs on Exhaust Manifold Bolts? nhalterman Normally Aspirated Powertrain 2 08-25-2003 10:23 PM
What is the WRX torque spec for this bolt? ThinkTank Brakes, Steering & Suspension 0 02-20-2002 01:21 PM
